NO
Uninstall the printer driver and install it again.
See the Starter Guide.
YES
YES
As a rule, LPR sends jobs under the name of the application software used for printing or the file name. A job cannot be sent to the machine if a file name exceeds 255 bytes. Use a shorter file name.
NO
NO
Make sure to select the right printer to send your print jobs to. You can make your selection in the printer folder.
YES
NO
Check the printer port settings.
(1) Open the printer folder.
(2) Right-click the icon of the machine and select [Printer properties] (or [Properties]).
(3) Click the [Ports] tab.
(4) Check the settings specified for the TCP/IP printer port, the printer IP address, and name to see if the settings are configured properly in the [Print to the following port(s)] list.
If not, select the right port and press [OK].
If the port is not found, see "Configuring Port Settings over a TCP/IP Connection" and create a new port.
YES
NO
Check to see if the IP address is entered correctly.
When setting the IP address through DHCP, BOOTP, or RARP, note that the DHCP, BOOTP, or RARP server needs to be running.
YES
NO
Check your network settings.
YES
YES
Check the following
The distance between wireless LAN router/access points is within 164' (50 m) (may vary on the communication speed or environmental condition)
There are no obstacles between the wireless LAN router/access point and the machine
There are no microwave ovens or refrigerators near the installation area
When multiple networks are used, to avoid interference between the channels, each network will be set to a channel that is as far apart from other network channels as possible such as Ch.1, Ch.6, and Ch.11
If there is no improvement
Turn OFF the machine and wait for at least 10 seconds before turning it back ON.
