Placing Originals
Place your originals on the platen glass or in the feeder. For originals such as books and thick/thin paper which cannot be loaded in the feeder, place the original on the platen glass. If you want to scan 2-sided originals or continue to scan several sheets of originals, place them in the feeder. For more information about the types of originals that can be placed on the platen glass or in the feeder, and information about the scannable area of an original, see
Specifications.
Use originals that are completely dry
When placing originals, make sure that any glue, ink, or correction fluid on the originals has completely dried.
To avoid paper jams
Do not place the following types of originals in the feeder as this may cause paper jams:
Wrinkled or creased paper
Carbon paper or carbon-backed paper
Curled or rolled paper
Coated paper
Torn originals
Originals with large holes
Onion skin or thin paper
Stapled or clipped originals
Paper printed by a thermal transfer printer
Transparencies
To scan originals more accurately
Originals placed in the feeder are scanned while being fed into the machine. On the other hand, originals placed on the platen glass remain in a fixed position while they are scanned. To ensure more accurate scanning results, placing originals on the platen glass is recommended.
To scan tracing paper or transparencies
To scan transparent originals (for example, tracing paper or transparencies), place them on the platen glass and cover them with plain white paper.
Placing Originals on the Platen Glass
1
Open the feeder/platen cover.
If you place an original for which the opening of the feeder/platen cover is insufficient, the size of the original may not be properly detected.
2
Place the original face down on the platen glass.
Align the corner of the original with the top-left corner of the platen glass.
When copying 2-sided original, place the original so that the top and the bottom are properly positioned, as shown in the illustration below.
3
Gently close the feeder/platen cover.
The original is ready for scanning.
When scanning is complete, remove the original from the platen glass.
Placing Originals in the Feeder
1
Spread the slide guides apart.
Move the slide guides outward until they are slightly farther apart than the actual width of the original.
When placing large-sized originals, pull out the original supply tray extension and original output tray extension to prevent them from dropping over the edge of the feeder.
2
Fan the original stack and align the edges.
Fan the original stack in small batches, and align the edges by lightly tapping the stack on a flat surface a few times.
3
Place the originals face up in the feeder.
Make sure that the original stack does not exceed the load limit lines (
). If you place originals that exceed the limit, they may not be scanned or may cause a paper jam.
Always smooth out any folds in your originals before placing them into the feeder. If the original is folded, an error screen may be displayed because the size of originals cannot be detected correctly.
Thin originals may become creased, if used in a high temperature or high humidity environment.
4
Align the slide guides against the edges of the original.
Move the slide guides inward until they are aligned securely against the edges of the original.
Originals are ready for scanning.
Align the slide guides securely against the edges of the original
Slide guides that are too loose or too tight can cause misfeeds or paper jam.
While originals are being scanned
Do not add or remove originals.
Remove the scanned originals from the original output tray to prevent paper jams. If originals are remained, the original output indicator blinks when you place originals for another job in the feeder.
When scanning long strip originals
If you scan long originals (which have a length of up to 24 7/8" (630 mm)), support the originals by hand when scanning and outputting paper.
When placing thin paper originals
It may be difficult to place thin paper originals. In this case, lightly bend the paper while placing it.
Make sure that you do not push too hard when placing the original. The original may not be fed correctly, or may cause a paper jam.
When you place thin 11" x 17" or LTRR originals into the feeder, lift up the Original Stopper to prevent scanned originals from creasing.
When repeatedly scanning the same original
It is recommended that you do not repeatedly scan the same original more than five times (this varies depending on paper quality). The original may fold or become wrinkled, or become difficult to send.
