Installing the Printer
If you want to use the printer with optional accessories installed, install them before installing the printer.
Carrying the Printer to the Installation Site
1
Carry the printer unit to the installation site.
After confirming that the covers and trays are closed, carry the printer with two or more people by holding the lift handles on the lower portion of the printer and lifting it up at the same time.
Check the weight of the printer and then start to carry it, making sure that you can hold it safely.
Connecting the Power Cord
1
Connect the power cord.
The form of the supplied power cord
The form of the supplied power cord may differ from the one in the above illustration.
2
Press the power switch to turn the printer ON.
The indicators and display on the control panel come on, and the printer initiates a self-diagnostic test on the printer unit and optional accessories.
If no abnormality is found during the self-diagnostic test, the Main Power indicator (green), Ready indicator (green), Online indicator (green) and Paper Source indicator (green) come on, <Ready to print.> appears in the display, and the printer is ready to print.
The following information is displayed in the display.
Next, perform the following procedures.
1
Specifying the printer's initial settings
Specifying a type of printer driver
2
Load paper.
3
Connecting to a computer
4
Install the printer driver.
5
Check the printing operation.
Check the operations by Test Page in Windows.
» Printer Installation » Installing the Printer
07E3-025
