Printer Specifications
Hardware Specifications
Type
Desktop Page Printer
Printing System
Semiconductor laser + xerographic system
Toner fixing system
On-demand fixing system
Resolution
600 dpi
Printing speed
(Plain paper (16.0 to 27.9 lb Bond (60 to 105 g/m²)), when printing Letter size paper continuously)
Black and white printing:
33 pages/min. (1-sided printing)
28.9 pages/min. / 14.5 sheets/min. (2-sided printing)
Color printing:
The print speed may drop depending on the paper settings for the size, type, orientation, and number of copies.
Warm up time
(Time from power on to printer ready)
39 seconds or less
May vary depending on the usage conditions, such as the availability of the optional accessories and installation environment.
Recovery time
(Time from the sleep mode to printer ready)
0 seconds when the printer is in Sleep Mode 1 (the Panel Sleep mode)
7 seconds when the printer is in Sleep Mode 2 (the Printer Sleep mode)
30 seconds or less when the printer is in Sleep Mode 3 (the Deep Sleep mode) *
It is the default setting. For details on [Sleep Mode], see "Sleep Mode."
May vary depending on the output environment.
First print time
(When performing 1-sided printing on Letter size paper and outputting face-down)
Black and white printing: 10.2 seconds or less
Color printing: 10.4 seconds or less
Paper size
Drawer 1
Standard sizes:
A4, B5, A5, A6, Letter, Executive Statement and 16K
Custom paper sizes *1:
In case of portrait orientation (only when the UFR II printer driver is used): Short edges 5.83 to 8.50 in. (148.0 to 215.9 mm); Long edges 5.83 to 8.50 in. (148.0 to 215.9 mm)
In case of landscape orientation: Short edges 4.00 to 8.50 in. (101.6 to 215.9 mm) *2; Long edges 5.83 to 11.69 in. (148.0 to 297.0 mm) *3
Drawer 2 (Optional)
Standard sizes:
A4, B5, A5, Legal, Letter, Executive, Foolscap and 16K
Custom paper sizes*1:
In case of portrait orientation (only when the UFR II printer driver is used): Short edges 8.27 to 8.50 in. (210.0 to 215.9 mm); Long edges 8.27 to 8.50 in. (210.0 to 215.9 mm)
In case of landscape orientation: Short edges 5.83 to 8.50 in. (148.0 to 215.9 mm); Long edges 8.27 to 14.00 in. (210.0 to 355.6 mm)
Multi-purpose tray
Standard sizes:
A4, B5, A5, A6, Legal, Letter, Executive, Statement, Foolscap, 16K, Index Card, Envelope DL, Envelope No.10, Envelope ISO-C5, and Envelope Monarch
In case of portrait orientation (only when the UFR II printer driver is used): Short edges 5.00 to 8.50 in. (127.0 to 215.9 mm); Long edges 5.00 to 8.50 in. (127.0 to 215.9 mm)
In case of landscape orientation: Short edges 3.00 to 8.50 in. (76.2 to 215.9 mm); Long edges 5.00 to 14.00 in. (127.0 to 355.6 mm)
*1
Width must not be greater than length (height).
*2
When width is 8.50 in. (215.9 mm), max length is 11.00 in. (279.4 mm).
*3
When length is 11.69 in. (297.0 mm), max width is 8.27 in. (210.0 mm).
Paper capacity
Drawer 1: Approx. 500 sheets
Drawer 2 (Optional): Approx. 500 sheets
Multi-purpose tray: Approx. 100 sheets
2-sided printing
Standard sizes:
A4, B5, A5, Legal, Letter, Executive, Foolscap, 16K
Custom paper sizes:
Paper output
Face-down
Output capacity
Approx. 250 sheets
Actual paper capacity varies depending on the installation environment and paper type to be used.
Noise
(measured in accordance with ISO 7779, declared noise emission in accordance with ISO 9296)
LwAd (declared A-weighted sound power level (1 B = 10 dB))
During standby: 5.3 B or less *
During operation: 7.0 B or less
LpAm (declared A-weighted sound pressure level (bystander position))
During standby: 32.4 dB *
During operation: 52 dB
Indicates the sound pressure level of each bystander position is below the ISO 7779 absolute criteria for the background noise level.
Operating environment
(Printer unit only)
Temperature range: 50 to 86°F (10 to 30°C)
Humidity range: 20 to 80% RH (no condensation)
Power supply
120 to 127 V, 60 Hz
Power consumption (at 68°F (20°C))
Maximum: 1,350 W or less
Average during operation: Approx. 605 W
Average during standby: Approx. 36 W
Average during Panel Sleep Mode (Sleep Mode 1): Approx. 35 W
Average during Printer Sleep Mode (Sleep Mode 2): Approx. 10 W
Average during Deep Sleep Mode (Sleep Mode 3): Approx. 1 W*
When the main power switch is turned OFF: 0.1 W or less
Even if the printer is turned OFF, power is still consumed slightly while the power plug is inserted in the AC power outlet.
To stop the power consumption completely, unplug the power plug from the AC power outlet.
Consumables
Toner cartridge
Canon GPR-45 H Black Toner
Canon GPR-45 Yellow Toner
Canon GPR-45 Magenta Toner
Canon GPR-45 Cyan Toner
For details on the yield, see "Replacement Timing" in "Consumables."
Waste toner container
WASTE TONER BOX WT-723
Weight
Printer unit and included parts
Printer unit (excluding the toner cartridges and drum cartridge): Approx. 69.4 lb (31.5 kg)
Toner cartridge: Approx. 1.0 kg
Consumables and optional accessories
Toner cartridge (each standard capacity) (Canon Genuine Cartridge): Approx. 1.0 kg
Toner cartridge (high capacity) (Canon Genuine Cartridge): Approx. 1.0 kg
Paper Feeder Unit PF-723A (including the paper drawer): Approx. 17.6 lb (8.0 kg)
Controller Specifications
CPU
528 MHz + 264 MHz
Memory (RAM) capacity
768 MB
Host interface
USB interface:
Hi-Speed USB (3) (1 front and 2 back)
Network interface:
Shared 10BASE-T/100BASE-TX/1000BASE-T (RJ-45)
Full duplex/Half duplex
User interface
LCD:
132 x 65 dots
F-STN liquid crystal display
LED indicator:
8
Operation key:
12
ROM slot
1
SD card slot
1
Software Specifications
Built-in control command
PCL5c, PCL6, PostScript 3 emulation, UFR II, PDF, and XPS
Built-in fonts
PCL:
93 Scalable fonts, 10 Bitmap fonts
PS:
136 standard fonts
Printable area
PCL5c/PCL6:
Data cannot be printed within a 0.167 in. (4.2 mm) margin (0.39 in. (10 mm) margin for envelopes) on all sides of the paper.
UFR II/PS:
Data cannot be printed within a 0.20 in. (5 mm) margin (0.39 in. (10 mm) margin for envelopes) on all sides of the paper.
For details, see "Printable Area."
Network interface
Supported protocol
TCP/IP (Frame type: Ethernet II)
AppleTalk
NetWare
SMB (option)
Print application
LPD
RAW
IPP/IPPS
FTP
WSD
» About This Printer » Printer Specifications
07E3-011
