To perform personal authentication management, you must first register user information in the database of the machine.
[Authentication Management].
[OK].
[User Name:] / [Password:] / [Confirm:]
[PIN:] / [Confirm:]
[Displayed As:]
[E-Mail Address]
[Department ID]
[Select Role to Set:]|
[Administrator]
Allows access to all machine operations.
[GeneralUser]
Allows general user privileges.
[DeviceAdmin]
Allows operations that are available to general users, along with the ability to change settings related to basic functions such as copying, printing, sending, and receiving.
[NetworkAdmin]
Allows operations that are available to general users, along with the ability to change network-related settings.
[ID to Register for IC Card 1:] / [ID to Register for IC Card 2:] / [Verification Value:]
[Set expiration for the user account]
[Disable the user account]
[User Group Association]
Configuring settings via the control panelYou can also register user information by pressing
<Management Settings> <User Management> <Authentication Management> <Register/Edit Authentication User>. <Register/Edit Authentication User>Creating user groupsAddress Lists in the Address Book can be shared between users who are registered in a user group. Registering User Groups
TIPS
Save time by importing user information from another machineIf you click [Export...] or [Import...] in step 4, you can save (export) user information from the machine to a computer, or load (import) user information from another machine. This convenient procedure enables you to register user information just one time. Specifying [Timing to Apply] enables you to reflect user information at a desired time. If the user information cannot be reflected at the specified time because the machine is turned OFF or is completely in sleep mode, the information is reflected when the machine recovers.
Check for unregistered Department IDsIf you click [Check Unregistered Department ID...] on the screen displayed in step 4, you can find out Department IDs that are not registered in the machine by checking Department IDs assigned to the users against Department IDs registered in the machine.
