e-ManualTopSite mapHelp
Top » Web Access » Customizing Settings
0UKW-09Y
This section describes the settings that can be made by the person that manages the operation of Web Access, such as the System Manager.
Only the System Manager, SSO-H System Administrator, Network Administrator, or Device Administrator can configure the Web Access settings. For information on the types of administrators, see "Administrator Settings."
If only the System Manager Information is set and the authentication mode is not used, the settings can be performed by pressing (Settings/Registration) on the control panel of the machine and logging in as the administrator. Enter the System Manager ID and System Manager PIN. The default setting for both the System Manager ID and System Manager PIN is '7654321'. (See "Specifying the System Manager Settings.")
If the desired setting is not displayed, press or to scroll to the desired setting.
