See the following sections.
The printout is hardly readable and printed poorly.
The printout is too light or has uneven density.
Vertical white streaks appear on the printout.
The printout has spots and is dirty.
The printout is askew.
The toner does not flow well into the paper.
See the following section:
Cannot print 2-sided documents.
Specify the 2-sided printing options in the printer driver.
The printout is printed askew.
Make sure that the number of sheets or the paper type loaded in the paper drawer or multi-purpose tray meets the paper specifications.
Adjust the paper guides to the paper size. If the problem persists, load paper with the other side face up, or in an opposite orientation.
Make sure that the document return tray or output tray is not full.
Cannot print documents from a computer.
Cannot print over a TCP/IP network.
