Copy Basic Features Screen
Pressing <Copy> on the Main Menu displays the Copy Basic Features screen.
Current setting status and setting buttons
Displays setting status such as the copy ratio, paper size, and number of copies. Make sure to confirm the settings in order to copy properly. To change the settings, press the button under the display section.
Basic Copy Operations
Depending on the number of copies and settings, <Copy Sample> is displayed to check the copy result by printing a sample copy.
Checking the Copy Results
<Check Settings>
You can check the settings in the list. You can also make changes to the settings.
![](./images/book_images/b_in_C0000_03.gif)
![](./images/book_images/pubnumbers/003_02_flk33_en_US/b_in_btn_C0003_29.gif)
Press this icon to register the current settings in <Favorite Settings> of
![](./images/book_images/b_in_C0000_05.gif)
or to change the buttons displayed in
![](./images/book_images/b_in_C0000_06.gif)
<Previous Settings>
<Favorite Settings>
Register frequently used copy settings here in advance to easily recall them when necessary.
Registering a Combination of Frequently Used Functions
Function setting buttons
Displays the most frequently used buttons from <Options>. The setting status is displayed on the buttons. You can also press
to change which buttons are displayed.
If the button for the function that you want to use is not displayed, press <Options> and select the desired button.
<Options>
Displays all of the function setting buttons. For convenience, you can display frequently used function setting buttons in
<Interrupt>
You can interrupt waiting copy jobs and make your copy immediately.
Copying Immediately by Interrupting Other Jobs
Some functions cannot be used in combination with each other. Buttons that cannot be selected are displayed in light gray.
