e-ManualTopSite mapHelp
Top » Web Access » Customizing Settings » Privacy Policy and Regulations Settings
0UKW-0AC
You can set restrictions to functions such as URL entry and editing bookmarks.
Press [Function Settings] → [Web Access] → [Settings].
Press [Privacy Policy and Regulations].
4.
Specify each setting → press [OK].
If the desired setting is not displayed, press or to scroll to the desired setting.
[Restrict URL Entry]:
Select whether to restrict URL entry. If you set this setting to 'On', you cannot make entries in the text entry field.
[Restrict Favorites]:
Select whether to restrict the adding and editing of favorites. If you set this setting to 'On', you cannot add, edit, or delete favorites.
[Restrict Home Page Edit]:
Select whether to restrict the editing of the home page. If you set this setting to 'On', you cannot make URL entries on the home page screen. Also, you cannot set the current page as the home page.
[Rstrct History Display]:
Select whether to restrict the display of the URL history.
[ID/User with History]:
Select whether to display the Department ID or User Name on the Details screen of the URL history list.
[Hide Buttons in Toolbar]:
Select whether to display the buttons in the toolbar on the home screen. If you set this setting to 'On', the buttons are not displayed.
[Hide Address in Toolbar]:
Select whether to display the address in the toolbar on the home screen. If you set this setting to 'On', the address is not displayed. In addition, you can no longer switch between display and hide on the Web Access screen.
[Full Screen]:
Select whether to enlarge the display to maximum as a default. However, if you set this setting to 'On', the display text entry field setting is set to 'Off'.
[Hide Web Access Button]:
Select whether to display [Web Access] button on the Main Menu screen.
Depending on the model of your machine, after turning the main power On, you may have to wait for the time set in 'Startup Settings' to elapse before starting Web Access. Network transmission is not possible until this startup time has elapsed. (See "Startup Time Settings.")
If you set [Hide Buttons in Toolbar] to 'Off', the buttons are displayed.
If you set [Hide Address in Toolbar] to 'Off', the address is displayed.
[Full Screen]
Even if you set [Full Screen] to 'On', the address bar display can be set to 'On' or 'Off'.
