to display simple on-screen solutions. If it is difficult to understand the procedures on the display, see the following sections to clear jams. Carefully read the precautions in Maintenance and Inspections before cleaning paper jams.
When removing the jammed paper, do not turn OFF the machine
Turning OFF the machine deletes the data that is being printed. Be especially careful when receiving fax documents.
If paper tears
Remove all the paper fragments to prevent them from becoming jammed.
If paper jams repeatedly
Tap the paper stack on a flat surface to even the edges of the paper before loading it into the machine.
Check that the paper is appropriate for the machine.
Check that no jammed paper fragments remain in the machine.
Do not forcibly remove the jammed document or paper from the machine
Forcibly removing the paper may damage parts. If you are not able to remove the paper, contact your local authorized Canon dealer.
1
Open the feeder cover.
2
Move the lever to unlock.
3
Gently pull out the document.
1
Place your finger in the hole indicated by the green mark, and lift the inner cover.
2
3
Close the inner cover.
1
Open the feeder.
2
3
Gently close the feeder.
to select <Yes>, and press
