This mode can be used only for printing a file stored in a mail box or a PDF or XPS file.
The Saddle Stitch and Fold modes can be used only for printing a file stored in a mail box.
Be sure to correctly set the paper type. If the type of paper is not set correctly, it could adversely affect the quality of the image. Moreover, the fixing unit may become dirty, or the paper could jam, and a service repair may be needed.
The Finishing modes cannot be set if custom size, envelopes, transparencies, tracing paper, or labels is selected.
If you set the Staple, Hole Punch, or Z-Fold mode, the side of the paper which is printed on will always be output face down.
The paper used for the cover page must be the same size as that which is used for the main document.
If you are loading preprinted paper to use as the cover page into the document insertion unit, you must load the paper face up.
When using Booklet Finisher-K1, use the paper shown below.
Main document: 16 lb bond to 80 lb cover (60 to 220 g/m2)
Cover paper: Up to 110 lb cover (300 g/m2)
When using Booklet Finisher-L1, use the paper shown below.
Cover paper: Up to 140 lb index (256 g/m2)
The [Saddle Stitch] mode can be set only if 2-Sided Printing is set.
The accuracy of folds created in the Saddle Stitch mode may vary depending on the paper type and the number of sheets.
If you specify the Z-Fold mode with the Staple mode, and the number of sheets that are Z-folded exceeds 10, the prints will be collated, but not stapled.
If you want the printed side to be folded inside, select [Up (Reverse Order)] for [Face Up/Face Down].
13" x 19", 12" x 18", 12 5/8" x 17 11/16", 11" x 17", LGL, LTRR, Custom Size (8 1/4" x 11" to 13" x 19 1/4" (210 mm x 279.3 mm to 330.2 mm x 487.7 mm)) paper can be saddle folded when the Booklet Finisher-K1 is attached.
12" x 18", 11" x 17", LGL, LTRR paper can be saddle folded when the Booklet Finisher-L1 is attached.
The Saddle Fold mode can be set only if the 2-Sided Printing is set.
A maximum of five sheets can be folded together and output with Saddle Fold.
You can only set [Rotate 90 Degrees] in the following cases:
If the paper size is set to [Auto] on the Paper Size Selection screen
If the paper size compatible with Rotate 90 Degrees is loaded in both the horizontal and vertical directions
If [Paper Drawer Auto Selection On/Off] for the selected paper source is set to 'On' (See "Enabling Paper Drawer Auto Selection.")
If there is no paper which can be rotated, the output will be collated.
[Auto]:
If you are printing a single page original, the printed sheets are output face up. Otherwise, the printed sheets are output face down.
[Face Down (Normal Order)]:
Printed sheets are always output face down.
[Face Up (Reverse Order)]:
Printed sheets are always output face up.
You can set [Trim] only if you select [Saddle Stitch].
: Available|
Optional Unit
Collate (Page Order)
Group (Same Pages)
Offset
Rotate 90 Degrees
Staple
Hole Punch
Fold
Trim
Face Up/Face Down
Corner
Double
Saddle Stitch
Saddle Fold
Z-Fold, C-Fold, Half Fold, Accordion Z-Fold, Double Parallel Fold
None
Copy Tray-P1
Staple Finisher-K1
Staple Finisher-K1 and Puncher Unit
Staple Finisher-K1, Professional Puncher-C1, and Professional Puncher Integration Unit-B1
Staple Finisher-K1 and Paper Folding Unit-G1
Booklet Finisher-K1
Booklet Finisher-K1 and Puncher Unit
Booklet Finisher-K1, Professional Puncher-C1, and Professional Puncher Integration Unit-B1
Booklet Finisher-K1 and Paper Folding Unit-G1
Booklet Finisher-K1 and Inner Booklet Trimmer-A1
Optional Unit
Group (Same Pages)
Offset
Rotate 90 Degrees
Staple
Hole Punch
Fold
Trim
Face Up/Face Down
Corner
Double
Saddle Stitch
Saddle Fold
Z-Fold, C-Fold
None
Copy Tray-P1
Staple Finisher-L1
Staple Finisher-L1 and Puncher
Staple Finisher-L1 and Document Insertion/Folding Unit-G1
Booklet Finisher-L1
Booklet Finisher-L1 and Puncher
Booklet Finisher-L1 and Document Insertion/Folding Unit-G1
Staple
Paper Type and Paper Weight
11" x 17"/LGL/LTRR
LTR/EXEC
Corner/Double
Thin/Plain (14 lb bond to 20 lb bond (52 to 80g/m2))
50 sheets
100 sheets
Plain (21 lb bond (81 to 81.4 g/m2))
40 sheets
100 sheets
Plain (22 lb bond to 28 lb bond (81.5 to 105 g/m2))
20 sheets
30 sheets
Heavy (29 lb bond to 74 lb cover (106 to 200 g/m2))
5 sheets
10 sheets
Heavy (75 lb cover to 94 lb cover (201 to 256 g/m2))
2 sheets
3 sheets
Heavy (100 lb cover to 110 lb cover (257 to 300 g/m2))
2 sheets
2 sheets
Coated (29 lb bond to 74 lb cover (106 to 200 g/m2))
5 sheets
2 sheets
Coated (75 lb cover to 110 lb index (201 to 256 g/m2))
3 sheets
2 sheets
Coated (100 lb cover to 110 lb cover (257 to 300 g/m2))
2 sheets
2 sheets
Saddle Stitch*
Thin/Plain (16 lb bond to 21 lb bond (60 to 81 g/m2))
20 sheets
Plain (22 lb bond to 28 lb bond (82 to 105 g/m2))
10 sheets
Heavy (29 lb bond to 80 lb cover (106 to 220 g/m2))
5 sheets
Coated (75 lb cover to 110 lb index (106 to 209 g/m2))
5 sheets
Coated (77 lb cover to 80 lb cover (210 to 220 g/m2))
3 sheets
Paper Size
Corner
Double
Saddle Stitch*
12" x 18"
16 sheets
12 5/8" x 17 11/16"
11" x 17"
30 sheets
30 sheets
16 sheets
LGL
30 sheets
30 sheets
16 sheets
LTRR
30 sheets
30 sheets
16 sheets
LTR
50 sheets
50 sheets
EXEC
50 sheets
50 sheets
STMTR
STMT
For information on the original orientation and paper orientation when performing stapling, see "Relationship Between the Original Orientation and Paper Orientation."
If you set Staple or Hole Punch, prints are always output with the printed face down.
For information on optional products that can be used with the imageRUNNER ADVANCE C9280 PRO/C9270 PRO, see the following:
For information on optional products that can be used with the imageRUNNER ADVANCE C7270/C7260, see the following:
If [Finishing] is not set, the settings are the same as when [Group (Same Pages)] is set.
You can display the detailed information of the selected paper by pressing
