Printing or Sending a Fax from a Computer
0R9W-1LK
Optional Equipment Requirements
You cannot print or send a fax from an SMB/CIFS network.
If you want to use the UFR II printer driver
Optional equipment is unnecessary
If you want to use the PCL printer driver
If you want to use the PS printer driver
Sending a Fax for a TCP/IP Network
Super G3 FAX Board
The following network and system environments are compatible when printing or sending a fax from a computer:
Compatible OS
Windows XP Professional
Windows XP Home Edition
Windows Server 2003
Windows Server 2008
Windows Vista Ultimate
Windows Vista Business
Windows Vista Home Premium
Windows Vista Home Basic
Windows Vista Enterprise
Windows 7 Ultimate
Windows 7 Enterprise
Windows 7 Professional
Windows 7 Home Premium
Windows Server 2008 R2
Windows 8
Windows 8 Pro
Windows 8 Enterprise
Windows 8.1
Windows Server 2012
Windows Server 2012 R2
Mac OS X 10.7 - 10.9
Computers/memory
Any computer which runs the above operating system software properly
With an AppleTalk Network
Compatible AppleTalk
EtherTalk Phase 2
With a Server-Based Computing Environment:
Compatible Windows Terminal Server (Services)
Windows Server 2003
Windows Server 2008
Windows Server 2012
Compatible Software
Citrix MetaFrame 1.8
Citrix MetaFrame XP
To print with the Mac OS X Classic environment, you need to use a PS printer driver provided by Apple Inc. with the Mac OS, via an AppleTalk network.
If you are using a Macintosh, you cannot use the PCL printer driver.
If you are using the UFR II printer driver or PS printer driver in a Macintosh environment, you cannot print documents via an AppleTalk network.
If you are using a Macintosh, you can send faxes only when you are connected via USB or you are connected to a TCP/IP network. For instructions on using the fax driver for Macintosh, see "Sending a Fax from a Computer (Mac OS)."
The machine does not support Macintosh LocalTalk networks.
