      0WR6-0CR
      Managing Stored Files
      You can use the Remote UI to print, send, or delete files that are stored in the Mail Box, or faxes and I-faxes that are temporarily stored in the Fax/I-Fax Inbox.
      Managing Files Stored in a Mail Box
      You can print or send documents that are stored in a Mail Box. You can also edit stored documents by deleting specific pages.
      1
      Start the Remote UI. Starting the Remote UI
      2
      Click [Access Received/Stored Files] on the portal page. Remote UI Screen
      3
      On the [Mail Box] page, click the number of the desired Mail Box.
      If the page for entering a PIN is displayed, enter the PIN and click [OK].
      You can also specify a Mail Box by entering its number in [Box Number (00-99)] and clicking [Open...].
      4
      Specify the file to manage, and perform the desired operation.
      You can click the [Type] icon or file name to display the file details.
      You can click [Print List] to print a list of the files in the Mail Box.
      Printing a file
      Sending a file
      Merging multiple files into one
      Inserting a file into another file
      Duplicating a file in another Mail Box
      Changing a file name
      Deleting pages from a file
      Deleting a file
      To change the settings of a Mail Box
      You can click [Set] on the screen displayed in step 3 to change the name and PIN for the selected Mail Box. Specifying the Mail Box Settings
      Managing Documents Temporarily Stored in Memory RX Inbox
      You can print or forward faxes and I-faxes that are temporarily stored in the Memory RX Inbox using Memory Lock.
      1
      2
      3
      Select [Memory RX Inbox] and click [Memory RX Inbox].
      4
      Select the document and perform the desired operation.
      Click the [Type] icon to display detailed information about the document.
      Printing a document
      Forwarding a document
      Deleting a file
      To check I-faxes that were divided when received
      Click [Divided Data RX Inbox] on the screen displayed in step 2 to display a list of I-faxes that were divided when received. Receiving I-Faxes
      To set a PIN for Memory RX Inbox
      You can change the PIN for the Memory RX Inbox by clicking [Set] on the screen displayed in step 3 and adding a check mark to [Set PIN].
      To configure Memory Lock settings
      You can set whether to receive faxes and I-faxes in the Memory RX Inbox by clicking [Memory Lock Settings] on the screen displayed in step 3.
      Managing Documents Temporarily Stored in Confidential Fax Inbox
      You can print or delete faxes and I-faxes that are temporarily stored in the Confidential Fax Inbox.
      1
      2
      3
      Select [Confidential Fax Inbox] and click the number of the desired Confidential Fax Inbox.
      You can also specify a Confidential Fax Inbox by entering its number in [Box Number (00-49)] and clicking [Open...].
      4
      Printing a document
      Deleting a file
      To change the settings of a Confidential Fax Inbox
      You can change the name and PIN for the selected Confidential Fax Inbox by clicking [Set] on the screen displayed in step 3.
