Top » Fax/I-Fax Inbox » Memory RX Inbox » Memory RX Inbox » Printing a File in the Memory RX Inbox
0R9W-16H
Press [Fax/I-Fax Inbox] → [Memory RX Inbox].
Press [Memory RX Inbox].
Select the file that you want to print → press [Print].
4.
Press [Start Printing].
You can print stored files only with the same settings as when they were received.
Files stored in the Memory RX Inbox are automatically deleted after you print them.
You cannot print multiple files simultaneously. To print multiple files, select and print one file at a time.
If you set <Fax Memory Lock> and/or <I-Fax Memory Lock> to 'Off', files received through the Fax/I-Fax function are automatically printed and deleted from the Memory RX Inbox.
