A Phillips screwdriver is required.
Have a screwdriver ready that matches the size of the screws for the slot cover.
Shut down the printer before turning it OFF.
For details on the procedure for shutting down the printer, see "Turning the Printer ON/OFF." |
USB cable*
(2) Turn the computer OFF.
(3) Disconnect the cable from the printer.
LAN cable*
(4) Disconnect the cable from the printer.
Power cord
(5) Disconnect the power plug from the AC power outlet.
(6) Disconnect the cord from the printer.
Whether the cable is connected or not varies depending on your environment.
(1)
Remove the screws marked with "
" or " ".![]() |
(2)
Open the slot cover.
(3)
Remove the cover in the direction of the arrow.
About the location for installing ROM
Confirm the installation location and its orientation before installing the ROM module.
(1)
Attach the slot cover.
(2)
Close the cover.
Next, perform the following procedures. (If you want to install the SD card, follow the procedure from Step 2 in "Installing SD Card".)
