The machine can print received fax documents on A4 or Letter size paper. If received fax documents are printed on other paper sizes, a portion of the page may not be printed or a page may be printed on two separate sheets of paper.
<Auto>
Dedicated to receiving faxes
The machine receives faxes automatically. Even if someone makes a call to you, you cannot talk to the caller.
<Fax/Tel (Auto Switch)>
When the call is a fax
The machine receives the fax automatically.
When the call is a telephone call
An incoming call rings. Pick up the handset to answer the call.
NOTE:
You need to connect your telephone to the machine beforehand.
<Answering Machine>
After an incoming call rings, the machine receives the fax automatically.
The answering machine activates, enabling the caller to leave a message. If you pick up the handset before the answering machine starts recording a message, you can talk with the caller.
NOTE:
You need to connect your answering machine to the machine beforehand.
Set the answering machine to answer after a few rings.
We recommend that you add approximately 4 seconds of silence at the beginning of the message or set the maximum recording time to 20 seconds.
<Manual>
An incoming call rings. Pick up the handset. If you hear a beep, press
, select <Start Receiving>, and press to receive faxes.![]() When the call is a telephone call
An incoming call rings. Pick up the handset and start your conversation.
NOTE:
You can set the machine to automatically receive faxes when an incoming call rings within a specified timeframe. Switch to Auto RX
<DRPD>
If you have subscribed to a Distinctive Ring Pattern Detection (DRPD) service provided by your telephone company, this receiving mode is available. This service assigns two or more telephone numbers with distinctive ring patterns to a single telephone line. You can use one of these numbers for faxes and one for telephone calls.
When the machine receives a call, it automatically recognizes the ring pattern and your telephone rings differently depending on whether the call is a fax or telephone call. If the ring pattern is for a fax, the machine automatically receives the fax.
NOTE:
For more information about this service, contact your telephone company.
Depending on the type of telephone connected to it, the machine may not be able to send or receive faxes properly.
If you are connecting an external telephone with fax functions, set the telephone not to receive faxes automatically.
If you pick up the telephone handset and hear a beep, the call is a fax. You can receive the fax just by using the telephone to enter a specific ID number.
Using a Telephone to Receive Faxes (Remote Reception) |
to select <RX Mode>, and press
When selecting <Fax/Tel (Auto Switch)>
<Ring Start Time>
<Incoming Ring Time>
<After Ring>
When selecting <DRPD>
TIPS
If you want to print received documents on both sides of paper: Print on Both Sides
If you want to print information, such as reception date and time, at the bottom of received documents: RX Page Footer
If you want to save toner when you print received documents: Saving Toner
