If your office has an LDAP server installed, you can use the destinations registered in the server. To specify destinations, access an LDAP server via the machine, and then search for a destination.
You need to specify the settings for connecting to an LDAP server beforehand.
to select <Specify from LDAP Server>, and press
toggles the input modes (except for searching by fax number).
<Using All Conditions Below>
<Using Some Conditions Below>
. You can enter the user name and password of the machine or yours, depending on the setting (Registering LDAP Servers (imageRUNNER 1435iF / 1435i Only)). If you are not sure, ask your Network Administrator.
To delete destinations
1
Select <Confirm/Edit Destination>, and press
2
Select a destination you want to delete, and press
3
Select <Delete Destination>, and press
4
Select <Yes>, and press
If you want to easily and quickly delete destinations without displaying a list of destinations
Before selecting <Confirm/Edit Destination> in step 1, you can press
/ to toggle the destinations you specified. Display a destination you want to delete <Yes> . |
