YES
Remove all the obstructions.
NO
NO
Load the document properly.
Load the paper properly.
YES
NO
Load the type of paper that meets the paper specifications.
YES
NO
Remove the sealing tape from the toner cartridge.
YES
NO
Install the toner cartridge properly.
YES
NO
If a toner cartridge has reached the end of its life, replace the toner cartridge with a new one.
YES
NO
Clean the scanning components or fixing unit.
YES
YES
Make sure to select the appropriate side of paper to copy your document on, as the side to be placed face up in the paper source varies depending on the paper type that you are using. If the copy result is not satisfactory, try to copy your document on the other side.
