and
and press <Details>. To delete a destination from the specified destinations, press <Delete Dest.>.
<Remote>.
Destination type buttons
and
displays fax and group destinations, respectively.
Drop-down list for selection of Address Book types
<Search by Name>
Search buttons by first letter|
If you select the group destination containing destinations other than fax destinations, sending a fax is not allowed.
and enter the number for the desired one-touch button.
<PIN Code Access>|
To send faxes overseas
Enter the international access number, the country code, and the fax number, in that order. If you cannot successfully connect to the destination overseas, press <Pause> to insert a pause between a number and the next number.
To send faxes with a subaddress
The machine supports the use of ITU-T* standard subaddresses. If the recipient's fax machine is compatible with the use of ITU-T subaddresses, you can enhance the confidentiality of sent documents using a subaddress and password. To send a document with a subaddress, enter a fax number, press <Subaddress> or <Set Details>, and then enter the subaddress and password.
* Stands for International Telecommunication Union-Telecommunication Standardization Sector, which is the group that makes recommendations towards the standardization of worldwide telecommunications.
<LDAP Server>.
Search categories
Search conditions
Search characters
If you are scanning free size/highly transparent documents, or the edge of documents is missing when scanning, you need to manually specify the scanning size.
Specifying the Scanning Size of Documents
The machine can automatically scan both the front and back sides of a document.
Scanning Both Sides of Documents
You can scan two facing pages in a book or magazine onto separate pages in one operation.
Splitting Facing Page Documents into Separate Pages for Faxing
When scanning a free size document
When specifying the values of scanning size
When scanning a long document|
To register the scanning size
If you frequently specify the scanning size with the same values, register the size in <Custom>
<Register Size> to quickly recall the setting for convenience. |
<2-Sided Original>.
When scanning facing page documents, place them on the platen glass. Place the document face down with its corner aligned with the top-left corner of the platen glass, as shown below.
<Book
You can select the resolution suitable for your document type. The higher the resolution is, the clearer the image becomes, but the longer it takes to send.
Selecting Resolution
Specifying the document type such as documents with characters only or magazines with photographs enables you to send with optimal image quality.
Selecting Document Type
You can adjust the density of the entire document. For example, increasing the density enables you to easily read faint characters written in pencil.
Adjusting the Density of the Entire Document
You can adjust the density of the background. You can clearly send documents with a colored background or thin documents such as newspapers whose characters and images on the back side are transparently visible.
Adjusting the Density of the Background
You can scan the image with clear contours and lines by increasing the sharpness, or soften the image by decreasing the sharpness. Use this function when you want to sharpen blurred text and diagrams, or to reduce moire (a shimmering, wavy pattern) to smoothen the finished image.
Adjusting Sharpness (Sharpness)
<Original Type>.
<Density>.
to decrease the density. Press
to increase the density.
<Density>.
<Function Settings>
<Common>
<Scan Settings>
<Speed/Image Quality Priority for B&W Scan>
<Quality Priority>
<Close>.
<Sharpness>.
You can enlarge or reduce standard size documents to other standard sizes when scanning.
Enlarging or Reducing in Standard Paper Sizes
You can enlarge or reduce by specifying magnification (%).
Enlarging or Reducing by Specifying Magnification
<Copy Ratio>.
, to reduce, select magnification from
and press <OK>.
<Copy Ratio>.
Place the document with punch holes on the platen glass. Placing in the feeder may result in damage.
<Erase Frame>.
Erasing the frames of documents|
1
Press <Erase Original Frame> and check <Original Size>.
![]() If the size displayed in <Original Size> is different from the size of the document you check, press <Change> to select the size.
2
Enter the width of the frame to erase.
Erasing dark borders of books|
1
Press <Erase Book Frame> and check <Original Size>.
![]() If the size displayed in <Original Size> is different from the size of the book you check, press <Change> to select the size.
2
Press <Center> or <Sides> and enter each erasing width.
Erasing punch holes in documents|
1
Press <Erase Binding> and select the punch hole location.
2
Enter the erasing width.
If you want to adjust the width for each border independently, press <Erase Original Frame> or <Erase Book Frame>, and then press <Adjust Independently> to enter the erasing widths.
<Close>.
<Yes>.
When <Press the [Start] key to scan the next original.> is displayed
. When scanning all of the documents is complete, press <Start Sending> to send the fax.
select a document
<Cancel>
<Yes>.|
To send with the sender information
You can send with the sender's name and fax number. <Common Settings>
<TX Terminal ID>To check the statuses for sent documents
On the <Status Monitor/Cancel> screen, you can check the statuses for sent documents. This screen enables you to send faxes again or cancel sending after checking the statuses. Checking Status and Log for Sent and Received Documents
When a transmission error occurs because the recipient's line is busy
The machine automatically redials after a certain period of time. You can change the settings such as how many times the machine redials and the interval between redials. <Fax Settings>
<Auto Redial>To print the report for the results of sending
On the Fax Basic Features screen, pressing <Options>
<TX Report> enables you to set to automatically print the report listing the results of sending.When multiple sheets are fed
Scanning is stopped and the message is displayed on the screen. Follow the message and start operation. To set to not notify with a message, press <Options> on the Fax Basic Features screen
<Detect Feeder Multi Sheet Fd.> each time you send a document to disable the setting, or set <Set Detection of Feeder Multi. Sheet Feed as Default> to <Off> (<Scan Settings> <Set Detection of Feeder Multi. Sheet Feed as Default>). |
TIPS
Saving a copy of a sent document
You can set the machine so that a copy of a sent document is automatically saved in a file server. The copy is converted into an electric file such as PDF and saved, allowing you to easily check the contents from your computer. Saving a Copy of a Sent Document
Selecting a sender's name
On the Basic Fax Features screen, pressing <Options>
<Sender Name (TTI)> enables you to select a name from a list of registered sender's names to include in the sender information. <Fax Settings> <Register Sender Name (TTI)>Checking scanned documents before sending
You can check scanned documents on the preview screen before sending.Checking Scanned Documents Before Sending (Preview)
Registering frequently used settings
You can combine frequently used destinations and scan settings into a button of the machine for later use. By pressing the registered button when scanning documents, you can quickly complete your settings. Registering Frequently Used Fax Settings
