Top » Fax/I-Fax Inbox » Confidential Fax Inbox » Checking the Detailed Information for/Displaying an Image/Deleting a File in a Confidential Fax Inbox
0R9W-16R
Checking the Detailed Information for a File
Press [Fax/I-Fax Inbox] → [Confidential Fax Inbox].
Select the desired inbox.
Select a file to check → press [Details].
Displaying the Image of a File
Select a file to check → press [Display Image].
4.
Press  or  → select the page to check → check the image.
You can press  (reduce) or  (enlarge) to zoom in or out.
You can press , , , or  to specify the area to display when you zoom in or out on the page.
Deleting a File
Select the file that you want to delete → press [Delete].
You can cancel a selection by selecting the file again.
4.
Press [Yes].
