Category
Top » Specifications » Printer Specification
Category Top
Machine Specifications
Wireless LAN Specification
Copy Specifications
Scanner Specifications
Fax Specifications
Telephone Specifications
Transmission Specification
Optional Drawer
Document Type
Supported Document Types
Scan Area
Paper
Supported Paper Types
Printable Area
Collapse all|Expand all
07K4-04W
Printing Method
Indirect electrostatic system (On-demand fixing)
Paper Capacity
Multi-purpose tray: Approx. 50 sheets (16 to 23 lb Bond (60 to 89 g/m²))
Paper drawer: Approx. 250 sheets (16 to 23 lb Bond (60 to 89 g/m²))
Paper Feeder Unit PF-44 (Optional): Approx. 500 sheets (16 to 23 lb Bond (60 to 89 g/m²))
Output Tray Capacity (a fresh stack of Letter size paper)
Output tray: Approx. 150 sheets (20 lb Bond (75 g/m²))*1
Sub Output tray: 1 sheet
Print Speed (Letter  Plain Direct)*2
35 ppm
First Print Time (Letter)
6 seconds or less*3
Output Resolution
Equivalent to 1200dpi x 600dpi
Gradation
256 gradations
Toner Cartridges
*1
The actual paper capacity varies depending on the installation environment and paper type used.
*2
The print speed on Letter size plain paper on one-side printing is measured during continuous printing. Print speeds vary depending on the paper type and size, as well as the paper feeding direction. Print speeds on smaller paper sizes may be slower. Plus, the machine may experience downtime or decrease the print speed in the middle of a continuous print run to adjust the temperature inside the machine or maintain the optimal print quality.
*3
May vary depending on the output environment.
