e-ManualTopSite mapHelp
Top » Web Access » Customizing Settings » Proxy Settings
Proxy Settings
0UKW-0AE
For security purposes, you can specify the Web addresses that do not require the use of proxies. You can also confirm the proxy settings of the machine.
Press [Function Settings] → [Web Access] → [Settings].
Press [Proxy Settings].
4.
Press the <Address Without Using Proxy> text entry field.
If you want to use HTTP1.1 for the proxy connection, select [On] for <Use HTTP1.1 for proxy connection>.
If the Web page is not properly displayed, set <Use HTTP1.1 for proxy connection> to 'On' to display the Web page properly.
5.
Enter the URL of the desired Web page → press [OK].
6.
Press [OK].
For information on changing the proxy settings of the machine, see "Settings Common to TCP/IPv4 and TCP/IPv6."
