NO
Uninstall the printer driver and install it again.
See the Starter Guide.
YES
YES
When a print job remains in the print queue without being processed due to an unexpected interruption, the machine may not respond. Delete the job and try to print it again. To delete print jobs from your computer, follow the steps in the procedure below:
(1) Open the printer folder.
(2) Double-click the machine icon.
(3) The list of print jobs is displayed.
To delete all the print jobs
Click [Printer] -> [Cancel All Documents]. To delete a specific print job
Right-click the print job and click [Cancel]. If this does not work, delete the print job(s) manually from the machine.
NO
NO
Configure the printer driver settings.
YES
NO
Reconnect the USB cable and check the connection status. If necessary, try a different USB cable.
YES
NO
Restart your computer and the machine and connect the machine to a different USB port on your computer.
YES
YES
Check the following.
The distance between wireless LAN router/access points is within 164' (50 m) (may vary on the communication speed or environmental condition)
There are no obstacles between the wireless LAN router/access point and the machine
There are no microwave ovens or refrigerators near the installation area
When multiple networks are used, to avoid interference between the channels, each network will be set to a channel that is as far apart from other network channels as possible such as Ch.1, Ch.6, and Ch.11
If there is no improvement
Turn OFF the machine and wait for at least 10 seconds before turning it back ON.
