Machine Specifications
Type
Personal Desktop
Power Supply
120 to 127 V, 60 Hz (Power requirements can vary by country. They depend on where you purchased the product.)
Power Consumption
Maximum
1,100 W or less Average consumption during standby mode
Approx. 9 W Average consumption during sleep mode
Approx. 2.3 W Approx. 3.0 W (by Wireless Connections) When the main power switch is turned OFF
0.1 W or less |
Warm-up Time
11 seconds or less*
(Temperature: 68 °F (20 °C), humidity: 65% RH ; from when the machine is turned ON using the main power switch to when the standby screen is displayed)
Weight
Main unit (the toner cartridge included): Approx. 42.8 lb (19.4 kg)
Dimensions
(W x L x H) |
In the normal state
18 5/8" x 18 5/8" x 17" (472 mm x 473 mm x 431 mm) When the optional drawer is installed
18 5/8" x 18 5/8" x 22 3/8" (472 mm x 473 mm x 569 mm) |
Installation Space
(W x L x H) |
In the normal state
26 1/2" x 50 3/8" x 31 3/8" (672 mm x 1,279 mm x 795 mm) When the optional drawer is installed
26 1/2" x 50 3/8" x 36 3/4" (672 mm x 1,279 mm x 933 mm) |
Environmental Conditions
Temperature: 50 to 86°F (10 to 30°C)
Humidity: 20% to 80% RH (no condensation)
Acceptable Documents
Acceptable Paper Stock
Printable Area
Scan Area
