      0WR6-06H
      Receiving I-Faxes
      When an I-fax is received
      The [Processing/Data] indicator on the control panel blinks green. When receiving is complete, the document is automatically printed and the indicator turns off.
      To cancel receiving, press   <Receive>  <Job Status>  select a document  <Cancel>.
      If a received I-fax is divided, the data finished being received is printed when 24 hours pass after the start of the reception, and the subsequent data is deleted. You can change the time as necessary. <Set Fax/I-Fax Inbox>  <Divided Data RX Timeout>
      Output paper
      An incoming I-fax is printed on the same size of paper as the document size received. When there is no paper matching the size of the received document, the document is printed according to the setting of <Select Drawer>. <Common Settings>  <Select Drawer>
      To receive I-faxes manually
      Press   <Receive>  <Job Log>  <Check I-Fax RX>. On the Main Menu (<Main Menu> Screen), pressing <Fax/I-Fax Inbox>  <Memory RX Inbox>  <Divided Data RX Inbox> enables you to check the receiving statuses of I-faxes divided and their data size.
      TIPS
      You can save paper when printing.
      You can include information, such as reception time, in received documents when printing. <Common Settings>  <Print RX Page Footer>
