      0WR6-0HS
      <Set Fax/I-Fax Inbox>
      You can specify the settings for the Confidential Fax Inbox and the Memory RX Inbox.
      Item
      Description
      <Set/Register Confidential Fax Inboxes>
      You can assign a name for each Confidential Fax Inbox as well as set a password.
      IMPORTANT:
      Since there is no way to check a registered password, make sure that you write down the password that you enter, and keep it in a safe place.
      Setting Value
      <Register Box Name>: Enter a box name.
      <PIN>: Enter a password.
      <URL Send Settings>: Select a destination from the Address Book.
      <Initialize>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      Can be set in the Remote UI: Yes
      Device Information Distribution Available: No
      <Memory RX Inbox PIN>
      You can set a password for the Memory RX Inbox.
      IMPORTANT:
      DeviceAdmin: Yes
      NetworkAdmin: No
      <Use Fax Memory Lock>
      You can select whether to save incoming faxes in the Memory RX Inbox of the machine without printing (Memory Reception). This function enables you to check saved documents before printing or deleting them from the Memory RX Inbox. Saving Received Documents in the Machine (Memory Reception)
      Setting Value
      <On>, <Off>
      DeviceAdmin: Yes
      NetworkAdmin: No
      <Use I-Fax Memory Lock>
      You can select whether to save incoming I-faxes in the Memory RX Inbox of the machine without printing (Memory Reception). This function enables you to check saved documents before printing or deleting them from the Memory RX Inbox. Saving Received Documents in the Machine (Memory Reception)
      Setting Value
      <On>, <Off>
      DeviceAdmin: Yes
      NetworkAdmin: No
      <Memory Lock Start Time>
      You can specify the time to activate the Memory Reception function. The machine will automatically switch to the Memory Reception mode at the specified time.
      Setting Value
      <Everyday>, <Specify Days>, <Off>
      DeviceAdmin: Yes
      NetworkAdmin: No
      Device Information Distribution Available: Yes
      <Memory Lock End Time>
      You can specify the time to deactivate the Memory Reception function. The machine will automatically cancel the Memory Reception mode at the specified time.
      Setting Value
      DeviceAdmin: Yes
      NetworkAdmin: No
      <Divided Data RX Timeout>
      If a received I-fax is divided, the data finished being received is printed when the time specified here passes after the start of the reception, and the subsequent data is deleted.
      Setting Value
      0 to 24 to 99 hr.
      NOTE:
      If you delete divided data, it cannot be combined to form a complete document, even if the remaining divided data is received later.
      Divided data cannot be printed as a regular image unless it has been combined.
      DeviceAdmin: Yes
      NetworkAdmin: No
      <Forward Temporarily Stored File to Memory RX Inbox>
      You can set the machine so that unprinted documents due to paper jams or lack of paper can be forwarded to the Memory RX Inbox of the machine. Forwarded documents can be printed later. Saving Received Documents in the Machine (Memory Reception)
