The CD-ROM drive name is indicated as "D:" in this manual. The CD-ROM drive name may differ depending on the computer you are using.
From the [Start] menu, select [Run].
Enter "D:\Maninst.exe."
Click [OK].
Enter "D:\Maninst.exe" in [Search programs and files] or [Start Search] under the [Start] menu.
Press the [ENTER] key on the keyboard.
Correctly enter the IP address which is set for the printer. If the wrong IP address is entered, you cannot obtain an appropriate check result.
When using DHCP, BOOTP, or RARP
Consult your network administrator and perform either of the following settings.
Configure DHCP or other settings so that the same IP address is always assigned to the printer when the printer is started.
"Configuring the Protocol Settings"Checking and configuring the subnet
Enter "ipconfig" as a command in Command Prompt.
The network setting information of the computer appears. Confirm that the computer and printer are on the same subnet.
(1)
Display the [General] tab.
(2)
Click [Print Test Page] to print a test page.
(1)
Display the [Ports] tab.
(2)
Check the [Enable bidirectional support] check box is selected.
Do not clear the [Enable bidirectional support] check box.
If the check box is cleared, you cannot perform printing.
(1)
Select the print server from [Network] or [My Network Places].
(2)
Check the icon for this printer is displayed.
(1)
(2)
Confirm the port is selected properly.
(1)
To change the printing protocol to LPR, select [LPR] for [Protocol].
(2)
To enable the LPR byte count, select the [LPR Byte Counting Enabled] check box.
(1)
Select [Standard], and then select [Canon Network Printing Device with P9100].
(2)
Click [Next].
