(Settings/Registration). |
[Low]:
Energy consumption in the Sleep mode is low, but it takes longer to recover from the Sleep mode.
[High]:
Energy consumption in the Sleep mode is high, but it takes less time to recover from the Sleep mode.
If Sleep Mode Energy Use is set to 'Low', it may take more than 10 seconds for the touch panel to appear after pressing
(Energy Saver). |
If the energy consumption level is set to 'Low', communication failure may occur, depending on the network utility software you are using. To avoid this, press
(Energy Saver) to cancel the Sleep mode before using the machine.If there are less than 10 minutes remaining before a Delayed Send job is to be sent, the energy consumption level is 'High' even when set to 'Low'.
If you are using a management application to view or manage the settings and status of the machine via the network, the energy consumption level is 'High' even when set to 'Low'.
In the following cases, the energy consumption level in the Sleep mode is 'High' even when the energy consumption level is set to 'Low'.
A job is being processed (including a forwarding, report, and receive jobs, and sending a forwarding done notice).
Any of the following settings are set from the Settings/Registration screen:
*1 If there are more than 10 minutes remaining before the specified time, the machine consumes the same amount of energy as when the energy consumption level is set to 'Low'.
