e-ManualTopSite mapHelp
Top » Web Access » Customizing Settings » Restricting the Display Screen
0UKW-0A0
You can specify various settings for the display screen, such as the format of the screen and whether to display images.
Press [Function Settings] → [Web Access] → [Settings].
Press [View Settings].
4.
Specify each setting.
If the desired setting is not displayed, press or to scroll to the desired setting.
[Show Images]:
Select whether to display images within the Web page.
[Use Word Wrap]:
Select whether to use the word wrap function.
[Use JP Hyphenation]:
Select whether to use the Japanese word wrap function.
[Use JavaScript]:
Select whether to use JavaScript.
[Fit Page to Screen Size]:
Select whether to display the content so that it fits within the width of the screen.
[Enable Table]:
Select whether to display tables.
[Show Animated GIFs]:
Select whether to display animated GIFs.
[Format]:
Select [Std CSS only], [Std CSS + Style Attribute], or [Std CSS + Style Attribute + External Imported CSS].
[Standard CSS]:
Select [CSS1], [CSS2], or [CSS3].
If you want to specify the settings for [Show Images], [Use Word Wrap], [Use JP Hyphenation], [Use JavaScript], [Fit Page to Screen Size], [Enable Table], or [Show Animated GIFs]:
If you want to specify the settings for [Format]:
If you want to specify the settings for [Standard CSS]:
Select the desired format → press [OK].
Press [Format] → select the desired format → press [OK].
Press [Standard CSS] → select the type of Standard CSS → press [OK].
