Mail box list
Mail box with files saved
Mail box with no files saved
Mail box with passwords set Specifying the Mail Box Settings
<Used>
<Up>
Mail box information
Files saved in the box
Total number of files and number of selected files
<Print List>
<Print>
<Send>
<Edit File>
<Display Image>
<De- tails>
<Select All (Max 100 Files)>/<Clear Selection>
, <Select All (Max 100 Files)> is displayed. If one or more files are selected, <Clear Selection> is displayed. Press <Select All (Max 100 Files)> to select up to 100 files in the box at the same time or <Clear Selection> to deselect them.
Display switch button
To change a file name
1
Select a file and press <Edit File>
<Change File Name>. |
2
Enter a file name and press <OK>.
To display the preview image of a file
1
Select a file and press <Display Image>.
2
After checking the preview image, press <Back>.
To print the file, press <Print>.
To check the detailed information of a file
1
Select a file and press <De- tails>.
2
After checking the detailed information, press <OK>.
To delete a file
1
<Delete>. |
2
Press <Yes>.
To scan and save documents
1
Set the original. Placing Originals
2
Press <Edit File>
<Add Files (Scan and Store)>. |
3
Specify the scan settings as necessary and press
.For scan settings, see Setting Screen and Operations for Scanning to Save.
To move/duplicate files to another box
1
<Move/Duplicate>. |
2
Press <Mail Box>.
3
Select the box and press <Move> or <Duplicate>.
When a file is duplicated, the file name will be the same as that of the original file.
To combine multiple files into one file
1
Select the files to combine, and press <Edit File>
<Merge Multiple Files>.The files are combined in the order they are selected.
2
Enter a file name.
Press <File Name>, enter the name, and press <OK>.
![]() If you do not specify anything, the saved date and time is automatically assigned as a file name. For example, if a file is saved at 1:05:12 p.m. on October 30, 2015, its name will be "20151030130512."
3
Press <Start Merging>.
All the print settings for each file are canceled, and the settings registered in <Change Default Settings> are applied to a new file. <Access Stored Files Settings>
<Change Default Settings> |
To insert a file into another one
1
Select the file where you want to insert another file, and press <Edit File>
<Insert Pages>. |
2
Specify the file to insert and the position to insert it, and press <Next>.
![]() Enter the page number where you want to insert the file using the numeric keys.
3
Enter a file name.
Press <File Name After Insertion>, enter the name, and press <OK>.
4
Check the page order and press <Start Inserting>.
To delete pages
1
<Delete Page>. |
2
Specify the pages to delete.
![]() To delete only one page, press <Single Page> and enter the corresponding page number.
To delete multiple pages at the same time, press <Multiple Pages>
<First Page> or <Last Page> and enter the corresponding page numbers. |
3
Press <Start Deleting>
<Yes>. |
