Category Top
Optional Equipment and System Requirements
Printing or Sending a Fax from a Computer
Using E-Mail/I-Fax
Sending Data
Checking Your Network Environment
Network Environment Setup Procedures
Connecting the Machine to a Computer or Network
Specifying Network Settings from the Touch Panel Display
Interface Settings
Communication Environment Setup
IEEE802.1X Authentication Settings
Selecting the IEEE802.1X Authentication Method
TCP/IP Network Setup Procedures
Protocol Settings
TCP/IPv4 Settings
TCP/IPv6 Settings
Settings Common to TCP/IPv4 and TCP/IPv6
Confirming TCP/IPv4 Settings (PING Command)
Confirming TCP/IPv6 Settings (PING Command)
Setting the Key Pair Used With SSL Encrypted Communications
IPSec Settings
Registering a Security Policy
Editing a Security Policy
Waiting Time for Connection at Startup
Setting Up a Computer for Printing/Sending a Fax
Printer Connection Method (LPD/Raw)
Windows XP/Server 2003/Server 2008/Vista/7/Server 2008 R2/8/8.1/Server 2012/Server 2012 R2
Mac OS X 10.5 - 10.9
UNIX
Printer Connection Method (IPP/IPPS)
Printer Connection Method (FTP)
Printer Connection Method (WSD)
Setting Up a Computer as a File Server
FTP Server Settings
WebDAV Server Settings
SMB/CIFS Network Setup Procedures
Protocol Settings
Connecting to a TCP/IP Network
Connecting to an SMB/CIFS Network and Configuring a Shared Folder
AppleTalk Network Setup Procedures
Protocol Settings
Network Connection Problems and Remedies
Printing Problems and Remedies
Data Sending/File Sharing Problems and Remedies
Encrypted SSL Data Communication Problems and Remedies
Confirming Settings
Checking the Block Log
Obtaining the Public Key of the Machine to Use SSL with Windows Server 2008/Vista/7/Server 2008 R2/8/8.1/Server 2012/Server 2012 R2
Top » Network » AppleTalk Network Setup Procedures » Protocol Settings
Protocol Settings
0R9W-1S8
This section describes how to specify the protocol settings for the machine using the control panel. If you are configuring the settings for the first time, use the control panel of the machine.
After configuring the settings, you can change them using software other than the control panel of the machine. For more information, see "Settings/Registration Table."
Press [Preferences] → [Network] → [AppleTalk Settings].
Press [On] for <Use AppleTalk> → specify the following items → press [OK].
Press [Off] for <Use AppleTalk> if you do not want to use AppleTalk.
To set the printer name displayed on the printer screen of the Macintosh, press [Service Name]. Enter a name for the printer → press [OK].
If a zone is set in your network environment, set the zone name. Press [Zone]. Enter the zone name → press [OK].
If you set <Use AppleTalk> to 'On', the machine will not completely enter the Sleep mode.
If there is more than one printer in the same zone, each printer must have a unique name.
You can also enter a zone name by pressing [Browse] and selecting the appropriate name from the displayed list.
Depending on the machine you are using, you may have to use optional equipment to print via an AppleTalk network. For information on the optional products required, see "Optional Equipment and System Requirements."
