Problem 1
A paper jam occurred inside the machine while the copy image was being adjusted.
Action
Remove the jammed paper and reset.
Problem 2
The toner ran out while the copy image was being adjusted.
Action
Replace the toner cartridge with new one.
Problem 1
When setting up using the WPS function, the machine could not detect wireless LAN router or access points.
Action
Repeat the setup again using the WPS function.
Push Button Mode: Press the WPS button within two minutes from the start of the search for an access point.
"Setting the Machine Using WPS (Push Button Mode)"PIN code mode: Enter the PIN code from a computer to the wireless LAN router or access point within 10 minutes of the start of the search for an access point.
"Setting the Machine Using WPS (PIN Code Mode)" "Entering the PIN Code in the Wireless LAN Router/Access Point"
Problem 2
The SSID of the wireless LAN router or access point was not entered correctly using the manual input settings.
Action
If you the settings of the wireless LAN router/access point have been changed, the settings have not been marked or you are unsure of them, check the SSID of the wireless LAN router or access point using Canon MF/LBP Wireless Setup Assistant.
Problem 3
Network problems are preventing the machine from detecting the wireless LAN router or access point.
Action
Check network connection.
If the access point cannot be determined even after checking the network connection, check the security settings on the wireless LAN router or access point.
Problem
You are restricted to send a fax to multiple destinations simultaneously.
Action
You need to disable the restriction. Contact your administrator for more information.
Problem
A group was specified as the destination after the Hook key has been pressed.
Action
Do not press the Hook key when specifying a group destination.
Problem 1
The memory media was disconnected while it was being written to, and writing failed.
Action
Check to see if the memory media was disconnected, and try writing again.
Problem 2
An error occurs when transferring images to memory media, and images cannot be transferred normally. (It is possible that the connected memory media is formatted with an unsupported file system.)
Action
Check the status of the memory media and whether it is formatted with a file system that is supported by the machine (FAT16 or FAT32). After checking, try again.
Problem 1
A paper jam occurred while the fixing unit was being cleaned.
Action
Clear the paper jam and reload paper.
Problem 2
The toner became nearly empty while the fixing unit was being cleaned.
Action
See the following to view the onscreen instructions and fix the problem.
Problem
Close the back cover completely.
Action
Check to make sure that the back cover is completely closed.
Problem
The front cover is not completely closed.
Action
Check to make sure that the front cover is completely closed.
Problem
Your computer is not connected to the machine when you try to scan a document from it.
Action
Connect the computer.
Problem
Cannot save scanned data to USB memory. USB memory is not connected.
Action
Connect a supported USB memory.
Problem
The network key (PSK) for the wireless LAN router or access point is not setup in the machine correctly.
Action1
Check the wireless LAN or access point you are using, enter the correct network key (PSK) and repeat the setup again.
Action2
If the network key (PSK) is correct, check the network connection.
Problem
Connection failed because settings for your wireless LAN routers and/or access points are different from security settings of the machine.
Action
Check the security settings of the wireless LAN router or access point, and repeat the setup again.
Problem
Other wireless LAN routers or access points within connection range were detected.
Multiple wireless LAN routers and/or access points cannot be connected simultaneously by holding down their respective WPS buttons.
Action
Wait for a while and try again.
Problem
Attempted to enable <Dept. ID Management On/Off>, but no department IDs are registered.
Action
Register the Dept. ID from the Remote UI.
Problem
The correct paper size is not specified.
Action
Problem
The toner cartridge is not inserted.
Action
Insert the toner cartridge.
Problem
Faxes could not be sent or received due to insufficient memory.
Action 1
If there are jobs waiting to be sent or printed, fax your document once all these jobs are completed.
Action 2
Print, send, or delete jobs stored in memory.
Action 3
Split a high-volume document into two subsets and send one subset at a time.
Action 4
Reduce the scanning resolution and send the document again.
Problem
You cannot copy your document as memory became full in the middle of processing it.
Action
Set <Original Type> to <Text/Photo (Quality)> before you make a copy.
Problem 1
Failed to scan the documents because of the shortage of memory capacity.
Action 1
Print the pages successfully scanned or cancel the job.
Action 2
Split the job into smaller subsets (fewer than 256 pages) and scan one subset at a time.
Problem 2
Your copy job is collated so all the pages cannot be scanned.
Action 1
Action 2
Split the job into smaller subsets or set <Original Type> to <Text/Photo (Quality)> before you make a copy.
Problem
Saving scanned data to USB memory is restricted.
Action
The setting needs to be changed in order to save to USB memory. Contact your administrator for more information.
Problem
This message automatically appears when you specify multiple destinations.
Action
If you do not want to display this message, you need to change the setting. Contact your administrator for more information.
Problem 1
The current settings do not allow you to specify new destinations.
Action
If you want to specify new destinations, you need to disable the setting. Contact your administrator for more information.
Problem 2
The current settings do not allow you to register new destinations or edit the destinations registered in the address book or one-touch keys.
Action
If you want to register new destinations or edit the registered destinations, you need to change the setting. Contact your administrator for more information.
Problem 1
There is no paper in the paper drawer or multi-purpose tray.
Action
Load paper.
Problem 2
The paper size specified to print a report or list is not appropriate.
Action
Set the paper size to <A4> or <LTR> to print a report or list and load the paper size specified into the paper drawer or multi-purpose tray.
Problem
No destination is registered in the one-touch key or coded dial code that you pressed.
Action
Register a destination.
Problem
The machine is not connected to the network, or the connection is not properly configured.
Action
Connect the machine to the network and properly configure the connection.
See the Starter Guide.
Problem 1
The receiving fax machine did not respond within 35 seconds.
Action
Repeat the sending procedure from the beginning. Additionally, ask the recipient to check the fax machine. When making an overseas call, add a pause to the fax number.
Problem 2
The receiving fax machine may not be a G3 fax machine.
Action
Make sure the receiving fax machine is a G3 fax machine. If it is a G3 fax machine, send the document again. Otherwise, switch to the communication mode supported by the receiving fax machine and send the document again.
Problem
You tried to register the number to a one-touch key or coded dial code in which another number is already registered.
Action
Register the number to an unregistered one-touch key or coded dial code.
Problem
You entered an incorrect PIN.
Action
Enter the correct PIN.
Problem
The number that you entered for confirmation does not match the number that you first entered. This message appears when <Fax No. Confirmation Re-Entry> in <Restrict TX Function> in <System Settings> is set to <On>.
Action
Make sure to enter the same number.
Problem 1
Connection failed because the machine uses "open system" authentication while the wireless LAN router or access point used is set to "Shared Key" authentication.
Action
Change the WEP authentication method on the machine to <Shared Key> accordingly and configure the settings manually.
Problem 2
The connection failed because the machine restricted the MAC address and the MAC address filtering was set with the wireless LAN router or access point you are using.
Action
Change the MAC address for the machine and the computer you are using to the allowed settings.
Problem
Paper is jammed somewhere inside the machine.
Action
Clear the paper jam and load paper and the document again.
Problem
Firmware cannot be updated because the machine is processing.
Action
Please wait.
Problem
The toner cartridge needs a replacement soon.
Action
Shake the toner cartridge to evenly distribute the toner inside the cartridge.
Prepare a new toner cartridge for the impending replacement.
We recommend that the toner cartridge be replaced when printing high-volume documents.
Problem
The output paper is backed up in the output tray.
Action
Remove output paper from output tray.
Problem
Paper is loaded in the multi-purpose tray when you want to print the address book list, user data list, or communication management report. (If paper is loaded in the multi-purpose tray, the lists and report as well as fax messages are not printed. The data will be stored in memory instead.)
Action
Remove paper from the multi-purpose tray and print the list or report again.
Problem
An incorrect paper size is selected to use the Copy ID Cards function.
Action
Specify A4 or LTR sized paper.
Problem
You are restricted to use the auto redial function.
Action 1
Redial the number manually.
Action 2
If you want to use the auto redial function, you need to change the setting. Contact your administrator for more information.
Problem
Connection failed because the machine uses "AES-CCMP" authentication while the wireless LAN router or access point used is set to "TKIP" authentication.
Action
Change so that the WPA/WPA2-PSK encryption on the wireless LAN router or access point will become "AES-CCMP", and repeat setup again.
If you do not change the wireless LAN routers or access points setup, change WPA/WPA2-PSK encryption method for the machine to <Auto> (TKIP or AES-CCMP) and reconfigure them.
Problem 1
The network key (WEP key) for the wireless LAN router or access point is not setup in the machine correctly.
Action
Check the wireless LAN or access point you are using, enter the correct network key (WEP key) and repeat the setup again.
Problem 2
Connection failed because the machine uses "Shared Key" authentication while the wireless LAN router or access point used is set to "Open System" authentication.
Action
Change so that the WEP encryption on the wireless LAN router or access point will become "Shared Key", and repeat setup again.
If you do not change the wireless LAN routers or access points setup, change the WEP authentication method of the machine to <Open System> and reconfigure them.
Problem
An error has occurred with the machine.
Action
Turn OFF the power switch, wait 10 seconds, and turn it back ON. If the problem persists, turn OFF the power switch, disconnect the power cord, and contact your local authorized Canon dealer or the Canon help line.
Problem
Unsupported USB memory or other USB device is connected.
Action
Problem
An error occurred with the machine during setup resulting in communication failure.
Action 1
Turn OFF the machine and turn it back ON, and then repeat the setup again.
Action 2
Problem
An error occurred while performing setup using the WPS function resulting in failure to connect.
Action
Check that the wireless LAN router or access point that you are using supports WPS function. If it does, check the network connection.
If your wireless LAN router or access point is not WPS capable, manually select a specific wireless LAN router or access point for your network identification.
Problem
You attempted to forward the document stored in memory to a destination that is not registered in the address book.
Action
Register a destination in the address book.
