Registering a Combination of Frequently Used Functions
If you use the same settings every time for the Copy, Fax, or Scan function or want to save complicated settings, you can register settings as favorite settings, which can then be conveniently recalled.
Copy Basic Features screen
Fax Basic Features screen
Scan Basic Features screen
Scan and Store Basic Features screen
Access Stored Files Basic Features screen
The Copy function is used here as an example.
Registering Settings
1
Press <Copy>, and specify the settings you want to register.
Basic Copy Operations
2
Press
<Register/Edit Favorite Settings>.
3
Select a button and press <Register>.
To change a button name, select the button, press <Rename>, and enter the new name.
To delete registered settings, select the button and press <Delete>.
4
Press <Yes>
<Close>.
For certain functions, press <Next>, enter a comment as necessary, and press <OK>. You can set <Show Comments> to <On> to display comments.
Recalling Registered Settings
1
Place the original.
Placing Originals
2
Press <Copy> on the Main Menu.
<Main Menu> Screen
3
Press <Favorite Settings> on the Copy Basic Features screen.
Copy Basic Features Screen
4
Select the button
<OK>
<Yes>.
You can also change the settings you recall after pressing <Yes>.
5
Press
Copying starts.
