Front Cover
Open this cover to remove jammed paper. (See "Paper Folding Unit-G1 (Optional).")
Folding Unit
Exit Slot
The folded paper is output to this tray.
If LTRR is Z-folded, please note that the Auto Orientation Setting differs depending on the orientation of the original.
*1 If Auto Orientation is set to 'Off', part of the image may cut off.
*2 If Auto Orientation is set to 'On', LTRR is selected automatically. However, if the Merge Job Blocks is set, LTRR is not selected automatically.
If 11" x 17" paper and LTR paper are loaded together, only 11" x 17" paper is Z-folded. Even if you set the original in LTR orientation and set Auto Orientation Setting to 'On', LTRR paper is not selected if you set [Different Size Originals].
The Z-folded areas are as shown in the illustration below.
Platen Glass ![]() Feeder ![]() If paper that has been Z-folded is included in the output, the sheets may not be aligned when output.
The half folded areas are as shown in the illustration below.
Platen Glass
![]() Feeder
The C-folded areas are as shown in the illustration below.
Platen Glass
![]() Feeder
The accordion Z-folded areas are as shown in the illustration below.
Platen Glass
![]() Feeder
The double parallel folded areas are as shown in the illustration below.
Platen Glass
![]() Feeder
