If you are copying onto the back side of a previously printed sheet, load the paper as indicated below.
Paper drawer: Load the side to copy on face up.
Multi-purpose tray, Paper Deck Unit-C1, POD Deck Lite-A1, or Multi-drawer Paper Deck-A1: Load the side to copy on face down.
Other Settings
Example of Stapling Position
Corner: Top Right
Double: Right ![]() LTR
Corner: Top Right
Double: Top ![]() 11" x 17", LGL, LTRR
Corner: Top Right
![]() LTR, LTRR
Corner: Top Right
Double: Right ![]() 11" x 17", LGL, LTRR
Preprinted paper
Loading location:
Paper Drawer 1
and 2 Preprinted paper: Face down
Loading location: Paper Drawer 3
and 4 Preprinted paper: Face down |
Loading location: Paper Deck Unit-C1
Preprinted paper: Face up |
Loading location: POD Deck Lite-A1, Multi-drawer Paper Deck-A1
Original
Loading location: Platen glass
Original: Face down |
Stapling setting
Corner: Top Right
Double: Right |
Corner: Bottom Right
Double: Right |
Corner: Top Right
Corner: Top Right
Double: Right |
Loading location: Feeder
Original: Face up |
Stapling setting
Corner: Top Right
Double: Right |
Double: Right |
Corner: Top Right
Corner: Top Right
Double: Right |
Auto Rotation Setting
Both ON and OFF available
Both ON and OFF available (ON when
loaded vertically in the paper drawer 3 and 4/Multi-purpose tray/POD Deck Lite-A1/Multi-drawer Paper Deck-A1) |
Other Settings
Corner: Top Left
Double: Left ![]() LTR
Corner: Top Left
Corner: Top Left
![]() LTR, LTRR
Corner: Top Left
Double: Left ![]() 11" x 17", LGL, LTRR
Preprinted paper
Loading location:
Paper Drawer 1
Original
Stapling setting
Corner: Top Left
Double: Left |
Corner: Top Right
Double: Right |
Corner: Top Left
Corner: Top Left
Double: Left |
Original: Face up |
Stapling setting
Corner: Top Left
Double: Left |
Corner: Top Right
Double: Right |
Corner: Top Left
Corner: Top Left
Double: Left |
Other Settings
![]() LTR, LTRR
![]() LTR, LTRR
Preprinted paper
Loading location:
Paper Drawer 1
Original
Original: Face up |
loaded horizontally in the paper drawer 3 and 4/Multi-purpose tray/POD Deck Lite-A1/Multi-drawer Paper Deck-A1) |
Function
Functions that Cannot Be Used in Combination
Preset Zoom
Zoom by Percentage*1, XY Independent*1, Auto XY Ratio*1, Auto Zoom*1, Set by Length*1, Poster (Number of Output Pages)*1, Poster (%)*1, N on 1*1, Booklet Scanning*1, Divided Booklet*1, Creep Correction*1
Zoom by Percentage
Preset Zoom*1, XY Independent*1, Auto XY Ratio*1, Auto Zoom*1, Set by Length*1, Poster (Number of Output Pages)*1, Poster (%)*1, N on 1*1, Booklet Scanning*1, Divided Booklet*1, Creep Correction*1
XY Independent
Preset Zoom*1, Zoom by Percentage*1, Auto XY Ratio*1, Auto Zoom*1, Set by Length*1, Poster (Number of Output Pages)*1, Poster (%)*1, N on 1*1, Booklet Scanning*1, Divided Booklet*1, Creep Correction*1
Auto XY Ratio
Preset Zoom*1, Zoom by Percentage*1, XY Independent*1, Auto Zoom*1, Set by Length*1, Automatic Paper Selection, Poster (Number of Output Pages)*1, Poster (%)*1, N on 1*1, Repeat Images (Auto), Repeat Images (Auto) + Framing, Booklet Scanning*1, Between Batches, Print on Tab, Tab Paper, Divided Booklet*1, Creep Correction*1
Auto Zoom
Preset Zoom*1, Zoom by Percentage*1, XY Independent*1, Auto XY Ratio*1, Set by Length*1, Automatic Paper Selection, Poster (Number of Output Pages)*1, Poster (%)*1, Repeat Images (Auto), Repeat Images (Auto) + Framing, Between Batches, Print on Tab, Tab Paper
Set by Length
Preset Zoom*1, Zoom by Percentage*1, XY Independent*1, Auto XY Ratio*1, Auto Zoom*1, Poster (Number of Output Pages)*1, Poster (%)*1, Print on Tab, Tab Paper
Fit to Page
Poster (Number of Output Pages), Poster (%), N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Booklet Scanning, Do Not Booklet Scan, Between Batches, Print on Tab, Tab Paper, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction
Function
Manual Paper Selection*1, Custom Size*1, Poster (Number of Output Pages)*1, N on 1*1, Booklet Scanning*1, Do Not Booklet Scan*1, Between Batches, Rotate 90 Degrees: Collating*1, Rotate 90 Degrees: Group*1, Saddle Stitch*1, Saddle Fold*1, Z-Fold*1, C-Fold*1, Accordion Z-Fold*1, Double Parallel Fold*1, Half Fold*1, Print on Tab*1, Divided Booklet*1, Creep Correction*1
Automatic Paper Selection*1, Custom Size*1, Between Batches, Print on Tab*1
Custom Size
Automatic Paper Selection*1, Manual Paper Selection*1, 1-Sided
2-Sided, Book 2-Sided, 2-Sided 2-Sided, Poster (Number of Output Pages), Poster (%), Book 2 Pages, N on 1, Booklet Scanning, Do Not Booklet Scan, Between Batches, Z-Fold, C-Fold, Accordion Z-Fold, Double Parallel Fold, Half Fold, Hole Punch, Divided Booklet, Creep Correction, Store in Mail Box, Store in Mail Box (Copy upon Storing) |
Scanning Originals Loaded in the Feeder
Book
2-Sided, Poster (Number of Output Pages), Poster (%), Book 2 Pages |
Function
Collate
Poster (Number of Output Pages)*1, Poster (%)*1, Transparency Cover Sheets*1, Booklet Scanning*1, Do Not Booklet Scan, Between Batches, Group*1, Rotate 90 Degrees: Collating*1, Rotate 90 Degrees: Group*1, Offset Collate*1, Offset Group*1, Staple*1, Saddle Stitch*1, Divided Booklet*1, Creep Correction*1
Group
Poster (Number of Output Pages), Poster (%), Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Collate*1, Rotate 90 Degrees: Collating*1, Rotate 90 Degrees: Group*1, Offset Collate*1, Offset Group*1, Staple*1, Saddle Stitch*1, Saddle Fold, Print on Tab, Tab Paper, Copy Sample, Copy Set Numbering, Divided Booklet, Creep Correction, Merge Job Blocks, Secure Watermark*2
Automatic Paper Selection, Poster (Number of Output Pages), Poster (%), Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Collate*1, Group*1, Rotate 90 Degrees: Group*1, Offset Collate, Offset Group, Staple, Saddle Stitch, Saddle Fold, C-Fold, Accordion Z-Fold, Double Parallel Fold, Half Fold, Hole Punch, Print on Tab, Tab Paper, Divided Booklet, Creep Correction, Merge Job Blocks
Automatic Paper Selection, Poster (Number of Output Pages), Poster (%), Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Collate*1, Group*1, Rotate 90 Degrees: Collating*1, Offset Collate, Offset Group, Staple, Saddle Stitch, Saddle Fold, C-Fold, Accordion Z-Fold, Double Parallel Fold, Half Fold, Hole Punch, Print on Tab, Tab Paper, Copy Sample, Copy Set Numbering, Divided Booklet, Creep Correction, Merge Job Blocks, Secure Watermark*2
Offset Collate
Poster (Number of Output Pages)*1, Poster (%)*1, Transparency Cover Sheets*1, Booklet Scanning*1, Do Not Booklet Scan, Between Batches, Collate*1, Group*1, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group*1, Offset Group, Staple*1, Saddle Stitch*1, Saddle Fold, C-Fold, Accordion Z-Fold, Double Parallel Fold, Half Fold, Print on Tab, Divided Booklet*1, Creep Correction*1
Offset Group
Poster (Number of Output Pages), Poster (%), Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Collate*1, Group*1, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate*1, Staple*1, Saddle Stitch*1, Saddle Fold, C-Fold, Accordion Z-Fold, Double Parallel Fold, Half Fold, Print on Tab, Tab Paper, Copy Sample, Copy Set Numbering, Divided Booklet, Creep Correction, Merge Job Blocks, Secure Watermark*2
Staple
Poster (Number of Output Pages), Poster (%), Mirror Image, Transparency Cover Sheets, Booklet Scanning, Do Not Booklet Scan, Between Batches, Collate*1, Group*1, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Saddle Stitch*1, Saddle Fold, C-Fold, Accordion Z-Fold, Double Parallel Fold, Half Fold, Print on Tab, Divided Booklet, Creep Correction
Saddle Stitch
Automatic Paper Selection, Book
2-Sided, 2-Sided 1-Sided, Poster (Number of Output Pages), Poster (%), Book 2 Pages, N on 1, Mirror Image, Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Collate*1, Group*1, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple*1, Saddle Fold, Z-Fold, C-Fold, Accordion Z-Fold, Double Parallel Fold, Half Fold, Hole Punch, Print on Tab, Tab Paper, Superimpose Image, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction, Merge Job Blocks |
Function
Z-Fold
Custom Size, Poster (Number of Output Pages), Poster (%), Transparency Cover Sheets, Booklet Scanning, Do Not Booklet Scan, Between Batches, Saddle Stitch, Saddle Fold, C-Fold, Accordion Z-Fold, Double Parallel Fold, Half Fold, Divided Booklet, Creep Correction
C-Fold
Automatic Paper Selection, Custom Size, Poster (Number of Output Pages), Poster (%), Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Rotate 90 Degrees:Collating, Rotate 90 Degrees:Group, Offset Collate, Offset Group, Staple, Saddle Stitch, Saddle Fold, Z-Fold, Accordion Z-Fold, Double Parallel Fold, Half Fold, Hole Punch, Print on Tab, Tab Paper, Divided Booklet, Creep Correction, Merge Job Blocks, Store in Mail Box, Store in Mail Box(Copy upon Storing)
Accordion Z-Fold
Automatic Paper Selection, Custom Size, Poster (Number of Output Pages), Poster (%), Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Rotate 90 Degrees:Collating, Rotate 90 Degrees:Group, Offset Collate, Offset Group, Staple, Saddle Stitch, Saddle Fold, Z-Fold, C-Fold, Double Parallel Fold, Half Fold, Hole Punch, Print on Tab, Tab Paper, Divided Booklet, Creep Correction, Merge Job Blocks, Store in Mail Box, Store in Mail Box(Copy upon Storing)
Automatic Paper Selection, Custom Size, Poster (Number of Output Pages), Poster (%), Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Rotate 90 Degrees:Collating, Rotate 90 Degrees:Group, Offset Collate, Offset Group, Staple, Saddle Stitch, Saddle Fold, Z-Fold, C-Fold, Accordion Z-Fold, Half Fold, Hole Punch, Print on Tab, Tab Paper, Divided Booklet, Creep Correction, Merge Job Blocks, Store in Mail Box, Store in Mail Box(Copy upon Storing)
Half Fold
Automatic Paper Selection, Custom Size, Poster (Number of Output Pages), Poster (%), Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Rotate 90 Degrees:Collating, Rotate 90 Degrees:Group, Offset Collate, Offset Group, Staple, Saddle Stitch, Saddle Fold, Z-Fold, C-Fold, Accordion Z-Fold, Double Parallel Fold, Hole Punch, Print on Tab, Tab Paper, Divided Booklet, Creep Correction, Merge Job Blocks, Store in Mail Box, Store in Mail Box(Copy upon Storing)
Saddle Fold
2-Sided, 2-Sided 1-Sided, Poster (Number of Output Pages), Poster (%), Book 2 Pages, N on 1, Mirror Image, Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Saddle Stitch, Z-Fold, C-Fold, Accordion Z-Fold, Double Parallel Fold, Half Fold, Hole Punch, Print on Tab, Tab Paper, Superimpose Image, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction, Merge Job Blocks |
Hole Punch
Custom Size, Poster (Number of Output Pages), Poster (%), Transparency Cover Sheets, Booklet Scanning, Do Not Booklet Scan, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Saddle Stitch, Saddle Fold, C-Fold, Accordion Z-Fold, Double Parallel Fold, Half Fold, Print on Tab, Divided Booklet, Creep Correction
Function
1-Sided
2-Sided |
Custom Size, Book
2-Sided*1, 2-Sided 2-Sided*1, 2-Sided 1-Sided*1, Poster (Number of Output Pages), Poster (%), Book 2 Pages, Transparency Cover Sheets, Booklet Scanning, Do Not Booklet Scan, Print on Tab, Divided Booklet, Creep Correction |
Book
2-Sided |
Custom Size, 1-Sided
2-Sided*1, 2-Sided 2-Sided*1, 2-Sided 1-Sided*1, Poster (Number of Output Pages), Poster (%), Book 2 Pages, N on 1, Erase Binding, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Framing, Blanking, Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Scanning Originals Loaded in the Feeder, Between Batches, Saddle Stitch, Saddle Fold, Print on Tab, Tab Paper, Different Size Originals, Divided Booklet, Creep Correction, Print & Check |
2-Sided
2-Sided |
2-Sided*1, Book 2-Sided*1, 2-Sided 1-Sided*1, Poster (Number of Output Pages), Poster (%), Book 2 Pages, Transparency Cover Sheets, Booklet Scanning, Do Not Booklet Scan, Print on Tab, Divided Booklet, Creep Correction |
2-Sided
1-Sided |
1-Sided
2-Sided*1, Book 2-Sided*1, 2-Sided 2-Sided*1, Poster (Number of Output Pages), Poster (%), Book 2 Pages, Transparency Cover Sheets, Booklet Scanning, Do Not Booklet Scan, Saddle Stitch, Saddle Fold, Divided Booklet, Creep Correction |
Auto (Color/Black), Background Density (Auto), Preset Zoom*1, Zoom by Percentage*1, XY Independent*1, Auto XY Ratio*1, Auto Zoom*1, Set by Length*1, Fit to Page, Automatic Paper Selection, Custom Size, 1-Sided
2-Sided, Book 2-Sided, 2-Sided 2-Sided, 2-Sided 1-Sided, Poster (%)*1, Book 2 Pages, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Position), Shift (By Numeric Keys), Gutter, Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Framing, Blanking, Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Scanning Originals Loaded in the Feeder, Job Build, Between Batches, Collate, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Saddle Stitch, Saddle Fold, Z-Fold, C-Fold, Accordion Z-Fold, Double Parallel Fold, Half Fold, Hole Punch, Print on Tab, Tab Paper, Different Size Originals, Copy Sample, Superimpose Image, Divided Booklet, Creep Correction, Print & Check, Merge Job Blocks |
Poster (%)
Auto (Color/Black), Background Density (Auto), Preset Zoom*1, Zoom by Percentage*1, XY Independent*1, Auto XY Ratio*1, Auto Zoom*1, Set by Length*1, Fit to Page, Custom Size, 1-Sided
2-Sided, Book 2-Sided, 2-Sided 2-Sided, 2-Sided 1-Sided, Poster (Number of Output Pages)*1, Book 2 Pages, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Position), Shift (By Numeric Keys), Gutter, Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Framing, Blanking, Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Scanning Originals Loaded in the Feeder, Job Build, Between Batches, Collate, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Saddle Stitch, Saddle Fold, Z-Fold, C-Fold, Accordion Z-Fold, Double Parallel Fold, Half Fold, Hole Punch, Print on Tab, Tab Paper, Different Size Originals, Copy Sample, Superimpose Image, Divided Booklet, Creep Correction, Print & Check, Merge Job Blocks |
Book
2 Pages |
2-Sided, Book 2-Sided, 2-Sided 2-Sided, 2-Sided 1-Sided, Poster (Number of Output Pages), Poster (%), N on 1, Erase Binding, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Framing, Blanking, Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Scanning Originals Loaded in the Feeder, Between Batches, Saddle Stitch, Saddle Fold, Print on Tab, Tab Paper, Different Size Originals, Divided Booklet, Creep Correction, Print & Check |
N on 1
Fit to Page, Automatic Paper Selection, Custom Size, Book
2-Sided, Poster (Number of Output Pages), Poster (%), Book 2 Pages, Erase Original Frame, Erase Book Frame, Shift (By Numeric Keys), Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Framing, Blanking, Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Saddle Stitch, Saddle Fold, Print on Tab, Tab Paper, Different Size Originals, Superimpose Image, Divided Booklet, Creep Correction, Print & Check |
Fit to Page, Poster (Number of Output Pages), Poster (%), N on 1, Erase Book Frame*1, Erase Binding*1, Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Framing, Booklet Scanning, Do Not Booklet Scan, Between Batches, Print on Tab, Tab Paper, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction
Erase Book Frame
Fit to Page, Poster (Number of Output Pages), Poster (%), N on 1, Erase Original Frame*1, Erase Binding*1, Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Framing, Booklet Scanning, Do Not Booklet Scan, Between Batches, Print on Tab, Tab Paper, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction
Erase Binding
Fit to Page, Book
2-Sided, Poster (Number of Output Pages), Poster (%), Book 2 Pages, Erase Original Frame*1, Erase Book Frame*1, Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Framing, Booklet Scanning, Do Not Booklet Scan, Between Batches, Print on Tab, Tab Paper, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction |
Interrupt
Between Batches, Merge Job Blocks
Function
Shift (By Position)
Poster (Number of Output Pages), Poster (%), Shift (By Numeric Keys)*1, Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Between Batches, Print on Tab, Tab Paper
Poster (Number of Output Pages), Poster (%), N on 1, Shift (By Position)*1, Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Booklet Scanning, Do Not Booklet Scan, Between Batches, Print on Tab, Tab Paper, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction
Gutter
Poster (Number of Output Pages), Poster (%), Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Booklet Scanning, Do Not Booklet Scan, Between Batches, Print on Tab, Tab Paper, Divided Booklet, Creep Correction, Scan Lock Information (TL Code)
1-Sided
2-Sided, Book 2-Sided, 2-Sided 2-Sided, 2-Sided 1-Sided, Poster (Number of Output Pages), Poster (%), Book 2 Pages, N on 1, Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Framing, Blanking, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Collate, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Saddle Stitch, Saddle Fold, Z-Fold, C-Fold, Accordion Z-Fold, Double Parallel Fold, Half Fold, Hole Punch, Print on Tab, Tab Paper, Superimpose Image, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction, Print & Check, Merge Job Blocks |
Front Cover
Book
2-Sided, Poster (Number of Output Pages), Poster (%), Book 2 Pages, N on 1, Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Transparency Cover Sheets, Booklet Scanning, Do Not Booklet Scan, Between Batches, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Group, Saddle Stitch, Saddle Fold, C-Fold, Accordion Z-Fold, Double Parallel Fold, Half Fold, Print on Tab, Superimpose Image, Page Numbering*3, Copy Set Numbering*3, Watermark*3, Print Date*3, Divided Booklet, Creep Correction |
Book
2-Sided, Poster (Number of Output Pages), Poster (%), Book 2 Pages, N on 1, Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Transparency Cover Sheets, Booklet Scanning, Do Not Booklet Scan, Between Batches, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Group, Saddle Stitch, Saddle Fold, Print on Tab, Superimpose Image, Page Numbering*3, Copy Set Numbering*3, Watermark*3, Print Date*3, Divided Booklet, Creep Correction |
Tab Paper
Auto XY Ratio, Auto Zoom, Set by Length, Fit to Page, Book
2-Sided, Poster (Number of Output Pages), Poster (%), Book 2 Pages, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Position), Shift (By Numeric Keys), Gutter, Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Framing, Blanking, Transparency Cover Sheets, Booklet Scanning, Do Not Booklet Scan, Between Batches, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Group, Saddle Stitch, Saddle Fold, C-Fold, Accordion Z-Fold, Double Parallel Fold, Half Fold, Print on Tab, Superimpose Image, Divided Booklet, Creep Correction |
Function
Booklet Scanning
2-Sided, Book 2-Sided, 2-Sided 2-Sided, 2-Sided 1-Sided, Poster (Number of Output Pages), Poster (%), Book 2 Pages, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Numeric Keys), Gutter, Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Framing, Blanking, Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Do Not Booklet Scan, Between Batches, Collate, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Saddle Stitch, Saddle Fold, Z-Fold, C-Fold, Accordion Z-Fold, Double Parallel Fold, Half Fold, Hole Punch, Print on Tab, Tab Paper, Different Size Originals, Superimpose Image, Watermark, Print Date, Divided Booklet*1, Print & Check, Merge Job Blocks, Secure Watermark, Scan Lock Information (QR Code), Scan Lock Information (TL Code), Tracking Information |
Do Not Booklet Scan
2-Sided, Book 2-Sided, 2-Sided 2-Sided, 2-Sided 1-Sided, Poster (Number of Output Pages), Poster (%), Book 2 Pages, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Numeric Keys), Gutter, Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Framing, Blanking, Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Between Batches, Collate, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Saddle Stitch, Saddle Fold, Z-Fold, C-Fold, Accordion Z-Fold, Double Parallel Fold, Half Fold, Hole Punch, Print on Tab, Tab Paper, Different Size Originals, Superimpose Image, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction, Print & Check, Merge Job Blocks, Secure Watermark, Scan Lock Information (QR Code), Scan Lock Information (TL Code), Tracking Information |
Divided Booklet
2-Sided, Book 2-Sided, 2-Sided 2-Sided, 2-Sided 1-Sided, Poster (Number of Output Pages), Poster (%), Book 2 Pages, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Numeric Keys), Gutter, Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Framing, Blanking, Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning*1, Do Not Booklet Scan, Between Batches, Collate, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Saddle Stitch, Saddle Fold, Z-Fold, C-Fold, Accordion Z-Fold, Double Parallel Fold, Half Fold, Hole Punch, Print on Tab, Tab Paper, Different Size Originals, Superimpose Image, Watermark, Print Date, Print & Check, Merge Job Blocks, Secure Watermark, Scan Lock Information (QR Code), Scan Lock Information (TL Code), Tracking Information |
Creep Correction
2-Sided, Book 2-Sided, 2-Sided 2-Sided, 2-Sided 1-Sided, Poster (Number of Output Pages), Poster (%), Book 2 Pages, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Numeric Keys), Gutter, Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Framing, Blanking, Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Do Not Booklet Scan, Between Batches, Collate, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Saddle Stitch, Saddle Fold, Z-Fold, C-Fold, Accordion Z-Fold, Double Parallel Fold, Half Fold, Hole Punch, Print on Tab, Tab Paper, Different Size Originals, Superimpose Image, Watermark, Print Date, Print & Check, Merge Job Blocks, Secure Watermark, Scan Lock Information (QR Code), Scan Lock Information (TL Code), Tracking Information |
Function
Sharpness
Between Batches, Secure Watermark, Scan Lock Information (QR Code), Scan Lock Information (TL Code), Tracking Information
Nega/Posi
Between Batches, Color Balance (Adjust Black Hue), Merge Job Blocks, Secure Watermark, Scan Lock Information (QR Code), Scan Lock Information (TL Code), Tracking Information
Mirror Image
Fit to Page, Poster (Number of Output Pages), Poster (%), N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Position), Shift (By Numeric Keys), Gutter, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Staple, Saddle Stitch, Saddle Fold, Tab Paper, Superimpose Image, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction, Merge Job Blocks, Store in Mail Box, Store in Mail Box (Copy upon Storing), Secure Watermark, Scan Lock Information (QR Code), Scan Lock Information (TL Code), Tracking Information
Repeat Images
Fit to Page, Book
2-Sided, Poster (Number of Output Pages), Poster (%), Book 2 Pages, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Position), Shift (By Numeric Keys), Gutter, Mirror Image, Repeat Images (Auto)*1, Repeat Images + Framing*1, Repeat Images (Auto) + Framing*1, Framing*4, Blanking, Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Print on Tab, Tab Paper, Different Size Originals, Superimpose Image, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction, Print & Check, Merge Job Blocks, Secure Watermark, Scan Lock Information (QR Code), Scan Lock Information (TL Code), Tracking Information |
Auto XY Ratio, Auto Zoom, Fit to Page, Automatic Paper Selection, Book
2-Sided, Poster (Number of Output Pages), Poster (%), Book 2 Pages, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Position), Shift (By Numeric Keys), Gutter, Mirror Image, Repeat Images*1, Repeat Images + Framing*1, Repeat Images (Auto) + Framing*1, Framing*4, Blanking, Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Print on Tab, Tab Paper, Different Size Originals, Superimpose Image, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction, Print & Check, Merge Job Blocks, Secure Watermark, Scan Lock Information (QR Code), Scan Lock Information (TL Code), Tracking Information |
Fit to Page, Book
2-Sided, Poster (Number of Output Pages), Poster (%), Book 2 Pages, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Position), Shift (By Numeric Keys), Gutter, Mirror Image, Repeat Images*1, Repeat Images (Auto)*1, Repeat Images (Auto) + Framing*1, Framing*4, Blanking, Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Print on Tab, Tab Paper, Different Size Originals, Superimpose Image, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction, Print & Check, Merge Job Blocks, Secure Watermark, Scan Lock Information (QR Code), Scan Lock Information (TL Code), Tracking Information |
2-Sided, Poster (Number of Output Pages), Poster (%), Book 2 Pages, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Position), Shift (By Numeric Keys), Gutter, Mirror Image, Repeat Images*1, Repeat Images (Auto)*1, Repeat Images + Framing*1, Framing*4, Blanking, Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Print on Tab, Tab Paper, Different Size Originals, Superimpose Image, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction, Print & Check, Merge Job Blocks, Secure Watermark, Scan Lock Information (QR Code), Scan Lock Information (TL Code), Tracking Information |
Framing
Book
2-Sided, Poster (Number of Output Pages), Poster (%), Book 2 Pages, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Repeat Images*4, Repeat Images (Auto)*4, Repeat Images + Framing*4, Repeat Images (Auto) + Framing*4, Transparency Cover Sheets, Booklet Scanning, Do Not Booklet Scan, Between Batches, Print on Tab, Tab Paper, Divided Booklet, Creep Correction, Merge Job Blocks, Secure Watermark, Scan Lock Information (QR Code), Scan Lock Information (TL Code), Tracking Information |
Blanking
Book
2-Sided, Poster (Number of Output Pages), Poster (%), Book 2 Pages, N on 1, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Transparency Cover Sheets, Booklet Scanning, Do Not Booklet Scan, Between Batches, Print on Tab, Tab Paper, Divided Booklet, Creep Correction, Merge Job Blocks, Secure Watermark, Scan Lock Information (QR Code), Scan Lock Information (TL Code), Tracking Information |
Job Build
Poster (Number of Output Pages), Poster (%), Between Batches, Merge Job Blocks
Between Batches
Background Density (Adjust All Color), Auto XY Ratio, Auto Zoom, Fit to Page, Automatic Paper Selection, Manual Paper Selection, Custom Size, Book
2-Sided, Sharpness, Adjust One-Touch Color (Vivid Colors/Tranquil Colors), Adjust One-Touch Color (Lighten Image/Darken Image/Highlight Reproduction), Adjust One-Touch Color (Sepia Tone), Color Balance, Color Balance (Fine Adjust Density), Poster (Number of Output Pages), Poster (%), Book 2 Pages, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Position), Shift (By Numeric Keys), Gutter, Nega/Posi, Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Framing, Blanking, Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Job Build, Collate, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Saddle Stitch, Saddle Fold, Z-Fold, C-Fold, Accordion Z-Fold, Double Parallel Fold, Half Fold, Hole Punch, Print on Tab, Tab Paper, Different Size Originals, Copy Sample, Interrupt, Superimpose Image, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction, Print & Check, Color Balance (Adjust Hue), Color Balance (Adjust Saturation), Color Balance (Adjust Black Hue), Merge Job Blocks, Store in Mail Box, Store in Mail Box (Copy upon Storing), Secure Watermark, Scan Lock Information (QR Code), Scan Lock Information (TL Code), Tracking Information |
Book
2-Sided, Poster (Number of Output Pages), Poster (%), Book 2 Pages, N on 1, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Booklet Scanning, Do Not Booklet Scan, Between Batches, Divided Booklet, Creep Correction |
Copy Sample
Poster (Number of Output Pages), Poster (%), Between Batches, Group*1, Rotate 90 Degrees: Group*1, Offset Group*1, Store in Mail Box
Superimpose Image
Adjust One-Touch Color (Sepia Tone), Poster (Number of Output Pages), Poster (%), N on 1, Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Saddle Stitch, Saddle Fold, Tab Paper, Page Numbering, Copy Set Numbering, Watermark, Print Date, Two Colors, Divided Booklet, Creep Correction, Print & Check, Merge Job Blocks, Store in Mail Box, Store in Mail Box (Copy upon Storing), Secure Watermark, Scan Lock Information (QR Code), Scan Lock Information (TL Code), Tracking Information
Function
Print on Tab
Auto XY Ratio, Auto Zoom, Set by Length, Fit to Page, Automatic Paper Selection, Manual Paper Selection, 1-Sided
2-Sided, Book 2-Sided, 2-Sided 2-Sided, Poster (Number of Output Pages), Poster (%), Book 2 Pages, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Position), Shift (By Numeric Keys), Gutter, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Framing, Blanking, Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Saddle Stitch, Saddle Fold, C-Fold, Accordion Z-Fold, Double Parallel Fold, Half Fold, Hole Punch, Tab Paper, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction, Merge Job Blocks |
Page Numbering
Fit to Page, Adjust One-Touch Color (Sepia Tone), Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Numeric Keys), Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Transparency Cover Sheets, Front Cover*3, Sheets/Chapter Pages*3, Do Not Booklet Scan, Between Batches, Saddle Stitch, Saddle Fold, Print on Tab, Superimpose Image, Copy Set Numbering*5, Watermark*5, Print Date*5, Two Colors
Copy Set Numbering
Fit to Page, Adjust One-Touch Color (Sepia Tone), Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Numeric Keys), Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Transparency Cover Sheets, Front Cover*3, Sheets/Chapter Pages*3, Do Not Booklet Scan, Between Batches, Group, Rotate 90 Degrees: Group, Offset Group, Saddle Stitch, Saddle Fold, Print on Tab, Superimpose Image, Page Numbering*5, Watermark*5, Print Date*5, Two Colors, Secure Watermark, Scan Lock Information (QR Code), Scan Lock Information (TL Code), Tracking Information
Watermark
Fit to Page, Adjust One-Touch Color (Sepia Tone), Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Numeric Keys), Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Transparency Cover Sheets, Front Cover*3, Sheets/Chapter Pages*3, Booklet Scanning, Do Not Booklet Scan, Between Batches, Saddle Stitch, Saddle Fold, Print on Tab, Superimpose Image, Page Numbering*5, Copy Set Numbering*5, Print Date*5, Two Colors, Divided Booklet, Creep Correction, Secure Watermark, Scan Lock Information (QR Code), Scan Lock Information (TL Code), Tracking Information
Print Date
Fit to Page, Adjust One-Touch Color (Sepia Tone), Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Numeric Keys), Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Transparency Cover Sheets, Front Cover*3, Sheets/Chapter Pages*3, Booklet Scanning, Do Not Booklet Scan, Between Batches, Saddle Stitch, Saddle Fold, Print on Tab, Superimpose Image, Page Numbering*5, Copy Set Numbering*5, Watermark*5, Two Colors, Divided Booklet, Creep Correction, Secure Watermark, Scan Lock Information (QR Code), Scan Lock Information (TL Code), Tracking Information
Print & Check
Book
2-Sided, 2-Sided 2-Sided, 2-Sided 1-Sided, Poster (Number of Output Pages), Poster (%), Book 2 Pages, N on 1, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Transparency Cover Sheets, Booklet Scanning, Do Not Booklet Scan, Between Batches, Superimpose Image, Divided Booklet, Creep Correction, Merge Job Blocks, Store in Mail Box |
Merge Job Blocks
Adjust One-Touch Color (Vivid Colors/Tranquil Colors), Adjust One-Touch Color (Lighten Image/Darken Image/Highlight Reproduction), Adjust One-Touch Color (Sepia Tone), Color Balance, Color Balance (Fine Adjust Density), Poster (Number of Output Pages), Poster (%), Single Color, Nega/Posi, Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Framing, Blanking, Transparency Cover Sheets, Booklet Scanning, Do Not Booklet Scan, Between Batches, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Group, Saddle Stitch, Saddle Fold, C-Fold, Accordion Z-Fold, Double Parallel Fold, Half Fold, Print on Tab, Interrupt, Superimpose Image, Two Colors, Divided Booklet, Creep Correction, Print & Check, Color Balance (Adjust Hue), Color Balance (Adjust Saturation), Color Balance (Adjust Black Hue), Secure Watermark*6, Scan Lock Information (QR Code)*6, Scan Lock Information (TL Code)*6, Tracking Information*6
Store in Mail Box
Custom Size, Adjust One-Touch Color (Vivid Colors/Tranquil Colors), Adjust One-Touch Color (Lighten Image/Darken Image/Highlight Reproduction), Adjust One-Touch Color (Sepia Tone), Color Balance, Color Balance (Fine Adjust Density), Single Color, Mirror Image, Between Batches, C-Fold, Accordion Z-Fold, Double Parallel Fold, Half Fold, Copy Sample, Superimpose Image, Two Colors, Print & Check, Color Balance (Adjust Hue), Color Balance (Adjust Saturation), Color Balance (Adjust Black Hue)
Custom Size, Adjust One-Touch Color (Vivid Colors/Tranquil Colors), Adjust One-Touch Color (Lighten Image/Darken Image/Highlight Reproduction), Adjust One-Touch Color (Sepia Tone), Color Balance, Color Balance (Fine Adjust Density), Single Color, Mirror Image, Between Batches, C-Fold, Accordion Z-Fold, Double Parallel Fold, Half Fold, Superimpose Image, Two Colors, Color Balance (Adjust Hue), Color Balance (Adjust Saturation), Color Balance (Adjust Black Hue)
Secure Watermark
Sharpness, Adjust One-Touch Color (Vivid Colors/Tranquil Colors), Adjust One-Touch Color (Lighten Image/Darken Image/Highlight Reproduction), Adjust One-Touch Color (Sepia Tone), Color Balance, Color Balance (Fine Adjust Density), Single Color, Nega/Posi, Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Framing, Blanking, Booklet Scanning, Do Not Booklet Scan, Between Batches, Group*2, Rotate 90 Degrees: Group*2, Offset Group*2, Superimpose Image, Copy Set Numbering, Watermark, Print Date, Two Colors, Divided Booklet, Creep Correction, Color Balance (Adjust Hue), Color Balance (Adjust Saturation), Color Balance (Adjust Black Hue), Merge Job Blocks*6, Scan Lock Information (QR Code), Scan Lock Information (TL Code), Tracking Information
Sharpness, Adjust One-Touch Color (Vivid Colors/Tranquil Colors), Adjust One-Touch Color (Lighten Image/Darken Image/Highlight Reproduction), Adjust One-Touch Color (Sepia Tone), Color Balance, Color Balance (Fine Adjust Density), Single Color, Nega/Posi, Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Framing, Blanking, Booklet Scanning, Do Not Booklet Scan, Between Batches, Superimpose Image, Copy Set Numbering, Watermark, Print Date, Two Colors, Divided Booklet, Creep Correction, Color Balance (Adjust Hue), Color Balance (Adjust Saturation), Color Balance (Adjust Black Hue), Merge Job Blocks*6, Scan Lock Information (TL Code), Tracking Information
Sharpness, Adjust One-Touch Color (Vivid Colors/Tranquil Colors), Adjust One-Touch Color (Lighten Image/Darken Image/Highlight Reproduction), Adjust One-Touch Color (Sepia Tone), Color Balance, Color Balance (Fine Adjust Density), Single Color, Nega/Posi, Mirror Image, Repeat Images, Repeat Images (Auto), Repeat Images + Framing, Repeat Images (Auto) + Framing, Framing, Blanking, Booklet Scanning, Do Not Booklet Scan, Between Batches, Superimpose Image, Copy Set Numbering, Watermark, Print Date, Two Colors, Divided Booklet, Creep Correction, Color Balance (Adjust Hue), Color Balance (Adjust Saturation), Color Balance (Adjust Black Hue), Merge Job Blocks*6, Secure Watermark, Scan Lock Information (QR Code)
Tracking Information (Scan Lock Information: TL Code)
Function
Auto (Color/Black)
Full Color*1, Black*1, Adjust One-Touch Color (Sepia Tone)*1, Single Color*1, Two Colors*1
Full Color
Auto (Color/Black)*1, Black*1, Adjust One-Touch Color (Sepia Tone)*1, Single Color*1, Two Colors*1
Black
Auto (Color/Black)*1, Full Color*1, Adjust One-Touch Color (Sepia Tone)*1, Single Color*1, Two Colors*1
Background Density (Adjust Each Color)*1, Background Density (Adjust All Color)*1, Poster (Number of Output Pages), Poster (%)
Background Density (Auto)*1, Background Density (Adjust All Color)*1
Background Density (Auto)*1, Background Density (Adjust Each Color)*1, Between Batches
Between Batches, Color Balance (Adjust Hue), Color Balance (Adjust Saturation), Merge Job Blocks, Store in Mail Box, Store in Mail Box (Copy upon Storing), Secure Watermark, Scan Lock Information (QR Code), Scan Lock Information (TL Code), Tracking Information
Color Balance*1, Color Balance (Fine Adjust Density)*1, Between Batches, Merge Job Blocks, Store in Mail Box, Store in Mail Box (Copy upon Storing), Secure Watermark, Scan Lock Information (QR Code), Scan Lock Information (TL Code), Tracking Information
Auto (Color/Black)*1, Full Color*1, Black*1, Single Color, Between Batches, Superimpose Image, Page Numbering, Copy Set Numbering, Watermark, Print Date, Two Colors, Merge Job Blocks, Store in Mail Box, Store in Mail Box (Copy upon Storing), Secure Watermark, Scan Lock Information (QR Code), Scan Lock Information (TL Code), Tracking Information
Color Balance
Adjust One-Touch Color (Lighten Image/Darken Image/Highlight Reproduction)*1, Between Batches, Merge Job Blocks, Store in Mail Box, Store in Mail Box (Copy upon Storing), Secure Watermark, Scan Lock Information (QR Code), Scan Lock Information (TL Code), Tracking Information
Single Color
Auto (Color/Black)*1, Full Color*1, Black*1, Adjust One-Touch Color (Sepia Tone), Two Colors*1, Merge Job Blocks, Store in Mail Box, Store in Mail Box (Copy upon Storing), Secure Watermark, Scan Lock Information (QR Code), Scan Lock Information (TL Code), Tracking Information
Two Colors
Auto (Color/Black)*1, Full Color*1, Black*1, Adjust One-Touch Color (Sepia Tone), Single Color*1, Superimpose Image, Page Numbering, Copy Set Numbering, Watermark, Print Date, Merge Job Blocks, Store in Mail Box, Store in Mail Box (Copy upon Storing), Secure Watermark, Scan Lock Information (QR Code), Scan Lock Information (TL Code), Tracking Information
Adjust One-Touch Color (Vivid Colors/Tranquil Colors), Between Batches, Merge Job Blocks, Store in Mail Box, Store in Mail Box (Copy upon Storing), Secure Watermark, Scan Lock Information (QR Code), Scan Lock Information (TL Code), Tracking Information
Nega/Posi, Between Batches, Merge Job Blocks, Store in Mail Box, Store in Mail Box (Copy upon Storing), Secure Watermark, Scan Lock Information (QR Code), Scan Lock Information (TL Code)*6, Tracking Information
