Specify the settings in [Network] in [Preferences] to suit your network environment. The following screen shots show the flow of operations for specifying the network settings.
Settings specified from the control panel become effective after the machine is restarted, after the procedure. If <Perform Apply Setting Changes from Settings/Regist.> is displayed on the bottom of the touch panel display, you can press [Apply Set. Chng.] in
The Administrator is set for the machine by default. Therefore, the administrator must log in by entering the user name and password for the Administrator. The user name of the administrator is 'Administrator' and the password is '7654321'. (Case sensitive.) It is recommended that you change both the System Manager ID and System Manager PIN. For information on administrators, see "Setting Administrators."
