Cause 1
Printing cannot be performed because the paper has run out.
Remedy
Load paper. (See "Loading Paper.")
Cause 2
The paper drawer is not correctly inserted into the machine.
Remedy
Insert the paper drawer in all the way. (See "Loading Paper.")
Cause 1
The optimal paper size selected with automatic paper selection is not loaded.
Remedy
Load paper of the displayed size.
Cause 2
[Paper Drawer Auto Selection On/Off] is set to 'Off'.
Remedy 1
Manually specify the paper drawer.
Remedy 2
Set [Paper Drawer Auto Selection On/Off] to 'On' for the paper drawer in which the displayed paper size is loaded. (See "Enabling Paper Drawer Auto Selection.")
Cause 3
A paper type not supported by automatic paper selection is loaded.
Remedy 1
Remedy 2
Set [Consider Paper Type] in [Paper Drawer Auto Selection On/Off] to 'Off' when copying. (See "Enabling Paper Drawer Auto Selection.")
Cause
Scanning stopped because an unspecified problem occurred in the feeder.
Remedy
Return the originals to their correct order, place them in the original loading area of the feeder again, and press
(Start). |
Return the originals to their correct order, then press the [Start] key. (The data size of the scanned original exceeded the limit. Settings will be automatically corrected and the originals will be scanned again.)|
Cause
Scanning was canceled because the data size of the scanned originals exceeded the maximum size that the machine can handle.
Remedy
Scan the originals again from the first page. If you still cannot scan the originals, you may be able to resolve the problem by decreasing the setting for [Sharpness] or setting the original type to [Text].
Scanning was canceled because the data size of the scanned original exceeded the limit. Scanning may be possible if sharpness is reduced, or Original Type is set to Text.|
Cause
Remedy
You may be able to resolve the problem by decreasing the setting for [Sharpness] or setting the original type to [Text].
Cause
A mode requiring an original to be placed on the platen glass is set. There is no original on the platen glass.
Remedy
Place the original on the platen glass.
Cause
An original remains on the platen glass.
Remedy
Remove the original remaining on the platen glass, and place the original again.
Cause
There is an original loaded in the feeder and on the platen glass when a mode that cannot scan originals loaded in the feeder is set.
Remedy
Remove the original from the feeder.
Cause
The original scanning area (thin glass strip) is dirty due to dust and grime.
Remedy
Clean the original scanning area of the feeder. (See "Scanned Originals Become Dirty (Manual Feeder Cleaning).")
Cause
The original scanning area of the Duplex Color Image Reader Unit-K1 is dirty due to dust and grime.
Remedy
Clean the original scanning area of the Duplex Color Image Reader Unit-K1. (See "Scanned Originals Become Dirty (Manual Feeder Cleaning).")
Cause
Printing will soon not be possible because the toner of the displayed color is running out.
Remedy
Replace the displayed color's toner cartridge. (See "Replacing the Toner Cartridge.")
Cause
Remedy
Cause
The toner cartridge of the displayed color is not inserted properly.
Remedy
Make sure that the toner cartridge is inserted properly. (See "Replacing the Toner Cartridge.")
Cause
The machine is performing automatic adjustment.
Remedy
Wait a few moments. When the adjustment is complete, printing will automatically resume.
Cause
The machine is performing an automatic adjustment.
Remedy
Please wait for a moment. Color printing resumes automatically when the adjustment is finished.
Cause
Multiple jobs such as print jobs or scan jobs are being executed while performing the scan operation.
Remedy
Wait a few moments for the machine to resume the scan operation.
Cause
The cover of an optional equipment is open.
Remedy 1
Check whether the cover of the POD Deck Lite-C1/POD Deck-D1/Secondary POD Deck-D1 is closed.
Remedy 2
Check whether the cover of the Document Insertion Unit-N1/Paper Folding Unit-J1/Multi Function Professional Puncher-A1/Finisher-AN1/Saddle Finisher-AN2 is closed.
Cause
There are no staples in the staple cartridge of the stapler unit in the Finisher-AN1/Saddle Finisher-AN2.
Remedy
Replace the staple cartridge of the Finisher-AN1/Saddle Finisher-AN2. (See "Replacing the Staple Cartridge (For Optional Products).")
Cause 1
Previous prints remain in the tray.
Remedy
Remove the paper that remains in the tray. Printing will start or resume automatically.
Cause 2
The prints in the output destination of the external finisher are full.
Remedy
Remove the prints from the output destination of the external finisher.
Printing automatically resumes after removing the prints from the output tray. |
Cause
Remedy
Remove the paper that remains in the booklet tray. Printing will start or resume automatically.
Cause
The punch waste tray of the Finisher-AN1/Saddle Finisher-AN2 is full.
Remedy
Empty the punch waste tray of the Finisher-AN1/Saddle Finisher-AN2. (See "Removing Punch Waste (Puncher Unit-BS1/Puncher Unit-BT1).")
Cause
There are no staples in the staple cartridge of the Saddle Finisher-AN2.
Remedy
Replace the staple cartridge of the Saddle Finisher-AN2. (See "Replacing the Staple Cartridge (For Optional Products).")
Cause
The trim waste tray of the Booklet Trimmer-D1/Booklet Trimmer-D1 and Two-Knife Booklet Trimmer-A1 is full.
Remedy
Empty the trim waste tray of the Booklet Trimmer-D1/Booklet Trimmer-D1 and Two-Knife Booklet Trimmer-A1. For more information, see the instruction manual for the Booklet Trimmer-D1 and Two-Knife Booklet Trimmer-A1.
Cause
Output from a previous job remains in the output tray of the Booklet Trimmer-D1/Booklet Trimmer-D1 and Two-Knife Booklet Trimmer-A1.
Remedy
Remove the paper in the output tray of the Booklet Trimmer-D1/Booklet Trimmer-D1 and Two-Knife Booklet Trimmer-A1. For more information, see the instruction manual for the Booklet Trimmer-D1 or Two-Knife Booklet Trimmer-A1.
Cause
The trimm waste tray of the Booklet Trimmer-D1/Booklet Trimmer-D1 and Two-Knife Booklet Trimmer-A1 is not inserted.
Remedy
Insert the trimm waste tray of the Booklet Trimmer-D1/Booklet Trimmer-D1 and Two-Knife Booklet Trimmer-A1. For more information, see the instruction manual for the Booklet Trimmer-D1 or Two-Knife Booklet Trimmer-A1.
Cause
The staple waste tray of the Finisher-AN1 or Saddle Finisher-AN2 stapler unit is full or almost full.
Remedy
Empty the staple waste tray of the Finisher-AN1 or Saddle Finisher-AN2 stapler unit. (See "Removing Staple Waste (Finisher-AN1/Saddle Finisher-AN2).")
Cause
The trim waste tray of the Perfect Binder-E1 is full.
Remedy
Remove the trim waste in the trim waste tray of the Perfect Binder-E1. For more information, see the instruction manual for the Perfect Binder-E1.
Cause
The trim waste tray of the Perfect Binder-E1 is not inserted.
Remedy
Insert the trim waste tray of the Perfect Binder-E1. For more information, see the instruction manual for the Perfect Binder-E1.
Cause
There is no glue in the Perfect Binder-E1.
Remedy
Add glue to the Perfect Binder-E1. For more information, see the instruction manual for the Perfect Binder-E1.
Cause
Output from a previous job remains in the stacker of the Perfect Binder-E1.
Remedy
Remove the paper in the stacker of the Perfect Binder-E1. For more information, see the instruction manual for the Perfect Binder-E1.
Cause
The stacker of the Perfect Binder-E1 is not inserted.
Remedy
Insert the stacker of the Perfect Binder-E1. For more information, see the instruction manual for the Perfect Binder-E1.
Cause
The front covers of the Perfect Binder-E1 are open.
Remedy
Check that the covers of the Perfect Binder-E1 are closed. For more information, see the instruction manual for the Perfect Binder-E1.
Cause
The top cover of the Perfect Binder-E1 is open.
Remedy
Check that the top cover of the Perfect Binder-E1 is closed. For more information, see the instruction manual for the Perfect Binder-E1.
Cause 1
The trimming width of the fore edge is over 1 15/16" (49.5 mm) when you trim with the Perfect Binding mode.
![]() *1 Trimming width (less than 1 15/16" (49.5 mm))
*2 Finishing size
*3 Thickness of the main document
Remedy 1
Change the paper for cover with shorter length in order to set the trimming width less than 1 15/16" (49.5 mm). Measure the thickness of the main document in advance, apply to the following formulas and judge.
(Length of the paper for the cover* - Thickness of the main document) / 2 - Length of the Finishing Size* ≤ 1 15/16" (49.5 mm)
* Horizontal length to the feeding direction.
Remedy 2
Basically, Remedy 1 is priority. However, if you have is no cover paper of other size, change the thickness of the main document to change the trimming width less than 1 15/16" (49.5 mm)
Change the paper for the main document into thick ones.
Add the number of the page of main document.
However, if the thickness of the main document exceeds 1" (25 mm), since another error occurs, cautions are required.
Cause 2
The width of the booklet is over 8 11/16" (221 mm) when you trim without the Perfect Binding mode.
![]() *1 Booklet width upper limit: 8 11/16" (221 mm)
*2 Thickness of the main document
Remedy 1
Change the paper for cover page with shorter length in order to set the booklet width less than 8 11/16" (221 mm). Measure the thickness of the main document in advance, apply to the following formulas and judge.
(Length of the paper for the cover* - Thickness of the main document) / 2 ≤ 8 11/16" (221 mm)
Remedy 2
Basically, Remedy 1 is priority. However, if you have no cover paper of other size, change the thickness of the main document to change the trimming width less than 8 11/16" (221 mm).
Increase the number of the page of the main document.
Cause
The thickness of the main document is over 1" (25 mm).
Remedy
Follow the solutions below to change the thickness of the main document less than 1" (25 mm).
Change the paper for the main document into thin ones.
Reduce the number of the page of the main document.
Before performing perfect bookbinding, we recommend you to check the curl state of a paper.
You need to print out the main document and a cover to the finisher or stacker, and check that curl is within the specified value.
Cause
Since the paper of the printed main document or a cover had curled more than specified value, perfect binding could not be performed.
The specified value are as follows:
![]() *1 Height of curl: Less than +3/8" (10 mm)
*2 Height of curl: Less than -3/8" (10 mm)
*3 Length of curl: More than 1 15/16" (50 mm)
Remedy
Adjust the curl correction level of currently using paper source (See "Curl Correction for Each Paper Deck."), or change the level of curl correction of currently using paper type. (See "Adjusting the Level of Curl Correction.")
If the curl cannot be corrected within the specified range by following the adjustment above, load other paper type into the paper source.
Cause
Prints remain in the tray.
Remedy
Remove the prints remaining in the output tray. Printing automatically resumes.
Cause
The right cover on the front side of the High Capacity Stacker-H1 is open.
Remedy
Close the right cover on the front side of the High Capacity Stacker-H1. For more information, see the instruction manual for the High Capacity Stacker-H1.
Cause
The left cover on the front side of the High Capacity Stacker-H1 is open.
Remedy
Close the left cover on the front side of the High Capacity Stacker-H1. For more information, see the instruction manual for the High Capacity Stacker-H1.
Cause
The top cover of the High Capacity Stacker-H1 is open.
Remedy
Close top cover of the High Capacity Stacker-H1. For more information, see the instruction manual for the High Capacity Stacker-H1.
Cause
A paper jam or other error has occurred in the external finisher.
Remedy
See the instruction manual for the external finisher.
Remove the prints when a paper jam occurs.
If the message appears on the display, you cannot submit a job which requires the external finisher.
Cause
Processing a job was stopped due to a problem with the external finisher.
Remedy
Check the external finisher.
For more information, see the instruction manual for the external finisher.
If the message appears on the display, you cannot submit a job.
Cause
The entered Department ID or PIN is incorrect.
Remedy
Contact the System Manager for the department to find out the Department ID/PIN.
Cause
The hard disk is damaged or is not attached.
Remedy 1
Contact your local authorized Canon dealer.
Remedy 2
If the Removable HDD Kit is attached, check the hard disk.
Cause
The replacement time for the displayed cleaning web unit is due.
Remedy
Prepare a cleaning web unit. (See "Consumables.")
Cause
The cleaning web of displayed number is low. Printing will become not possible soon.
Remedy
Prepare a cleaning web unit. When printing a large amount, it is recommended to replace the cleaning web unit. (See "Replacing Cleaning Web Unit.")
Cause
The waste toner will be full soon.
Remedy
Prepare the waste toner container for replacement.
Cause
Printing will not possible soon because the waste toner container is full.
Remedy
Replace the waste toner container. (See "Replacing the Waste Toner Container.")
The puncher unit die needs to be lubricated. Follow the instructions in the manual to lubricate the die, then remove the warning about lubrication.|
Cause
The Multi Function Professional Puncher-A1 die needs to be lubricated.
Remedy
Follow the instruction manual for the Multi Function Professional Puncher-A1 to lubricate the die, and then press [Remove Warning] to remove the warning about lubrication.
