Unavailable Combination of Functions
The following tables show the unavailable combinations of settings when you want to set more than one function at a time.
Print Function for Files Stored in a Mail Box
Function
Functions that Cannot Be Used in Combination
Select Color: Auto (Color/Black)
Select Color: Black*1, Select Color: Single Color*1, Select Color: Two Colors*1
Select Color: Black
Select Color: Auto (Color/Black)*1, Select Color: Single Color*1, Select Color: Two Colors*1
Select Color: Auto (Color/Black)*1, Select Color: Black*1, Select Color: Two Colors*1, Secure Watermark: Watermark, Secure Watermark: Date, Secure Watermark: Copy Set Numbering, Secure Watermark: Serial Number, Secure Watermark: ID/User Name, Document Scan Lock: Scan Lock Information, Document Scan Lock: Tracking Information, Adjust One-Touch Color*2
Select Color: Auto (Color/Black)*1, Select Color: Black*1, Select Color: Single Color*1, Secure Watermark: Watermark*3, Secure Watermark: Date*3, Secure Watermark: Copy Set Numbering*3, Secure Watermark: Serial Number*3, Secure Watermark: ID/User Name*3, Document Scan Lock: Scan Lock Information, Document Scan Lock: Tracking Information, Superimpose Image, Gutter, Page Numbering*3, Copy Set Numbering*3, Watermark*4, Print Date*4, Adjust One-Touch Color*2
Automatic Paper Selection
Automatic Paper Selection (Auto Orientation)*1, Multi-Purpose Tray*5, Finishing: Rotate 90 Degrees + Collate, Finishing: Rotate 90 Degrees + Group, Finishing: Saddle Stitch*1, Finishing: Saddle Stitch: Add Cover (Print/Leave Blank)*1, Finishing: Multi-Hole Punch, Finishing: Saddle Fold*1, Finishing: C-Fold*1, Finishing: Half Fold*1, Finishing: Accordion Z-Fold*1, Finishing: Double Parallel Fold*1, Booklet: Booklet Scan*1, Booklet: Booklet ScanBooklet: Do Not Booklet Scan*1, Booklet: Saddle Stitch*1, Booklet: Add Cover*1, Booklet: Divided Booklet*1, Booklet: Creep Correction*1, Print on Tab
Automatic Paper Selection*1, Multi-Purpose Tray*5, Finishing: Rotate 90 Degrees + Collate, Finishing: Rotate 90 Degrees + Group, Finishing: Saddle Stitch, Finishing: Saddle Stitch: Add Cover (Print/Leave Blank), Finishing: Multi-Hole Punch, Finishing: Saddle Fold, Finishing: C-Fold, Finishing: Half Fold, Finishing: Accordion Z-Fold, Finishing: Double Parallel Fold, Different Size Originals, Booklet: Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction
Multi-Purpose Tray
Automatic Paper Selection*5, Automatic Paper Selection (Auto Orientation)*5, Finishing: Collate*6, Finishing: Group*6, Finishing: Rotate 90 Degrees + Collate*5, Finishing: Rotate 90 Degrees + Group*5, Finishing: Offset Collate*5, Finishing: Offset Group*5, Finishing: Staple*5, Finishing: Saddle Stitch*5, Finishing: Saddle Stitch: Add Cover (Print/Leave Blank)*5, Finishing: Hole Punch*5, 2-Sided: 2-Sided Printing*5, 2-Sided: Document Separate Duplex Printing*5, 2-Sided: Document Separate Continuous Printing*5, Insert Sheets: Sheet Insertion (Print/Leave Blank)*5, Insert Sheets: Chapter Page*5, Job Separator*5, Booklet: Booklet Scan*5, Booklet: Saddle Stitch*5, Booklet: Add Cover*5, Booklet: Divided Booklet*5, Booklet: Creep Correction*5, Superimpose Image*6
Print Sample
Finishing: Group, Finishing: Rotate 90 Degrees + Group, Finishing: Offset Group, Multiple Documents
Finishing: Collate
Multi-Purpose Tray*6, Finishing: Group*1, Finishing: Rotate 90 Degrees + Collate*1, Finishing: Rotate 90 Degrees + Group*1, Finishing: Offset Collate*1, Finishing: Offset Group*1, Finishing: Staple*1, Finishing: Saddle Stitch*1, Finishing: Saddle Stitch: Add Cover (Print/Leave Blank)*1, Booklet: Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction
Finishing: Group
Multi-Purpose Tray*6, Print Sample, Finishing: Collate*1, Finishing: Rotate 90 Degrees + Collate*1, Finishing: Rotate 90 Degrees + Group*1, Finishing: Offset Collate*1, Finishing: Offset Group*1, Finishing: Staple*1, Finishing: Saddle Stitch*1, Finishing: Saddle Stitch: Add Cover (Print/Leave Blank)*1, Finishing: Saddle Fold, 2-Sided: Document Separate Continuous Printing, Front Cover, Back Cover, Insert Sheets: Sheet Insertion (Print/Leave Blank), Insert Sheets: Chapter Page, Insert Sheets: Tab Paper, Job Separator, Booklet: Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Secure Watermark: Copy Set Numbering, Copy Set Numbering, Print on Tab
Automatic Paper Selection, Automatic Paper Selection (Auto Orientation), Multi-Purpose Tray*5, Finishing: Collate*1, Finishing: Group*1, Finishing: Rotate 90 Degrees + Group*1, Finishing: Offset Collate*1, Finishing: Offset Group*1, Finishing: Staple*1, Finishing: Saddle Stitch*1, Finishing: Saddle Stitch: Add Cover (Print/Leave Blank)*1, Finishing: Hole Punch, Finishing: Multi-Hole Punch, Finishing: Saddle Fold, Finishing: C-Fold, Finishing: Half Fold, Finishing: Accordion Z-Fold, Finishing: Double Parallel Fold, Front Cover, Back Cover, Insert Sheets: Sheet Insertion (Print/Leave Blank), Insert Sheets: Chapter Page, Insert Sheets: Tab Paper, Job Separator, Booklet: Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction
Automatic Paper Selection, Automatic Paper Selection (Auto Orientation), Multi-Purpose Tray*5, Print Sample, Finishing: Collate*1, Finishing: Group*1, Finishing: Rotate 90 Degrees + Collate*1, Finishing: Offset Collate*1, Finishing: Offset Group*1, Finishing: Staple*1, Finishing: Saddle Stitch*1, Finishing: Saddle Stitch: Add Cover (Print/Leave Blank)*1, Finishing: Hole Punch, Finishing: Multi-Hole Punch, Finishing: Saddle Fold, Finishing: C-Fold, Finishing: Half Fold, Finishing: Accordion Z-Fold, Finishing: Double Parallel Fold, 2-Sided: Document Separate Continuous Printing, Front Cover, Back Cover, Insert Sheets: Sheet Insertion (Print/Leave Blank), Insert Sheets: Chapter Page, Insert Sheets: Tab Paper, Job Separator, Booklet: Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Secure Watermark: Copy Set Numbering, Copy Set Numbering, Print on Tab
Multi-Purpose Tray*5, Finishing: Collate*1, Finishing: Group*1, Finishing: Rotate 90 Degrees + Collate*1, Finishing: Rotate 90 Degrees + Group*1, Finishing: Offset Group*1, Finishing: Staple*1, Finishing: Saddle Stitch*1, Finishing: Saddle Stitch: Add Cover (Print/Leave Blank)*1, Finishing: C-Fold, Finishing: Half Fold, Finishing: Accordion Z-Fold, Finishing: Double Parallel Fold, Booklet: Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction
Multi-Purpose Tray*5, Print Sample, Finishing: Collate*1, Finishing: Group*1, Finishing: Rotate 90 Degrees + Collate*1, Finishing: Rotate 90 Degrees + Group*1, Finishing: Offset Collate*1, Finishing: Staple*1, Finishing: Saddle Stitch*1, Finishing: Saddle Stitch: Add Cover (Print/Leave Blank)*1, Finishing: Saddle Fold, Finishing: C-Fold, Finishing: Half Fold, Finishing: Accordion Z-Fold, Finishing: Double Parallel Fold, 2-Sided: Document Separate Continuous Printing, Front Cover, Back Cover, Insert Sheets: Sheet Insertion (Print/Leave Blank), Insert Sheets: Chapter Page, Insert Sheets: Tab Paper, Job Separator, Booklet: Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Secure Watermark: Copy Set Numbering, Copy Set Numbering, Print on Tab
Finishing: Staple
Multi-Purpose Tray*5, Finishing: Collate*1, Finishing: Group*1, Finishing: Rotate 90 Degrees + Collate*1, Finishing: Rotate 90 Degrees + Group*1, Finishing: Offset Collate*1, Finishing: Offset Group*1, Finishing: Saddle Stitch*1, Finishing: Saddle Stitch: Add Cover (Print/Leave Blank)*1, Finishing: Saddle Fold, Finishing: C-Fold, Finishing: Half Fold, Finishing: Accordion Z-Fold, Finishing: Double Parallel Fold, Insert Sheets: Tab Paper*7, Booklet: Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Print on Tab*7
Finishing: Offset by No. of Copies
Automatic Paper Selection, Automatic Paper Selection (Auto Orientation), Multi-Purpose Tray*5, Finishing: Collate*1, Finishing: Group*1, Finishing: Rotate 90 Degrees + Collate*1, Finishing: Rotate 90 Degrees + Group*1, Finishing: Offset Collate*1, Finishing: Offset Group*1, Finishing: Staple*1, Finishing: Saddle Stitch: Add Cover (Print/Leave Blank)*1, Finishing: Hole Punch, Finishing: Multi-Hole Punch, Finishing: Saddle Fold, Finishing: Z-Fold, Finishing: C-Fold, Finishing: Half Fold, Finishing: Accordion Z-Fold, Finishing: Double Parallel Fold, 2-Sided: 1-Sided Printing, Different Size Originals, Front Cover, Back Cover, Insert Sheets: Sheet Insertion (Print/Leave Blank), Insert Sheets: Chapter Page, Insert Sheets: Tab Paper, Job Separator, Booklet: Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Secure Watermark: Copy Set Numbering, Superimpose Image, Page Numbering, Copy Set Numbering, Watermark, Print Date, Print on Tab
Automatic Paper Selection, Automatic Paper Selection (Auto Orientation), Multi-Purpose Tray*5, Finishing: Collate*1, Finishing: Group*1, Finishing: Rotate 90 Degrees + Collate*1, Finishing: Rotate 90 Degrees + Group*1, Finishing: Offset Collate*1, Finishing: Offset Group*1, Finishing: Staple*1, Finishing: Saddle Stitch*1, Finishing: Hole Punch, Finishing: Multi-Hole Punch, Finishing: Saddle Fold, Finishing: Z-Fold, Finishing: C-Fold, Finishing: Half Fold, Finishing: Accordion Z-Fold, Finishing: Double Parallel Fold, 2-Sided: 1-Sided Printing, Different Size Originals, Front Cover, Back Cover, Insert Sheets: Sheet Insertion (Print/Leave Blank), Insert Sheets: Chapter Page, Insert Sheets: Tab Paper, Job Separator, Booklet: Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Secure Watermark: Copy Set Numbering, Superimpose Image, Page Numbering, Copy Set Numbering, Watermark, Print Date, Print on Tab
Multi-Purpose Tray*5, Finishing: Rotate 90 Degrees + Collate, Finishing: Rotate 90 Degrees + Group, Finishing: Saddle Stitch, Finishing: Saddle Stitch: Add Cover (Print/Leave Blank), Finishing: Multi-Hole Punch, Finishing: Saddle Fold, Finishing: C-Fold, Finishing: Half Fold, Finishing: Accordion Z-Fold, Finishing: Double Parallel Fold, Booklet: Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction
Automatic Paper Selection*6, Automatic Paper Selection (Auto Orientation), Finishing: Rotate 90 Degrees + Collate, Finishing: Rotate 90 Degrees + Group, Finishing: Saddle Stitch, Finishing: Saddle Stitch: Add Cover (Print/Leave Blank), Finishing: Hole Punch, Finishing: Saddle Fold, Finishing: C-Fold, Finishing: Half Fold, Finishing: Accordion Z-Fold, Finishing: Double Parallel Fold, Booklet: Booklet Scan, Booklet: Booklet ScanBooklet: Do Not Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Print on Tab
Automatic Paper Selection, Automatic Paper Selection (Auto Orientation), Finishing: Group, Finishing: Rotate 90 Degrees + Collate, Finishing: Rotate 90 Degrees + Group, Finishing: Offset Group, Finishing: Staple, Finishing: Saddle Stitch, Finishing: Saddle Stitch: Add Cover (Print/Leave Blank), Finishing: Hole Punch, Finishing: Multi-Hole Punch, Finishing: Z-Fold, Finishing: C-Fold, Finishing: Half Fold, Finishing: Accordion Z-Fold, Finishing: Double Parallel Fold, 2-Sided: 1-Sided Printing, Front Cover, Back Cover, Insert Sheets: Sheet Insertion (Print/Leave Blank), Insert Sheets: Chapter Page, Insert Sheets: Tab Paper, Job Separator, Booklet: Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Secure Watermark: Copy Set Numbering, Superimpose Image, Page Numbering, Copy Set Numbering, Watermark, Print Date, Print on Tab
Finishing: Z-Fold
Finishing: Saddle Stitch, Finishing: Saddle Stitch: Add Cover (Print/Leave Blank), Finishing: Saddle Fold, Finishing: C-Fold, Finishing: Half Fold, Finishing: Accordion Z-Fold, Finishing: Double Parallel Fold, Booklet: Booklet Scan, Booklet: Booklet ScanBooklet: Do Not Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction
Finishing: C-Fold
Automatic Paper Selection, Automatic Paper Selection (Auto Orientation), Finishing: Rotate 90 Degrees + Collate, Finishing: Rotate 90 Degrees + Group, Finishing: Offset Collate, Finishing: Offset Group, Finishing: Staple, Finishing: Offset by No. of Copies, Finishing: Saddle Stitch, Finishing: Saddle Stitch: Add Cover (Print/Leave Blank), Finishing: Hole Punch, Finishing: Multi-Hole Punch, Finishing: Saddle Fold, Finishing: Z-Fold, Finishing: Half Fold, Finishing: Accordion Z-Fold, Finishing: Double Parallel Fold, Front Cover, Back Cover, Insert Sheets: Sheet Insertion (Print/Leave Blank), Insert Sheets: Chapter Page, Insert Sheets: Tab Paper, Job Separator, Booklet: Booklet Scan, Booklet: Booklet ScanBooklet: Do Not Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Print on Tab
Automatic Paper Selection, Automatic Paper Selection (Auto Orientation), Finishing: Rotate 90 Degrees + Collate, Finishing: Rotate 90 Degrees + Group, Finishing: Offset Collate, Finishing: Offset Group, Finishing: Staple, Finishing: Offset by No. of Copies, Finishing: Saddle Stitch, Finishing: Saddle Stitch: Add Cover (Print/Leave Blank), Finishing: Hole Punch, Finishing: Multi-Hole Punch, Finishing: Saddle Fold, Finishing: Z-Fold, Finishing: C-Fold, Finishing: Accordion Z-Fold, Finishing: Double Parallel Fold, Front Cover, Back Cover, Insert Sheets: Sheet Insertion (Print/Leave Blank), Insert Sheets: Chapter Page, Insert Sheets: Tab Paper, Job Separator, Booklet: Booklet Scan, Booklet: Booklet ScanBooklet: Do Not Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Print on Tab
Automatic Paper Selection, Automatic Paper Selection (Auto Orientation), Finishing: Rotate 90 Degrees + Collate, Finishing: Rotate 90 Degrees + Group, Finishing: Offset Collate, Finishing: Offset Group, Finishing: Staple, Finishing: Offset by No. of Copies, Finishing: Saddle Stitch, Finishing: Saddle Stitch: Add Cover (Print/Leave Blank), Finishing: Hole Punch, Finishing: Multi-Hole Punch, Finishing: Saddle Fold, Finishing: Z-Fold, Finishing: C-Fold, Finishing: Half Fold, Finishing: Double Parallel Fold, Front Cover, Back Cover, Insert Sheets: Sheet Insertion (Print/Leave Blank), Insert Sheets: Chapter Page, Insert Sheets: Tab Paper, Job Separator, Booklet: Booklet Scan, Booklet: Booklet ScanBooklet: Do Not Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Print on Tab
Automatic Paper Selection, Automatic Paper Selection (Auto Orientation), Finishing: Rotate 90 Degrees + Collate, Finishing: Rotate 90 Degrees + Group, Finishing: Offset Collate, Finishing: Offset Group, Finishing: Staple, Finishing: Offset by No. of Copies, Finishing: Saddle Stitch, Finishing: Saddle Stitch: Add Cover (Print/Leave Blank), Finishing: Hole Punch, Finishing: Multi-Hole Punch, Finishing: Saddle Fold, Finishing: Z-Fold, Finishing: C-Fold, Finishing: Half Fold, Finishing: Accordion Z-Fold, Front Cover, Back Cover, Insert Sheets: Sheet Insertion (Print/Leave Blank), Insert Sheets: Chapter Page, Insert Sheets: Tab Paper, Job Separator, Booklet: Booklet Scan, Booklet: Booklet ScanBooklet: Do Not Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Print on Tab
Finishing: Saddle Stitch, Finishing: Saddle Stitch: Add Cover (Print/Leave Blank), Finishing: Saddle Fold, 2-Sided: 2-Sided Printing*1, 2-Sided: Document Separate Duplex Printing*1, 2-Sided: Document Separate Continuous Printing*1, Booklet: Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction
Multi-Purpose Tray*5, 2-Sided: 1-Sided Printing*1, Merge Files and Print, Booklet: Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Print on Tab
Multi-Purpose Tray*5, 2-Sided: 1-Sided Printing*1, 2-Sided: Document Separate Continuous Printing*1, Single Document, Multiple Documents, Booklet: Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Print on Tab
Multi-Purpose Tray*5, Finishing: Group, Finishing: Rotate 90 Degrees + Group, Finishing: Offset Group, 2-Sided: 1-Sided Printing*1, 2-Sided: Document Separate Duplex Printing*1, Single Document, Multiple Documents, Booklet: Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Print on Tab
Different Size Originals*8
Automatic Paper Selection (Auto Orientation), Finishing: Saddle Stitch, Finishing: Saddle Stitch: Add Cover (Print/Leave Blank), Booklet: Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction
Single Document
2-Sided: Document Separate Duplex Printing, 2-Sided: Document Separate Continuous Printing, Multiple Documents, Merge Files and Print, Front Cover, Back Cover, Insert Sheets: Sheet Insertion (Print/Leave Blank), Insert Sheets: Chapter Page, Insert Sheets: Tab Paper, Job Separator
Multiple Documents
Print Sample, 2-Sided: Document Separate Duplex Printing, 2-Sided: Document Separate Continuous Printing, Single Document, Merge Files and Print, Front Cover, Back Cover, Insert Sheets: Sheet Insertion (Print/Leave Blank), Insert Sheets: Chapter Page, Insert Sheets: Tab Paper, Job Separator, Booklet: Booklet Scan*9, Booklet: Saddle Stitch*9, Booklet: Add Cover*9, Booklet: Divided Booklet*9, Booklet: Creep Correction*9
2-Sided: 2-Sided Printing, Single Document, Multiple Documents, Front Cover, Back Cover, Insert Sheets: Sheet Insertion (Print/Leave Blank), Insert Sheets: Chapter Page
Front Cover
Finishing: Group, Finishing: Rotate 90 Degrees + Collate, Finishing: Rotate 90 Degrees + Group, Finishing: Offset Group, Finishing: Saddle Stitch, Finishing: Saddle Stitch: Add Cover (Print/Leave Blank), Finishing: Saddle Fold, Finishing: C-Fold, Finishing: Half Fold, Finishing: Accordion Z-Fold, Finishing: Double Parallel Fold, Single Document, Multiple Documents, Merge Files and Print, Insert Sheets: Tab Paper, Job Separator, Booklet: Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Superimpose Image, Print on Tab
Back Cover
Multi-Purpose Tray*5, Finishing: Group, Finishing: Rotate 90 Degrees + Collate, Finishing: Rotate 90 Degrees + Group, Finishing: Offset Group, Finishing: Saddle Stitch, Finishing: Saddle Stitch: Add Cover (Print/Leave Blank), Finishing: Saddle Fold, Finishing: C-Fold, Finishing: Half Fold, Finishing: Accordion Z-Fold, Finishing: Double Parallel Fold, Single Document, Multiple Documents, Merge Files and Print, Insert Sheets: Tab Paper, Job Separator, Booklet: Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Superimpose Image, Print on Tab
Finishing: Group, Finishing: Rotate 90 Degrees + Collate, Finishing: Rotate 90 Degrees + Group, Finishing: Offset Group, Finishing: Staple*7, Finishing: Saddle Stitch, Finishing: Saddle Stitch: Add Cover (Print/Leave Blank), Finishing: Saddle Fold, Finishing: C-Fold, Finishing: Half Fold, Finishing: Accordion Z-Fold, Finishing: Double Parallel Fold, Single Document, Multiple Documents, Front Cover, Back Cover, Insert Sheets: Sheet Insertion (Print/Leave Blank), Insert Sheets: Chapter Page, Job Separator, Booklet: Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Superimpose Image, Print on Tab
Job Separator
Multi-Purpose Tray*5, Finishing: Group, Finishing: Rotate 90 Degrees + Collate, Finishing: Rotate 90 Degrees + Group, Finishing: Offset Group, Finishing: Saddle Stitch, Finishing: Saddle Stitch: Add Cover (Print/Leave Blank), Finishing: Saddle Fold, Finishing: C-Fold, Finishing: Half Fold, Finishing: Accordion Z-Fold, Finishing: Double Parallel Fold, Single Document, Multiple Documents, Front Cover, Back Cover, Insert Sheets: Sheet Insertion (Print/Leave Blank), Insert Sheets: Chapter Page, Insert Sheets: Tab Paper, Booklet: Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Superimpose Image, Print on Tab
Automatic Paper Selection, Automatic Paper Selection (Auto Orientation), Multi-Purpose Tray*5, Finishing: Collate, Finishing: Group, Finishing: Rotate 90 Degrees + Collate, Finishing: Rotate 90 Degrees + Group, Finishing: Offset Collate, Finishing: Offset Group, Finishing: Staple, Finishing: Saddle Stitch, Finishing: Saddle Stitch: Add Cover (Print/Leave Blank), Finishing: Hole Punch, Finishing: Multi-Hole Punch, Finishing: Saddle Fold, Finishing: Z-Fold, Finishing: C-Fold, Finishing: Half Fold, Finishing: Accordion Z-Fold, Finishing: Double Parallel Fold, 2-Sided: 1-Sided Printing, 2-Sided: 2-Sided Printing, 2-Sided: Document Separate Duplex Printing, 2-Sided: Document Separate Continuous Printing, Different Size Originals, Multiple Documents*9, Front Cover, Back Cover, Insert Sheets: Sheet Insertion (Print/Leave Blank), Insert Sheets: Chapter Page, Insert Sheets: Tab Paper, Job Separator, Shift, Secure Watermark: Watermark, Secure Watermark: Date, Secure Watermark: Copy Set Numbering, Secure Watermark: Serial Number, Secure Watermark: ID/User Name, Document Scan Lock: Scan Lock Information, Document Scan Lock: Tracking Information, Superimpose Image, Gutter, Watermark, Print Date, Print on Tab
Automatic Paper Selection, Finishing: Multi-Hole Punch, Finishing: Z-Fold, Finishing: C-Fold, Finishing: Half Fold, Finishing: Accordion Z-Fold, Finishing: Double Parallel Fold
Booklet: Add Cover
Automatic Paper Selection, Automatic Paper Selection (Auto Orientation), Multi-Purpose Tray*5, Finishing: Collate, Finishing: Group, Finishing: Rotate 90 Degrees + Collate, Finishing: Rotate 90 Degrees + Group, Finishing: Offset Collate, Finishing: Offset Group, Finishing: Staple, Finishing: Saddle Stitch, Finishing: Saddle Stitch: Add Cover (Print/Leave Blank), Finishing: Hole Punch, Finishing: Multi-Hole Punch, Finishing: Saddle Fold, Finishing: Z-Fold, Finishing: C-Fold, Finishing: Half Fold, Finishing: Accordion Z-Fold, Finishing: Double Parallel Fold, 2-Sided: 1-Sided Printing, 2-Sided: 2-Sided Printing, 2-Sided: Document Separate Duplex Printing, 2-Sided: Document Separate Continuous Printing, Different Size Originals, Multiple Documents*9, Front Cover, Back Cover, Insert Sheets: Sheet Insertion (Print/Leave Blank), Insert Sheets: Chapter Page, Insert Sheets: Tab Paper, Job Separator, Booklet: Creep Correction*10, Shift, Secure Watermark: Watermark, Secure Watermark: Date, Secure Watermark: Copy Set Numbering, Secure Watermark: Serial Number, Secure Watermark: ID/User Name, Document Scan Lock: Scan Lock Information, Document Scan Lock: Tracking Information, Superimpose Image, Gutter, Watermark, Print Date, Print on Tab
Automatic Paper Selection, Automatic Paper Selection (Auto Orientation), Multi-Purpose Tray*5, Finishing: Collate, Finishing: Group, Finishing: Rotate 90 Degrees + Collate, Finishing: Rotate 90 Degrees + Group, Finishing: Offset Collate, Finishing: Offset Group, Finishing: Staple, Finishing: Saddle Stitch, Finishing: Saddle Stitch: Add Cover (Print/Leave Blank), Finishing: Hole Punch, Finishing: Multi-Hole Punch, Finishing: Saddle Fold, Finishing: Z-Fold, Finishing: C-Fold, Finishing: Half Fold, Finishing: Accordion Z-Fold, Finishing: Double Parallel Fold, 2-Sided: 1-Sided Printing, 2-Sided: 2-Sided Printing, 2-Sided: Document Separate Duplex Printing, 2-Sided: Document Separate Continuous Printing, Different Size Originals, Multiple Documents*9, Front Cover, Back Cover, Insert Sheets: Sheet Insertion (Print/Leave Blank), Insert Sheets: Chapter Page, Insert Sheets: Tab Paper, Job Separator, Booklet: Divided Booklet*10, Shift, Secure Watermark: Watermark, Secure Watermark: Date, Secure Watermark: Copy Set Numbering, Secure Watermark: Serial Number, Secure Watermark: ID/User Name, Document Scan Lock: Scan Lock Information, Document Scan Lock: Tracking Information, Superimpose Image, Gutter, Watermark, Print Date, Print on Tab
Shift
Booklet: Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Secure Watermark: Copy Set Numbering, Page Numbering, Copy Set Numbering, Watermark, Print Date, Print on Tab
Select Color: Single Color, Select Color: Two Colors*3, Booklet: Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Secure Watermark: Date*1, Secure Watermark: Copy Set Numbering*1, Secure Watermark: Serial Number*1, Secure Watermark: ID/User Name*1, Document Scan Lock: Scan Lock Information*11, Document Scan Lock: Tracking Information, Superimpose Image, Copy Set Numbering, Watermark, Print Date, Color Balance, Adjust One-Touch Color
Select Color: Single Color, Select Color: Two Colors*3, Booklet: Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Secure Watermark: Watermark*1, Secure Watermark: Copy Set Numbering*1, Secure Watermark: Serial Number*1, Secure Watermark: ID/User Name*1, Document Scan Lock: Scan Lock Information*11, Document Scan Lock: Tracking Information, Superimpose Image, Copy Set Numbering, Watermark, Print Date, Color Balance, Adjust One-Touch Color,
Select Color: Single Color, Select Color: Two Colors*3, Finishing: Group, Finishing: Rotate 90 Degrees + Group, Finishing: Offset Group, Finishing: Saddle Stitch, Finishing: Saddle Stitch: Add Cover (Print/Leave Blank), Finishing: Saddle Fold, Booklet: Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Shift, Secure Watermark: Watermark*1, Secure Watermark: Date*1, Secure Watermark: Serial Number*1, Secure Watermark: ID/User Name*1, Document Scan Lock: Scan Lock Information*11, Document Scan Lock: Tracking Information, Superimpose Image, Copy Set Numbering, Watermark, Print Date, Color Balance, Adjust One-Touch Color
Select Color: Single Color, Select Color: Two Colors*10, Booklet: Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Secure Watermark: Watermark*1, Secure Watermark: Date*1, Secure Watermark: Copy Set Numbering*1, Secure Watermark: ID/User Name*1, Document Scan Lock: Scan Lock Information*11, Document Scan Lock: Tracking Information, Superimpose Image, Copy Set Numbering, Watermark, Print Date, Color Balance, Adjust One-Touch Color
Select Color: Single Color, Select Color: Two Colors*3, Booklet: Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Secure Watermark: Watermark*1, Secure Watermark: Date*1, Secure Watermark: Copy Set Numbering*1, Secure Watermark: Serial Number*1, Document Scan Lock: Scan Lock Information*11, Document Scan Lock: Tracking Information, Superimpose Image, Copy Set Numbering, Watermark, Print Date, Color Balance, Adjust One-Touch Color
Select Color: Single Color, Select Color: Two Colors, Booklet: Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Secure Watermark: Watermark*11, Secure Watermark: Date*11, Secure Watermark: Copy Set Numbering*11, Secure Watermark: Serial Number*11, Secure Watermark: ID/User Name*11, Superimpose Image, Page Numbering, Copy Set Numbering, Watermark, Print Date, Color Balance, Adjust One-Touch Color
Select Color: Single Color, Select Color: Two Colors, Booklet: Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Secure Watermark: Watermark, Secure Watermark: Date, Secure Watermark: Copy Set Numbering, Secure Watermark: Serial Number, Secure Watermark: ID/User Name, Superimpose Image, Page Numbering, Copy Set Numbering, Watermark, Print Date, Color Balance, Adjust One-Touch Color
Superimpose Image
Select Color: Two Colors, Multi-Purpose Tray*6, Finishing: Saddle Stitch, Finishing: Saddle Stitch: Add Cover (Print/Leave Blank), Finishing: Saddle Fold, Front Cover, Back Cover, Insert Sheets: Sheet Insertion (Print/Leave Blank), Insert Sheets: Chapter Page, Insert Sheets: Tab Paper, Job Separator, Booklet: Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Secure Watermark: Watermark, Secure Watermark: Date, Secure Watermark: Copy Set Numbering, Secure Watermark: Serial Number, Secure Watermark: ID/User Name, Document Scan Lock: Scan Lock Information, Document Scan Lock: Tracking Information, Page Numbering, Copy Set Numbering, Watermark, Print Date
Gutter
Select Color: Two Colors, Booklet: Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Print on Tab
Page Numbering
Select Color: Two Colors*3, Finishing: Saddle Stitch, Finishing: Saddle Stitch: Add Cover (Print/Leave Blank), Finishing: Saddle Fold, Shift, Document Scan Lock: Scan Lock Information, Document Scan Lock: Tracking Information, Superimpose Image, Copy Set Numbering*12, Watermark*12, Print Date*12
Copy Set Numbering
Select Color: Two Colors*3, Finishing: Group, Finishing: Rotate 90 Degrees + Group, Finishing: Offset Group, Finishing: Saddle Stitch, Finishing: Saddle Stitch: Add Cover (Print/Leave Blank), Finishing: Saddle Fold, Shift, Secure Watermark: Watermark, Secure Watermark: Date, Secure Watermark: Copy Set Numbering, Secure Watermark: Serial Number, Secure Watermark: ID/User Name, Document Scan Lock: Scan Lock Information, Document Scan Lock: Tracking Information, Superimpose Image, Page Numbering*12, Watermark*12, Print Date*12
Watermark
Select Color: Two Colors*4, Finishing: Saddle Stitch, Finishing: Saddle Stitch: Add Cover (Print/Leave Blank), Finishing: Saddle Fold, Booklet: Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Shift, Secure Watermark: Watermark, Secure Watermark: Date, Secure Watermark: Copy Set Numbering, Secure Watermark: Serial Number, Secure Watermark: ID/User Name, Document Scan Lock: Scan Lock Information, Document Scan Lock: Tracking Information, Superimpose Image, Page Numbering*12, Copy Set Numbering*12, Print Date*12
Print Date
Select Color: Two Colors*4, Finishing: Saddle Stitch, Finishing: Saddle Stitch: Add Cover (Print/Leave Blank), Finishing: Saddle Fold, Booklet: Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Shift, Secure Watermark: Watermark, Secure Watermark: Date, Secure Watermark: Copy Set Numbering, Secure Watermark: Serial Number, Secure Watermark: ID/User Name, Document Scan Lock: Scan Lock Information, Document Scan Lock: Tracking Information, Superimpose Image, Page Numbering*12, Copy Set Numbering*12, Watermark*12
Color Balance
Select Color: Single Color*2, Select Color: Two Colors*2, Secure Watermark: Watermark, Secure Watermark: Date, Secure Watermark: Copy Set Numbering, Secure Watermark: Serial Number, Secure Watermark: ID/User Name, Document Scan Lock: Scan Lock Information, Document Scan Lock: Tracking Information
Print on Tab
Automatic Paper Selection, Finishing: Group, Finishing: Rotate 90 Degrees + Group, Finishing: Offset Group, Finishing: Staple*7, Finishing: Saddle Stitch, Finishing: Saddle Stitch: Add Cover (Print/Leave Blank), Finishing: Multi-Hole Punch, Finishing: Saddle Fold, Finishing: C-Fold, Finishing: Half Fold, Finishing: Accordion Z-Fold, Finishing: Double Parallel Fold, 2-Sided: 2-Sided Printing, 2-Sided: Document Separate Duplex Printing, 2-Sided: Document Separate Continuous Printing, Front Cover, Back Cover, Insert Sheets: Sheet Insertion (Print/Leave Blank), Insert Sheets: Chapter Page, Insert Sheets: Tab Paper, Job Separator, Booklet: Booklet Scan, Booklet: Saddle Stitch, Booklet: Add Cover, Booklet: Divided Booklet, Booklet: Creep Correction, Shift, Gutter
*1 If you select these modes in combination, the mode which is set last has priority.
*2 Combination unavailable if [Sepia Tone] is selected for [Adjust One-Touch Color].
*3 If you select these modes in combination, the text set in these modes is printed in black regardless of the specified color of the text.
*4 If you are using a file which is stored with Two Colors setting from the printer driver, the text set in these modes is printed in black regardless of the specified color of the text. Combination unavailable for other settings.
*5 Combination unavailable if [Custom Size] or [Envelope] is selected.
*6 Combination unavailable if [Envelope] is selected.
*7 You cannot specify the Staple for Bottom Right Corner, Bottom Left Corner, or Right Double stapling with tab paper.
*8 Output prints scanned using the Different Size Originals mode.
*9 Combination unavailable if the record sizes of the selected files are different.
*10 Combination unavailable if [Auto] is selected for the Creep Correction mode.
*11 You cannot combine these modes if Document Scan Lock Information (TL Code) is selected. You can combine these modes if Document Scan Lock Information (QR Code) is selected.
*12 You can combine three modes at most among the following four modes: Page Numbering, Copy Set Numbering, Watermark, and Print Date.
Print Function for PDF/XPS Files
Function
Booklet, N on 1, Match Paper Size
Standard Size Paper Selection
Booklet*1, Rotate 90 Degrees
Collate (Page Order)
Booklet, Group (Same Pages)*3, Staple*3
Group (Same Pages)
Forced Secure Watermark*2, Booklet, Collate (Page Order)*3, Staple*3
Hole Punch
Booklet, Rotate 90 Degrees
Staple
Booklet, Offset Collate, Collate (Page Order)*3, Group (Same Pages)*3, Rotate 90 Degrees
Rotate 90 Degrees
Booklet, Standard Size Paper Selection, Hole Punch, Offset Collate, Staple
Offset Collate
Booklet, Staple, Rotate 90 Degrees
2-Sided Printing
Booklet
Match Paper Size
N on 1
Booklet
Forced Document Scan Lock (QR Code), Forced Document Scan Lock (TL Code), Forced Secure Watermark, 2-Sided Printing, Offset Collate, Rotate 90 Degrees, Staple, Hole Punch, Group (Same Pages), Collate (Page Order), Standard Size Paper Selection*1, Automatic Paper Selection
Forced Document Scan Lock (TL Code), Booklet, Group (Same Pages)*2
Forced Document Scan Lock (QR Code), Forced Secure Watermark, Booklet
Encrypted PDF
PDF Files with a Security Policy*4
Encrypted PDF*4
*1 Combination unavailable if [Envelope] is selected.
*2 You cannot combine these modes when Copy Set Numbering is set for Secure Watermark.
*3 If you select these modes in combination, the mode which is set last has priority.
*4 You cannot set the same password for both Encrypted PDF and PDF Files with a Security Policy.
» Access Stored Files » Unavailable Combination of Functions
08JK-19S
