![](./images/global_images/1T0003419081/b_style_note1_L=en-GB.gif)
Optional products are required to use Bluetooth LE or NFC. System Options
Set the machine to Access Point Mode
![]() ![]() ![]() ![]() ![]() ![]() When connecting using Bluetooth LE, press
![]() ![]() ![]() ![]() ![]() When connecting using NFC, refer to the NFC Kit User's Guide.
Put the machine into the connection standby status.
<Main Menu>
Connect from mobile devices
Based on the SSID information and the network key displayed, perform settings for wireless LAN connection with the machine as the connection destination.
![]() While connected, <Connected using Access Point Mode to other devices.> is displayed.
When connecting using Bluetooth LE, place the mobile device near the machine. The device name and PIN code are shown on the display. Using this information, perform pairing via the mobile device.
Perform the desired operation such as printing or scanning.
Stop the connection between the machine and the mobile device.
Press <Disable> on the <Direct Connection> screen. Connection with the mobile device stops.
While connecting via direct connection, you may not be able to connect to the Internet depending on the mobile device you are using.
You can connect with up to five mobile devices using direct connection.
If a wireless connection from a mobile device is not performed within 5 minutes while the SSID and network key are displayed, the status waiting for connection ends.
If the status without data transmission between a mobile device and the machine continues during communication by direct connection, the communication may end.
Power saving performance of sleep mode degrades while connecting via direct connection.
When you finish the desired operation, be sure to terminate the connection between the machine and the mobile device. If they remain connected, power saving performance of sleep mode degrades.
If you use the direct connection, do not set the IP address manually on the mobile device. Doing so may prevent proper communication after using the direct connection.
