Item
Setting Description
Default
Setting |
Can be set in
Remote UI |
Device Information
Delivery Available |
[Paper Settings]
Select the paper source:
Thin 2 (60-63 g/m2), Thin 1 (64-79 g/m2), Plain (80-105 g/m2), Heavy 1 (106-128 g/m2), Heavy 2 (129-150 g/m2), Heavy 3 (151-180 g/m2), Heavy 4 (181-209 g/m2), Heavy 5 (210-256 g/m2), Heavy 6 (257-300 g/m2), Heavy 7 (301-325 g/m2), Heavy 8 (326-350 g/m2), Color (64-79 g/m2), Recycled 1 (64-79 g/m2), Recycled 2 (80-105 g/m2), Recycled 3 (210-256 g/m2), Pre-Punched 1 (64-79 g/m2), Pre-Punched 2 (80-105 g/m2), Transparency (151-180 g/m2), Clear Film (151-180 g/m2), Translucent Film (151-180 g/m2), Labels (151-180 g/m2), Tab 1 (151-180 g/m2), Tab 2 (181-209 g/m2), Bond (80-105 g/m2), 1-Sided Coated Thin (70-79 g/m2), 1-Sided Coated 1 (80-105 g/m2), 1-Sided Coated 2 (106-128 g/m2), 1-Sided Coated 3 (129-150 g/m2), 1-Sided Coated 4 (151-180 g/m2), 1-Sided Coated 5 (181-209 g/m2), 1-Sided Coated 6 (210-256 g/m2), 1-Sided Coated 7 (257-300 g/m2), 1-Sided Coated 8 (301-325 g/m2), 1-Sided Coated 9 (326-350 g/m2), 2-Sided Coated Thin (70-79 g/m2), 2-Sided Coated 1 (80-105 g/m2), 2-Sided Coated 2 (106-128 g/m2), 2-Sided Coated 3 (129-150 g/m2), 2-Sided Coated 4 (151-180 g/m2), 2-Sided Coated 5 (181-209 g/m2), 2-Sided Coated 6 (210-256 g/m2), 2-Sided Coated 7 (257-300 g/m2), 2-Sided Coated 8 (301-325 g/m2), 2-Sided Coated 9 (326-350 g/m2), Matte Coated Thin (70-79 g/m2), Matte Coated 1 (80-105 g/m2), Matte Coated 2 (106-128 g/m2), Matte Coated 3 (129-150 g/m2), Matte Coated 4 (151-180 g/m2), Matte Coated 5 (181-209 g/m2), Matte Coated 6 (210-256 g/m2), Matte Coated 7 (257-300 g/m2), Matte Coated 8 (301-325 g/m2), Matte Coated 9 (326-350 g/m2), Textured 1 (80-105 g/m2), Textured 2 (106-128 g/m2), Textured 3 (129-150 g/m2), Textured 4 (151-180 g/m2), Textured 5 (181-209 g/m2), Textured 6 (210-256 g/m2), Textured 7 (257-300 g/m2), Vellum 1 (80-105 g/m2), Vellum 2 (106-128 g/m2), Custom Type
Plain (80-105 g/m2)
Yes
No
Custom Size
No
No
[Paper Type Management Settings]
Details/ Edit
Name, Category, Basis Weight, Size, Finish, Type, Color, 2nd Side of 2-Sided Page, Ppr. Fiber Direction Settings, Adjust Creep Correction, Adjust Saddle Fold Position*1, Adj. Saddle Stitch Fold Pos.*1, Change Fold/Stitch Position*1, Adjust Hole Punch Position, Curl Correction Level, Adj. Fan Level for Paper Sep., Adj. Paper Convey. (2-Sided), Adjust Gloss/Fine Black, Adjust Lead/Tail Margins, Adj. Secondary Transfer Volt., Corr. Tail End Toner Applic., Adj. Antistatic Bias, Adjust ITB Image Clearing, Adj. Sec. Transfer Belt Speed, Toner Amount Reduct. Mode, Adj Ld Edge Sec. Trans. Volt., Adj. Primary Transfer Voltage, Adjust Image Position, Do Not Use Scanner*1, Use Scanner*1, Output Test Page, Lead Edge (e) Align., Left Edge (i) Align., Zoom (f), Zoom (d), Auto Adj. Back Lead Edge Align., Adj Level for Ppr Misalign. Corr., Set Details, Corr. Image Misalignment, Corr. Distort. (Trapezoid), Corr. Distort. (Paralellgrm)
Yes
No
Duplicate, Delete, Paper Database
Yes
No
[Long Multi-Purpose Tray Defaults]*1
On, Off
Register(Paper Size/Paper Type)
Off
No
No
[Register Custom Size]
S1 to S5:
Register/ Edit, Rename
No
Yes
Delete
No
No
Item
Setting Description
Default
Setting |
Can be set in
Remote UI |
Device Information
[Default Screen after Startup/Restoration]
Main Menu, Quick Menu, Copy*1, Scan and Send*1, Scan and Store*1, Access Stored Files, Fax/I-Fax Inbox, Scanner
Main Menu
No
No
Open Status Monitor/Cancel: On, Off
On
No
No
[Default Screen (Status Monitor/Cancel)]
Default Status Type: Job, Paper, Toner/Other
Job
No
No
Status/Log: Job Status, Job Log
Job Status
No
No
Details (Job, Job Status):
Print, Copy*1, Send, Forward |
No
No
Details (Job, Job Log):
Copy*1, Printer, Local Print, Received Job Print, Print Report , Send, Receive |
No
No
[Copy Screen Display Settings]*1
Regular Copy, Express Copy
Regular Copy
No
No
[Store Location Display Settings]
Mail Box: On, Off
On
No
No
[Switch Language/Keyboard On/Off]
On, Off
Off
No
No
[Switch Language/Keyboard]
Language, Keyboard Layout
No
No
[Use Keyboard Shift Lock Feature]
On, Off
Off
No
Yes
[Display Remaining Paper Message]
On, Off
On
No
No
[No. of Copies/Job Duration Status]
On, Off
On
No
No
[Notify to Clean Original Scanning Area]
On, Off
On
No
No
[Change Display of Paper List Screen]
W/ Illustrations, No Illustrations
W/ Illustrations
No
No
[Paper Type Selection Screen Priority]
Simple, Detailed
Detailed
No
No
[Change Default Display for Paper Type List]
Category:
All, Standard Type, Custom Type
All
No
No
Sort:
Reg'd (Asc.), Reg'd (Desc.), Name (Asc.), Name (Desc.), Weight (Asc.), Weight (Desc.)
Reg'd (Desc.)
No
No
[Switch Millimeter/Inch Entry]
mm, Inch
Inch
No
Yes
[ID/User Name Display On/Off]
On, Off
On
No
No
[Display Remaining Toner Error Message]
On, Off
Off
No
No
[Delete Remaining Toner Error]
Yes, No
No
No
[Edit Puncher Unit Die Name]*1
Edit
Yes
No
[Edit Primary Fixing Assembly Name]
Edit
No
No
[Edit Secondary Fixing Assembly Name]
Edit
No
No
*1
Indicates items that appear only when the appropriate optional product is available for use.
Item
Setting Description
Default
Setting |
Can be set in
Remote UI |
Device Information
[Adjust Time]
00:00 to 23:59, in one minute increments
No
No
[Date/Time Settings]
Date and Time Setting (12 digit number)
Yes
No
Time Zone: GMT-12:00 to GMT+12:00
GMT -05:00
Yes
No
Daylight Saving Time: On, Off
Off
Yes
No
Start Date (Month/Day/Time (0 to 23))
March, 2nd, Sunday, 2:00
Yes
No
End Date (Month/Day/Time (0 to 23))
November, 1st, Sunday, 2:00
Yes
No
[Time Format]
24 Hour, 12 Hour
12 Hour
Yes
No
[Auto Reset Time]
0 min=Off, 10 to 50 seconds in 10 second increments, 1 to 9 minutes in one minute increments
2 mins
Yes
Yes
[Restrict Auto Reset Time]
On, Off
Off
Yes
Yes
[Function After Auto Reset]
Initial Function, Selected Function
Initial Function
Yes
Yes
[Auto Sleep Time]
0 sec, 5, 10, 15, 20, 30, 40, 50 mins, 1 hr, 90 mins, 2, 3, 4 hrs
5 min*1
Yes
Yes
[Sleep Mode Energy Use]
Low, High
Low
Yes
Yes
[Auto Sleep Weekly Timer]
Sun to Sat, 00:00 to 23:59, in one minute increments
Yes
Yes
[Time Settings for Auto Adjust Gradation]
No
Yes
[Energy Saver/Sleep Mode Exit Time Settings]
Yes
Yes
[Mode After Energy Saver Key Pressed]
Energy Saver Mode, Sleep Mode
Sleep Mode
Yes
No
[Change Energy Saver Mode]
-0.1, -0.25, -0.5, Zero Restore Time
-0.1
Yes
No
[Low Power Mode Time]
5, 10, 15, 20, 30, 40, 50 mins, 1 hr, 90 mins, 2 hrs, 3 hrs, 4 hrs
15 mins
Yes
No
[Perfect Binder Energy Saver Mode Time]*2
0=Off, 10, 15, 20, 30, 40, 50 mins, 1 hr, 90 mins, 2 hrs, 3 hrs, 4 hrs
15 mins
Yes
No
[End the Perfect Binder Energy Saver Mode]*2
Sync with Main Unit, Do Not Sync w/ Main Unit
Yes
No
*1
It is recommended that you use the default setting for this item. However, if you set priority is given to productivity when you copy or print, set the value in this mode to '0'. If you set to '0', press
to set the machine to enter the Sleep mode or the Energy Saver mode. |
*2
Item
Setting Description
Default Setting
Can be set in Remote UI
Device Information Delivery Available
[Output Report]
Yes, No
Yes
No
Item
Setting Description
Default Setting
[Confirm Network Connection Set. Changes]
On, Off
Off
No
Yes
Item
Setting Description
Default
Setting |
Can be set in
Remote UI |
Device Information
[Use FTP PASV Mode]
On, Off
Off
Yes
Yes
[Use HTTP]
On, Off
On
Yes
Yes
[SSL Settings]
Settings that use SSL
Yes
No
[Key and Certificate]
Set as the Default Key
Yes
No
Certificate Details(Version, Serial Number, Signature Algorithm, Issued To, Validity Start Date, Validity End Date, Issuer, Public Key, Certificate Thumbprint, Verify Cert.)
Yes
No
Display Use Location (Key and Certificate)
Yes
No
[Proxy Settings]
Use Proxy: On, Off
Off
Yes
No
Server Address (IP Address or FQDN)
(NULL)
Yes
No
Port Number: 1 to 65535
80
Yes
No
Use Proxy within the Same Domain: On, Off
Off
Yes
No
[Set Authentication]
Use Proxy Auth.: On, Off
Off
Yes
No
User Name
(NULL)
Yes
No
Password
(NULL)
Yes
No
Item
Setting Description
Default
Setting |
Can be set in
Remote UI |
Device Information
[Key Repetition Settings]
Standard, Slightly Slow, Slow
Standard
No
No
[Reversed Display (Color)]
On, Off
Off
No
No
Some items can be set using the Remote UI. Use the control panel of the device to set items which cannot be set using the Remote UI.
The names may be different on the Remote UI.
