      0WR6-0LU
      Printing Reports and Lists
      You can print reports and lists to check information such as the total number of copied pages, communication results, and machine settings.
      Printing a Report on the Number of Copied and Printed Pages
      Counter Report
      You can print a report to check the total number of all copied and printed pages, as well as the total number of scanned pages and faxed pages.
      Page Count List
      You can print a list to check the total number of pages* that were copied, printed, and scanned for each Department ID. To print this list, you need to log in with Administrator privileges. Logging into the Machine
      * In this report, the numbers are based on copied or printed sides of the page. For example, the count is 1 if you print on one side of a page, and the count is 2 if you print on both sides of the page.
      Printing a List of Usage History
      When you press , the <Status Monitor/Cancel> screen appears, allowing you to check the usage history for each function. From this screen, you can also print the usage history for each function, such as copying, printing, or sending e-mail.
      If "NG" is displayed in the printed list, printing, communicating, or saving scanned documents may have failed. Check the three-digit number preceded by "#" in the printed list to find the reason and solutions. When a Number Preceded by "#" (Error Code) Appears
      If you press   <Management Settings>  <Device Management>, and set <Restrict Access to Other User Jobs> to <On>, jobs other than those of the logged-in user are displayed as "***" and cannot be performed. If you log in with Administrator privileges, the jobs of all users are displayed.
      1
      Press .
      2
      Display the usage history of each function and print a list.
      Copy/print log
      Sending/receiving log
      Fax sending/receiving log
      Storage log
      Printing a Communication Result Report
      You can print a list of results for sending/receiving fax, e-mail, or I-fax, and results for storing items in the file server or Mail Box (machine's temporary storage space). A report is set to be printed automatically or printed only when an error occurs. However, you can change the setting to print only at a specified time or not to print at all.
      Communication Management Report
      You can configure the machine to automatically print the report when the specified number of communication results, including sent or received faxes, e-mails, and I-faxes, as well as items saved in the file server or Mail Box (machine's temporary storage space), is reached. You can also configure the setting to print the report at a specified time.
      TX Report
      You can configure the machine to automatically print the report for sending results, including sent faxes, e-mails, and I-faxes, as well as items saved in the file server or Mail Box (machine's temporary storage space). You can also configure the setting to print the report only when an error occurs. You are required to log in with Administrator privileges to print this report.
      Fax Activity Report
      You can configure the machine to automatically print the report when the specified number of sent and received faxes is reached. You can also configure the setting to print the report at a specified time.
      Fax TX Report
      You can configure the machine to automatically print the report each time a fax is sent. You can also configure the setting to print the report only when an error occurs.
      Fax RX Report
      You can set a Fax RX Report to print automatically every time a fax is received. It is also possible to set the report to print only when an error occurs.
      Confidential Fax Inbox RX Report
      You can configure the machine to automatically print the report when a received fax is saved in the Confidential Fax Inbox. You can also configure the setting so that the report is not printed.
      Printer Report
      You can print and check the information of a printer driver, such as the font list and status.
      Device Information Communication Log Report
      You can configure the machine to automatically print the report when the specified number of results for device information distribution or reception is reached. You can also configure the setting to print the report at a specified time. You are required to log in with Administrator privileges to change the report setting.
      Printing List of Setting Items
      Information and settings registered in the machine such as registered destinations, send/receive settings, fax settings, forwarding conditions, files in a Mail Box, etc. can be printed as a list.
      Address Lists
      You can print a list of destinations registered in the Address Book or in one-touch buttons.
      TX/RX User Data List
      You can print a list of the send/receive settings configured for <Send> and <Receive/Forward> in the setting menu.
      Fax User Data List
      You can print a list of the fax settings configured for <Send> and <Receive/Forward> in the setting menu.
      Forwarding Settings
      You can print a list of the fax/I-fax forwarding settings configured for <Receive/Forward> in the setting menu. You are required to log in with Administrator privileges to print this list.
      Mail Box File List
      You can print a list of temporarily saved files in a Mail Box on the machine.
      Network Setting List
      You can print a list of the settings configured for <Network> in <Preferences> in the setting menu.
      System Information list
      You can print a list of information such as MEAP applications and licenses. You are required to log in with Administrator privileges to print this list.
      Device Information Distribution Destination List
      You can print a list of devices registered as information distribution destinations. You are required to log in with Administrator privileges to print this list.
      LDAP Server Registration List
      You can print a list of LDAP server settings registered in the machine. You are required to log in with Administrator privileges to print this list.
      IPSec Policy List
      You can print a list of IPSec policy settings registered in the machine. You are required to log in with Administrator privileges to print this list.
