Category
Top » Troubleshooting » Troubleshooting » Fax Problems » Receiving Problems » Modes Cannot Switch Automatically between Telephone and Fax
Category Top
Error Codes
When a Power Failure Occurs
Clearing Jams
Document Jams in the Feeder
Paper Jams in the Output Area
Paper Jams in the Multi-Purpose Tray
Paper Jams in the Paper Drawer (Drawer 1 or 2)
Paper Jams in the Back Cover and Duplex Unit
Paper Jams in the Front Cover
Paper Jams in the 2-sided Transport Guide
When <Incorrect Size/Setting> Appears
Onscreen Messages
Troubleshooting
Paper Feeding Problems
Fax Problems
Sending Problems
Cannot Send a Fax
Receiving Problems
Faxes Cannot Be Printed, or the Images on Printouts Are Spotted or Distorted
Copying Problems
The Copy Output Is Hardly Readable and Copied Poorly
Printing Problems
Cannot Print Documents from a Computer
Cannot Print over a TCP/IP Network
Scanning Problems
Cannot Scan a Document
Telephone Problems
Network Problems
Wired LAN Troubles
Checking Network Connection (Wired LAN)
Wireless LAN Troubles
Checking Network Connection (Wireless LAN)
Installation and Uninstallation Problems
Miscellaneous Problems
Printing Results Are Not Good
Paper Curls
Paper Creases
Vertical Streaks Appear on the Output
Toner Smudges and Spatters Appear around Text and Images
The Bottom Edge of Paper or Following Paper Has Smudge Marks
A Portion of the Page Is Not Printed
Uninstalling the Software
When a Problem Cannot Be Resolved
Collapse all|Expand all
07K4-0U1
Is the machine set to automatically switch modes between telephone and fax?
NO
Set the receive mode to <Fax/Tel Auto Switch> or <Answering Machine>.
When <Answering Machine> is set, make sure that an external telephone with the built-in answer function is connected to the machine. Also make sure that it is always turned on and the recorded answering message can be heard anytime.
YES
Is the time set for <Ring Start Time> too short?
YES
When you set the ring time too short, incoming faxes may be regarded as incoming phone calls. Set a longer ring time for incoming faxes in <Ring Start Time>.
NO
Is the line condition of the sender's machine good?
NO
Change the <RX Start Speed>.
YES
Is memory full?
YES
Print, send, or delete jobs stored in memory.
NO
Can the sender's machine send a switching signal, to notify your machine of an incoming fax?
NO
Some machines cannot send this signal. In this case, receive the fax manually.
