<Store/Access Files>
This section describes the settings for storing scanned documents and printing stored files.
<Register/Edit Favorite Settings>
<Function Settings>
<Common Settings>
<Scan and Store Settings>
You can register frequently used settings in a button of the machine for later use when saving. You can also assign your favorite name to a button and check registered settings.
Registering a Combination of Frequently Used Functions
<Change Default Settings>
<Function Settings>
<Common Settings>
You can change the settings registered as default for the <Scan and Store> function.
<Function Settings>
<Common Settings>
<Access Stored Files Settings>
You can register frequently used settings in a button of the machine for later use when printing. You can also assign your favorite name to a button and check registered settings.
<Function Settings>
<Common Settings>
You can change the settings registered as default for the <Access Stored Files> function.
<Limit Box PIN to 7 Digits/Restrict Access>
<Function Settings>
<Common Settings>
If you set this setting to <On>, users are forced to set a seven-digit PIN, thus enhancing security. The PIN for User Inboxes can set using at least one digit.
<Set/Register Mail Boxes>
<Function Settings>
<Mail Box Settings>
You can set a PIN and name for a box as well as specify the period of time before files in a box are automatically deleted.
Specifying the Mail Box Settings
<Time Until File Auto Delete>
<Function Settings>
<Mail Box Settings>
<Settings for All Mail Boxes>
You can specify the period of time before files in boxes are automatically deleted.
<Print When Storing from Printer Driver>
<Function Settings>
<Mail Box Settings>
You can select whether to print a file upon saving from a computer.
<Display Print When Storing from Printer Driver>
<Function Settings>
<Mail Box Settings>
<Box Security Settings>
If you set this setting to <Off>, the settings for <Print When Storing from Printer Driver> cannot be changed.
<Unified Advanced Box Settings>
<Function Settings>
<Advanced Box Settings>
You can batch specify the settings necessary to use the Advanced Box.
Setting Advanced Box to Public
<Open to Public>
<Function Settings>
You can specify how to open the Advanced Box to the public. The machine can be opened externally as either an SMB or WebDAV server.
<WebDAV Server Settings>
<Function Settings>
You can specify the security settings to use when opening the machine externally as a WebDAV server.
<Allow to Create Personal Space>
<Function Settings>
You can select whether to allow a Personal Space to be created in the Advanced Box.
<Delete All Personal Spaces>
<Function Settings>
You can delete all Personal Spaces in the Advanced Box.
<Initialize Shared Space>
<Function Settings>
You can delete all folders and files stored in the Shared Space of the Advanced Box.
<Prohibit Writing from External>
<Function Settings>
For users that accessed the machine via a computer or another imageRUNNER ADVANCE series machine, you can select whether to prohibit those users from creating a folder or saving a file in the Advanced Box opened externally.
Even if this setting is set to <On>, you can send to the Advanced Space of the machine using <Scan and Send> if you specify the address of the machine on the network (the loopback address). Specify the following IP address and host name for the loopback address.
IPv4: 127.0.0.1
IPv6: 0:0:0:0:0:0:0:1 or ::1
Host name: localhost\
<Authentication Management>
<Function Settings>
You can select whether to manage the authentication of users who access the Advanced Box. To allow a Personal Space to be created, you need to set this setting to <On>.
<File Formats Allowed for Storing>
<Function Settings>
You can set the file formats allowed for saving in the Advanced Box.
<Save Operation Log>
<Function Settings>
You can select whether to create operation logs for the Advanced Box. If you have operation logs performed to the Advanced Box, you can check and trace the recorded user operations using the Remote UI. In addition, the logs can be saved to a computer in the CSV format.
Managing the Logs
<Network Place Settings>
<Function Settings>
<Network Settings>
You can register the Advanced Box of another imageRUNNER ADVANCE series machine or a Windows server as an external reference.
Connecting to the Other Devices
<Protocol for External Reference>
<Function Settings>
<Network Settings>
You can select the protocol to use when accessing the Advanced Box of another imageRUNNER ADVANCE series machine or a Windows server which is opened externally.
<Confirm TLS Certificate for Network Access>
<Function Settings>
<Network Settings>
You can confirm whether the TLS server certificate is valid when accessing the Advanced Box of another imageRUNNER ADVANCE series machine or a Windows server. You can verify the validity of the certificate and reliability of the certificate chain, as well as confirm the CN (Common Name).
<Use Scan/Print Function>
<Function Settings>
<Memory Media Settings>
Specifying this setting enables you to save documents stored in memory media, as well as print files in memory media.
Restricting the Use of Memory Media
