<Network>
This section describes the network settings.
<Output Report>
You can print the settings in <Network>.
Printing a List of Settings
<Confirm Network Connection Setting Changes>
If this setting is set to <On>, you can use it with a network environment. If errors related to network connections occur, an error message appears on the touch panel display of the machine.
Canceling the Network Setting Lock
<Use IPv4>
<Preferences>
<Network>
<TCP/IP Settings>
<IPv4 Settings>
Set whether to use IPv4.
Setting an IPv4 Address
<IP Address Settings>
<Preferences>
<Network>
<TCP/IP Settings>
<IPv4 Settings>
Specify the IPv4 address.
<DHCP Option Settings>
<Preferences>
<Network>
<TCP/IP Settings>
<IPv4 Settings>
Specify the optional settings for DHCP.
Using a DHCP Server
<PING Command>
<Preferences>
<Network>
<TCP/IP Settings>
<IPv4 Settings>
Tests whether the IPv4 address is set correctly.
Conducting a Connection Test for an IPv4 Address
<Use IPv6>
<Preferences>
<Network>
<TCP/IP Settings>
<IPv6 Settings>
Specify whether to use IPv6.
Setting an IPv6 Address
<Stateless Address Settings>
<Preferences>
<Network>
<TCP/IP Settings>
<IPv6 Settings>
Specify the IPv6 stateless address.
<Manual Address Settings>
<Preferences>
<Network>
<TCP/IP Settings>
<IPv6 Settings>
Specify the IPv6 address manually.
<Use DHCPv6>
<Preferences>
<Network>
<TCP/IP Settings>
<IPv6 Settings>
Specify whether to obtain the IPv6 address from the DHCP server.
<PING Command>
<Preferences>
<Network>
<TCP/IP Settings>
<IPv6 Settings>
Check whether the IPv6 address is correctly specified.
Conducting a Connection Test for an IPv6 Address
<Only Retrieve Stateful Address Prefix>
<Preferences>
<Network>
<TCP/IP Settings>
<IPv6 Settings>
Specify whether to obtain only the former half of the stateful address from the DHCP server by using DHCPv6.
<Preferences>
<Network>
<TCP/IP Settings>
<IPv6 Settings>
Using a DHCP Server
<DNS Server Address Settings>
<Preferences>
<Network>
<TCP/IP Settings>
<DNS Settings>
Specify the DNS server address settings.
Making DNS Settings
<DNS Host/Domain Name Settings>
<Preferences>
<Network>
<TCP/IP Settings>
<DNS Settings>
Specify the host name and domain name of the machine.
Making DNS Settings
<DNS Dynamic Update Settings>
<Preferences>
<Network>
<TCP/IP Settings>
<DNS Settings>
Specify whether to perform the automatic update when the mapping between the host name and IP address is changed on an environment such as DHCP.
Making DNS Settings
<mDNS Settings>
<Preferences>
<Network>
<TCP/IP Settings>
<DNS Settings>
Specify the mDNS settings.
Making DNS Settings
<Computer Name/Workgroup Name Settings>
<Preferences>
<Network>
<TCP/IP Settings>
Specify the name of the machine on the network and the name of the workgroup it belongs to. If your environment does not have workgroups, create a workgroup in Windows and enter the name of that workgroup.
<SMB Server Settings>
<Preferences>
<Network>
<TCP/IP Settings>
Specify the SMB server settings to open the Advanced Box to the public in a network.
Making SMB Settings
<WINS Settings>
<Preferences>
<Network>
<TCP/IP Settings>
Specify settings for Windows Internet Name Service (WINS).
Making WINS Settings
<LPD Print Settings>
<Preferences>
<Network>
<TCP/IP Settings>
Specify settings for LPD printing. To use LPD printing, press <On> and set the time until the job is automatically canceled when the print data cannot be received due to a communication error, etc.
Banner pages are set to be output by print job. Even if <LPD Banner Page> is set to <On>, banner pages are not output for print jobs that are set to not output a banner page.
<RAW Print Settings>
<Preferences>
<Network>
<TCP/IP Settings>
Specify settings for RAW printing. To use RAW printing, press <On> and set whether to use bidirectional communication and the time until the job is automatically canceled when the print data cannot be received due to a communication error, etc.
<SNTP Settings>
<Preferences>
<Network>
<TCP/IP Settings>
Specify settings for Simple Network Time Protocol (SNTP).
Making SNTP Settings
<FTP Print Settings>
<Preferences>
<Network>
<TCP/IP Settings>
Specify settings for FTP printing. To use FTP printing, press <On>, and set <User Name> and <Password> as necessary.
<Use UTF-8 to Display Name of FTP Print Job>
<Preferences>
<Network>
<TCP/IP Settings>
Specify whether to use UTF-8 for displaying file names when you perform FTP print.
<WSD Settings>
<Preferences>
<Network>
<TCP/IP Settings>
Specify the WSD settings. To use WSD (Web Service on Devices) for the print application, set <Use WSD> to <On>. To use WSD to retrieve the information for the machine, set <Use WSD Browsing> to <On>.
To use the WSD Scan function, set <Use WSD Scan Function> to <On>.
Using WSD
If you set <Use WSD> to <On>, <Use WSD Browsing> and <Use HTTP> are also set to <On>.
If you set <Use WSD Scan Function> to <On>, <Use HTTP> is also set to <On>.
<Use FTP PASV Mode>
<Preferences>
<Network>
<TCP/IP Settings>
Specify whether to use the FTP PASV mode.
Setting the PASV Mode of FTP
<IPP Print Settings>
<Preferences>
<Network>
<TCP/IP Settings>
Specify settings for IPP printing. To use IPP printing, press <On> and set whether to encrypt the IPP communication data with TLS and whether to use IPP authentication.
If you set this to <On>, <Use HTTP> is also set to <On>.
To use the IPP authentication function by setting <Use Authentication> to <On>, the user information of the machine is used as the user and password for IPP authentication. Make sure to register the user information in advance when using the IPP authentication function. Registering User Information in the Local Device
<Multicast Discovery Settings>
<Preferences>
<Network>
<TCP/IP Settings>
<Use HTTP>
<Preferences>
<Network>
<TCP/IP Settings>
Enable or disable HTTP setting.
If you set this to <Off>, the following settings are also set to <Off>.
<Remote UI>
<Use WSD Scan Function> and <Use WSD> in <WSD Settings>
<BMLinkS Settings>
<Use WebDAV Server>
<Use WebDAV Server>
<Preferences>
<Network>
<TCP/IP Settings>
Specify whether to use the WebDAV server.
Making WebDAV Settings
<TLS Settings>
<Preferences>
<Network>
<TCP/IP Settings>
You can set a key pair that is in use after checking the functions that use TLS encrypted communication.
Configuring the Key and Certificate for TLS
<Proxy Settings>
<Preferences>
<Network>
<TCP/IP Settings>
Specify settings for the proxy.
Setting a Proxy
<Confirm Auth. Info. When in Auth. Management Mode>
<Preferences>
<Network>
<TCP/IP Settings>
Specify whether the machine checks authentication information when you print using the V4 printer driver.
<IPSec Settings>
<Preferences>
<Network>
<TCP/IP Settings>
<SIP Settings>
<Preferences>
<Network>
<TCP/IP Settings>
Specify the SIP settings. For information on using <SIP Settings>, see the IP FAX Expansion Kit User's Guide.
<Use Network Link Scan>
<Preferences>
<Network>
<TCP/IP Settings>
Specify whether to use Network Link Scan.
<AppleTalk Settings>
Specify whether to use AppleTalk. Also, specify the protocol when you use AppleTalk.
<SNMP Settings>
<Format Host Resources MIB to RFC2790>
Specify whether the host resources MIB is compliant with the specifications of RFC2790.
<Dedicated Port Settings>
Specify whether to configure/refer to detailed information of the machine from the Canon drivers or utility software.
If the setting is set to <Off>, some application that uses dedicated port may not be used.
<Dedicated Port Authentication Method>
Specify the authentication method for the dedicated port.
If the setting is set to <Mode 2>, communication using a dedicated port uses a secure mode. Accordingly, you may not be able to connect from device management software or drivers, etc.
<Use Spool Function>
Specify whether to spool print jobs that are sent to the machine in the hard disk of the machine.
<Waiting Time for Connection at Startup>
Specify the waiting time for connecting to a network from when the machine starts.
Setting the Wait Time When Connecting to a Network
<Ethernet Driver Settings>
Specify the Ethernet driver settings.
Making Ethernet Settings
<Sleep Mode Priority Settings>
Put a priority on either the speed of waking from sleep mode or saving power consumption during sleep mode.
<IEEE 802.1X Settings>
If you set <IEEE 802.1X Settings> to <On>, the machine will not completely enter the Sleep mode.
<Outbound Filter>
<Preferences>
<Network>
<Firewall Settings>
<IPv4 Address Filter>
<Inbound Filter>
<Preferences>
<Network>
<Firewall Settings>
<Always Allow Sending/Receiving Using ICMP>
<Preferences>
<Network>
<Firewall Settings>
Specify whether to always allow ICMP communication.
<Outbound Filter>
<Preferences>
<Network>
<Firewall Settings>
<IPv6 Address Filter>
<Inbound Filter>
<Preferences>
<Network>
<Firewall Settings>
<Always Allow Sending/Receiving Using ICMPv6>
<Preferences>
<Network>
<Firewall Settings>
Specify whether to always allow ICMPv6 communication.
<Outbound Filter>
<Preferences>
<Network>
<Firewall Settings>
<MAC Address Filter>
<Inbound Filter>
<Preferences>
<Network>
<Firewall Settings>
<IP Address Block Log>
<Preferences>
<Network>
<Firewall Settings>
Displays the log for blocking with an IP address filter.
Specifying IP Addresses in Firewall Settings
<Use Mopria>
Specify whether to print data directly from mobile devices that support Mopria, such as smartphones and tablets.
Utilizing the Machine through Applications
<Use AirPrint>
Specify whether to print directly from an iPhone, iPad, iPod Touch, or Mac that supports AirPrint.
Using AirPrint
<Google Cloud Print Settings>
Specify whether to print directly from a computer, smartphone, or tablet, etc., that supports Google Cloud Print.
Using Google Cloud Print
<Device Position Information Settings>
Specify the device position information settings.
Using AirPrint
<Select Wired/Wireless LAN>
Specify whether you use Wired LAN or Wireless LAN.
Selecting Wired or Wireless LAN
If you set this to <Wireless LAN>, <Compensate for Network Comm.> is enabled when <Low> is selected in <Sleep Mode Energy Use>.
<Wireless LAN Settings>
<Preferences>
<Network>
<Wireless LAN>
Specify the wireless LAN settings.
Connecting to a Wireless LAN
<Wireless LAN Information>
<Preferences>
<Network>
<Wireless LAN>
<Power Save Mode>
<Preferences>
<Network>
<Wireless LAN>
Specify whether to set the machine to the power save mode periodically, according to the signals sent by a wireless LAN router.
<Use Direct Connection>
<Preferences>
<Network>
<Direct Connection Settings>
Specify whether to use direct connection (access point mode).
Connecting Directly (Access Point Mode)
<Time Until Direct Connection Session Is Terminated>
<Preferences>
<Network>
Specify the time before communication is automatically terminated when there is a prolonged period of no data transmission/reception while communicating using direct connection (access point mode).
<Access Point Mode Settings>
<Preferences>
<Network>
Specify the settings for access point mode.
<IP Address Settings for Direct Connection>
<Preferences>
<Network>
Specify the IP address to distribute to mobile devices connecting using direct connection (access point mode).
The IP address distributed to mobile devices may be up to nine numbers greater than the value of the specified IP address.
<Use Login Name as User Name for Print Jobs>
<Preferences>
<Network>
Specify whether to display the login name as the user name of print jobs that are printed using direct connection (access point mode).
<Use Bluetooth>
<Preferences>
<Network>
<Bluetooth Settings>
Specify whether to use a Bluetooth connection.
If you set this to <On>, <Compensate for Network Comm.> is enabled when <Low> is selected in <Sleep Mode Energy Use>.
<Set Device Name/PIN Code>
<Preferences>
<Network>
Specify the device name of the machine to notify by Bluetooth and the PIN code to use for pairing.
<Connection Timeout>
<Preferences>
<Network>
Specify the timeout time for pairing when a Bluetooth device is detected.
<Display MAC Address>
<Preferences>
<Network>
Displays the Bluetooth MAC address of the machine.
<Connected Device Information>
<Preferences>
<Network>
Displays a list of MAC addresses for paired Bluetooth devices.
