Combining Jobs with Different Settings Into a Single Job (Merge Job Blocks)
You can scan multiple originals with different settings, and then combine the jobs into a single job and print it out. For example, scan one original document with the Hole Punch setting and another original document with the 2-sided setting, after that, you can combine these documents into a single job and add page numbers or attach covers to the whole output.
1
Press <Copy>.
2
Press <Options> on the Copy Basic Features screen. Copy Basic Features Screen
3
Press <Merge Job Blocks>.
4
Specify settings that are applied to all of the documents and press <OK>.
To configure <Finishing>, see Basic Copy Operations.
To configure <Job Separator>, see <Paper Output Settings> <Job Separator Between Jobs> or <Job Separator Between Copies>.
To configure <Secure Watermark>, <Document Scan Lock>, see Restricting Copying of Confidential Documents.
To configure <Page Numbering>, <Copy Set Numbering>, <Watermark>, <Print Date>, see Functions Useful for Making and Managing Material.
To configure <Job Done Notice>, <Store in Mail Box>, see Useful Copy Functions.
5
Place the first original, configure settings on the Copy Basic Features screen, and press .
Scanning starts. When scanning is complete, the screen appears prompting you to scan the next original.
If you want to keep the setting specified in this step for the next original, proceed to step 7.
If you want to change some of the settings such as copy ratio or density for the next original, press <Change Settings> on the screen, change the settings, and proceed to step 7.
6
Press <Scan Settings of Next Block>.
7
Place the next original, configure settings on the Copy Basic Features screen and press .
Repeat steps 6 and 7 for the originals you want to combine.
To apply the last setting you used to the original, place the original and press .
8
Press<Check/Merge All Blocks>.
9
Enter the number of copies and confirm the settings for the scanned documents.
<No. of Prints>
Enter the number of copies using the numeric keys.
<Check Overall Settings>
You can check the settings specified in step 4.
List of scanned documents
Displays the information of the scanned documents as a list.
The number in appears as 1, 2, 3... in the order that the documents are scanned, and the copies are printed order. If you want to change the order, press <Clear Selection> in  and specify the order.
<Add Cover>/<Insert Sheets>
You can include covers and insert sheets (chapter pages).
Adding a Cover and Back Cover
Inserting Sheets and Chapter Pages (Insert Sheets)
<Edit & Adjust>
You can preview pages, or delete specific pages or jobs.
<Add Originals>
You can scan more originals to add to the output.
<Add from Mail Box>
You can call documents from the Mail Box to add to the output. Making Simple Edits to Files
<De- tails>
When selecting documents in , <De- tails> is displayed. You can confirm the settings for each document.
<Print Sample>
You can print a copy sample to check the result before making a large amount of copies. Checking the Copy Results
<Clear Selection>/<Select All>
You can change the document order in .
10
Press <Start Printing>.
Copying starts.
13WJ-051
