The settings that you cannot specify using FTP Client, NetSpot Device Installer, or the control panel on the printer
Specify them using a Web browser (Remote UI).
(However, you cannot specify the settings with
even using the Remote UI.)About the item names
In the following table, the characters shown in parentheses are exclusively for FTP Client.
For example, "[IP Address] (INT_ADDR)" is displayed differently as follows, depending on the application.
: Can be specified
: Cannot be specified|
Option
Contents
Default
Settings
Using NetSpot Device Installer |
Settings
Using FTP Client |
Settings Using the Control Panel
[Device Name]
(DEVICE_NAME)
Up to 32 characters
LBP5480
[Location]
(SYS_LOC)
Up to 32 characters
(Blank)
[System Manager]
(SYS_CONTACT) |
Up to 32 characters
(Blank)
[System Manager Password]
(ROOT_PWD) |
Up to 16 characters
7654321
[Permit End-User's Job Operation]
(USER_JOB_CONT)
ON, OFF
OFF
Support Link
[URL]
(LINK_URL1)
Up to 128 alphanumeric characters
http://www.canon.com
: Can be specified
Option
Contents
Default
Settings Using NetSpot Device Installer
Settings Using FTP Client
[Use IPv4] (IPV4_USE)
ON, OFF
ON
[DHCP] (DHCP_ENB)
ON, OFF
OFF
[RARP] (RARP_ENB)
ON, OFF
OFF
[BOOTP] (BOOTP_ENB)
ON, OFF
OFF
IP address
0.0.0.0
[Subnet Mask] (NET_MASK)
IP address
0.0.0.0
[Gateway Address] (DEF_GW)
IP address
0.0.0.0
[Primary DNS Server Address] (DNS_PADDR)
IP address
0.0.0.0
[Secondary DNS Server Address] (DNS_SADDR)
IP address
0.0.0.0
[Host Name] (HOST_NAME)
Up to 47 alphanumeric characters
"Canon" + "Last 6 digits of the MAC address"
[Domain Name] (DOMAIN_NAME)
(Blank)
[DNS Dynamic Update] (DDNS_ENB)
ON, OFF
OFF
[WINS Resolution] (WINS_ENB)
ON, OFF
OFF
[WINS Server Address] (WINS_SERVER)
IP address
0.0.0.0
[Scope ID] (WINS_SCOPEID)
Up to 63 alphanumeric characters
(Blank)
[SMB Server Name] (SMB_SERVER)
Up to 15 alphanumeric characters
(Blank)
[SMB Workgroup Name] (SMB_WG)
(Blank)
[Use ARP/PING] (ARP_PING_ENB)
ON, OFF
ON
[Use FTP Print] (FTP_PRINT_ENB)
ON, OFF
OFF
[FTP Print User Name] (FTP_PRINT_USER)
Up to 24 alphanumeric characters
guest
[Password] (FTP_PRINT_PWD)
7654321
[FTP Settings]
ON, OFF
OFF
[Use LPD Printing] (LPD_ENB)
ON, OFF
ON
[Print LPD Banner Page] (LPD_BANN)
ON, OFF
OFF
[Use RAW Printing] (RAW_ENB)
ON, OFF
ON
[Use Bidirectional Communication] (RAW_BIDIR_ENB)
ON, OFF
OFF
[Use IPP Print] (IPP_ENB)
ON, OFF
OFF
[SSL]
ON, OFF (Fixed at OFF when a key is not registered.)
OFF
[IPP Authentication] (IPP_AUTH_ENB)
ON, OFF
ON
[User Name] (IPP_AUTH_ACCUNT1)
Up to 24 characters (Must be entered when using IPP Authentication)
guest
[Password] (IPP_AUTH_PASSWD1)
7654321
[Use WSD Printing] (WSD_ENB)
ON, OFF
OFF
[Use WSD Browsing] (WSD_BROWSING)
ON, OFF
OFF
[Use Multicast Discovery] (WSD_MULTICAST_DISCOVERY)
ON, OFF
OFF
[Use HTTP] (HTTP_ENB)
ON, OFF
ON
[Use Proxy]
ON, OFF
OFF
[HTTP Proxy Server Address]
(Blank)
[HTTP Proxy Server Port Number]
0 to 99999
80
[Use Proxy within Same Domain]
ON, OFF
OFF
[Proxy Authentication]
ON, OFF
OFF
[User Name]
(Blank)
[Password]
(Blank)
[Discovery Response] (DISCOVERY_ENB)
ON, OFF
ON
[Scope Name] (DISCOVERY_SCOPE_NAME)
Scope name to be used for discovery using utility software such as NetSpot Device Installer. (Up to 32 characters)
default
[Use SNTP] (SNTP_ENB)
ON, OFF
OFF
[NTP Server Name] (SNTP_ADDR)
IP address or host name
(Blank)
[Polling Interval] (SNTP_INTERVAL)
Interval for synchronizing time (1 to 48 hours)
24
: Can be specified
Option
Contents
Default
[Use IPv6] (IPV6_USE)
ON, OFF
OFF
[Use Stateless Address] (IPV6_STATELESS_USE)
ON, OFF
ON
[Use Manual Address] (IPV6_MANUAL_ADDR_USE)
ON, OFF
OFF
[IP Address] (IPV6_MANUAL_ADDR_SET)
IP address
(Blank)
[Prefix Length] (IPV6_MANUAL_ADDR_PREFIX)
0 to 128
64
[Default Router Address] (IPV6_MANUAL_ROUTER_ADDR)
IP address
(Blank)
[Use DHCPv6] (IPV6_DHCPV6_USE)
ON, OFF
OFF
[Primary DNS Server Address] (IPV6_DNS_ADDRESS_PRI)
IP address
(Blank)
[Secondary DNS Server Address] (IPV6_DNS_ADDRESS_SEC)
IP address
(Blank)
[Use IPv4 Host/Domain Names] (IPV6_DNS_NAME_SAME_AS_IPV4)
ON, OFF
OFF
[Host Name] (IPV6_DNS_HOST_NAME_V6)
[Domain Name] (IPV6_DNS_DOMAIN_NAME_V6)
(Blank)
[DNS Dynamic Update] (IPV6_DNS_DYNAMIC_SET)
ON, OFF
OFF
[Register Manual Address] (IPV6_DNS_MANUAL)
ON, OFF
OFF
[Register Stateful Address] (IPV6_DNS_STATEFUL)
ON, OFF
OFF
[Register Stateless Address] (IPV6_DNS_STATELESS)
ON, OFF
OFF
: Can be specified
Option
Contents
Default
[Use NetWare] (NW_ENB)
ON, OFF
OFF
[Frame Type] (NW_FRAME_TYPE)
Frame type used by NetWare
AutoSense([Auto Detect])
[IPX External Network Number]
(Display only)
[Node Number]
(Display only)
[Print Service] (NW_PRINT_SERVICE)
Print service to be used
ndsPserver([NDS PServer])
Bindery PServer
[File Server Name] (NW_PSERVER_FILE_SERVER_
NAME)
Name of the NetWare file server to which the NetWare print server belongs (1 to 47 characters)
(Blank)
[Print Server Name] (NW_PSERVER_PRINT_SERVER_NAME)
NetWare print server name to be used (1 to 47 characters)
(Blank)
[Print Server Password] (NW_PSERVER_PASSWD)
Password for accessing the print server (0 to 20 characters)
(Blank)
[Printer Number] (NW_PSERVER_PRINTER_NO)
Number for the printer connected to the NetWare print server (0 to 15)
0
[Service Mode] (NW_PSERVER_SERVICE_MODE)
Service mode to be used
psMode1: Only the currently loaded paper can be serviced.
psMode2: Paper can be changed as needed.
psMode3: The order of the jobs is rearranged to minimize the frequency of changing paper.
psMode4: The order of the jobs in a queue is rearranged to minimize the frequency of changing paper.
psMode4
[Printer Form] (NW_PSERVER_PRINTER_FORM)
Paper Define Form (0 to 255)
0
[Polling Interval] (NW_PSERVER_POLLING_INT)
Interval for checking the jobs (1 to 15 seconds)
5
[Buffer Size] (NW_PSERVER_BUFFER_SIZE)
Data Buffer Size (1 to 20 KB)
20
NDS PServer
[Tree Name](NW_NDSSERVER_TREE_NAME)
Name of the NDS tree to which the NetWare print server belongs (1 to 32 characters)
(Blank)
[Context Name] (NW_NDSSERVER_CONTEXT_
NAME)
Name of the context to which the NetWare print server belongs (1 to 255 characters)
(Blank)
[Print Server Name] (NW_NDSSERVER_PRINT_
SERVER_NAME)
NetWare print server name to be used (1 to 64 characters)
(Blank)
[Print Server Password] (NW_NDSSERVER_PRINT_
SERVER_PASSWORD)
(Blank)
[Printer Number] (NW_NDSSERVER_PRINTER_NO)
Number for the printer connected to the NetWare print server (0 to 254)
0
[Service Mode] (NW_NDSSERVER_SERVICE_
MODE)
psMode4
[Printer Form] (NW_NDSSERVER_PRINTER_FORM)
0
[Polling Interval] (NW_NDSSERVER_POLLING_INT.)
Interval for checking the jobs (1 to 255 seconds)
5
[Buffer Size]
(NW_NDSSERVER_BUFFER_SIZE)
Data Buffer Size (3 to 20 KB)
20
RPrinter
[File Server Name] (NW_RPRINTER_FILE_SERVER_
NAME)
(Blank)
[Print Server Name] (NW_RPRINTER_PRINT_SERVER_
NAME)
(Blank)
[Printer Number] (NW_RPRINTER_PRINTER_NO)
0
NPrinter
[Tree Name](NW_NPRINTER_TREE_NAME)
Name of the NPrinter tree to which the NetWare print server belongs (1 to 32 characters)
(Blank)
[Context Name] (NW_NPRINTER_CONTEXT_NAME)
Name of the context to which the NetWare print server belongs (1 to 256 characters)
(Blank)
[Print Server Name] (NW_NPRINTER_PRINT_SERVER_
NAME) |
(Blank)
[Printer Number](NW_NPRINTER_PRINTER_NO)
0
: Can be specified
Option
Contents
Default
Settings
Settings
Using FTP Client |
[Use AppleTalk]
(ATLK_ENB)
ON, OFF
OFF
[Phase]
Fixed at [Phase 2]
[Phase 2]
[Service Name]
(APRINT_1)
Up to 32 characters *1
LBP5480
[Zone]
(ATK_ZONE)
Up to 32 characters *2
[Print Mode]
[Open Both Spool and Direct], [Open Spool], [Open Direct]
*1
"=", "@", "*", ":", and "~" cannot be used.
*2
"=", "@", ":", and "~" cannot be used.
: Can be specified
Option
Contents
Default
Settings
Settings
Using FTP Client |
[Use SMB Server](SMB_ENB)
ON, OFF
OFF
[Server Name](SMB_SERVER)
Up to 15 characters
(Blank)
[Workgroup Name](SMB_WG)
Up to 15 characters
(Blank)
[Comments](SMB_COMMENT)
Up to 48 characters
(Blank)
[Use LM Announce](SMB_LM_ENB)
ON, OFF
OFF
[Use SMB Printing](SMB_PRINT_ENB)
ON, OFF
OFF
[Printer Name](SMB_PRINTER)
Up to 13 characters
(Blank)
: Can be specified
Option
Contents
Default
Settings
Settings
Using FTP Client |
[Use SNMPv1]
(SNMP_V1_ENB)
ON, OFF
ON
[Use Community Name 1]
(SNMP_COMMUNITY1_ENB)
ON, OFF
ON
[Community Name 1]
(SNMP_COMMUNITY1_NAME) |
Up to 32 characters
public
[MIB Access Permission]
(SNMP_COMMUNITY1_ACCESS)
RW, RO
([Read/Write], [Read Only]) |
RO
([Read Only]) |
[Use Community Name 2]
(SNMP_COMMUNITY2_ENB)
ON, OFF
OFF
[Community Name 2]
(SNMP_COMMUNITY2_NAME) |
Up to 32 characters
public2
(SNMP_COMMUNITY2_ACCESS)
RW, RO
RO
([Read Only]) |
[Use SNMPv3]
(SNMP_V3_ENB)
ON, OFF
OFF
[Obtain Printer Management Information from Host]
(SNMP_GET_PRT_MNG_INFO)
ON, OFF
OFF
[Reject SNMP Packets While in Sleep Mode]
ON, OFF
OFF
: Can be specified
Option
Contents
Default
Settings
Settings
Using FTP Client |
[User Name]
Up to 32 alphanumeric characters
initial
[Read/Write]
[Security Settings]
[Authentication Yes/Encryption Yes], [Authentication Yes/Encryption No], [Authentication No/Encryption No]
[Authentication Algorithm]
[MD5], [SHA1]
[MD5]
[Authentication Password] *
6 to 16 alphanumeric characters
initial
[Encryption Algorithm]
[DES], [AES]
[DES]
[Encryption Password] *
initial
Can be specified only when the printer is in the state of SSL encrypted communication. (If the printer is not in the state of encrypted communication, specify the setting using the printer's control panel.)
: Can be specified
Option
Contents
Default
Settings
Settings
Using FTP Client |
[Context Name 1] - [Context Name 5]
(Blank)
: Can be specified
Option
Contents
Default
Settings
Settings
Using FTP Client |
[Use Spooler](SPOOL_ENB)
ON, OFF
OFF
: Can be specified
Option
Contents
Default
Settings
Settings
Using FTP Client |
[Startup Time]
(STRT_DELAY_TIME)
Waiting time from when you turn the printer ON to when the printer starts obtaining the address (0 to 300 seconds)
0
: Can be specified
Option
Contents
Default
Settings
Settings
Using FTP Client |
[Auto Detect]
ON, OFF
ON
[Communication Mode]
[Half Duplex], [Full Duplex]
[Half Duplex]
[Ethernet Type]
[10 Base-T], [100 Base-TX], [1000 Base-T]
[10 Base-T]
: Can be specified
Option
Contents
Default
Settings
Settings
Using FTP Client |
[POP3 Server Name](EMAIL_POP_ADDR)
Up to 48 alphanumeric characters
(Blank)
[POP3 User Name](EMAIL_POP_ACCOUNT)
(Blank)
[Password](EMAIL_POP_PASSWD)
(Blank)
[POP3 RX Interval](EMAIL_POP_INTERVAL)
0 to 90 minutes
0
[POP3 RX](EMAIL_PRINT_ENB)
ON, OFF
OFF
[POP3 Server Port Number](EMAIL_POP_PORTNO)
0 to 65535
110
[SMTP RX]
ON, OFF
OFF
[SMTP Server Port Number]
0 to 65535
25
: Can be specified
Option
Contents
Default
Settings
Settings
Using FTP Client |
[Remote UI](RUI_ENB)*
Turing ON or OFF the Remote UI
ON
[Use SSL]
ON, OFF
OFF
Can be specified only by FTP Client or the printer's control panel
: Can be specified
Option
Contents
Default
Settings
Settings
Using FTP Client |
[MAC Address Filter]
ON, OFF
ON
[MAC Address]
(Display only)
Specifiable
Not specifiable
Can perform a part of the settings
Setting Type
Web Browser (Remote UI)
FTP Client
ARP/PING Command
Control Panel of the Printer
Configuring the Ethernet Driver
Setting the Spooling Function
Configuring the Communication Environment
Setting the IP Address of the Printer
Setting the TCP/IP Protocol
Setting IP v. 6
Preparing the NetWare Protocol Settings
Setting the NetWare Protocol
Setting the AppleTalk Protocol
Changing the Device Name or Administrator Information
Changing the Administrator Password
Specifying the Job Operation Permission for End-users
Restricting the Job Requests by Certain Devices
Setting the Key Lock Function
Changing E-Mail Print Settings
