      0WR6-093
      Specifying the Mail Box Settings
      You can set a password and name for the Mail Box as well as change the period of time before files are automatically deleted.
      1
      Press .
      2
      Press <Function Settings>  <Store/Access Files>  <Mail Box Settings>  <Set/Register Mail Boxes>.
      3
      Select the desired box.
      4
      Specify the settings necessary and press <OK>.
      <Register Box Name>
      Enter a name for the box.
      <PIN>
      Set a password for the box. Enter a number of up to seven digits, press <Confirm>, enter the same password, and then press <OK>.
      IMPORTANT:
      Passwords with only "0" are not allowed.
      If you forget your password, there is no way to retrieve it. Be careful not to forget the password.
      <Time Until File Auto Delete>
      Press <->/<+> to change the period of time until saved files are automatically deleted. When set to "0," files will not be deleted.
      <URL Send Settings>
      Notifies you by e-mail of the location (URL) of the box where files are saved. This setting is helpful for checking saved files from the Remote UI screen.
      <Initialize>
      Restores all the settings to the factory default values. Note that you cannot initialize the settings when files are stored in the box.
      <Print When Storing from Printer Driver>
      Specify whether to print a file when it is sent from a computer and saved in the box.
      <Time Until File Auto Delete> and <Print When Storing from Printer Driver> can be specified for all boxes at the same time. <Settings for All Mail Boxes>
