] or [
] (Address Book).|
(1)
When destinations are already registered in the coded dial code, press [
].To register a destination for the first time, proceed to Step (2).
(2)
Select <Register New Destination to Address Book> using [
] or [ ] and press [OK].![]()
(3)
Select <Coded Dial> using [
] or [ ] and press [OK].![]() |
(4)
Select <Fax> or <E-Mail> using [
(5)
Select <Name> using [
(6)
Use the numeric keys to specify <Name>.
(7)
Select <Apply> using [
(8)
Select <Destination> using [
(9)
Use the numeric keys to specify <Destination>.
If you selected <Fax> in Step 4, press [OK] to specify <Set Details> if necessary.
(10)
(11)
(12)
Select the number to be registered using [
(13)
(1)
Press [
(2)
Select <Edit Address Book> using [
(3)
Select the destination that you want to edit using [
(4)
Select the item that you want to edit using [
] or [ ] and press [OK].Type
Name
Destination
Coded Dial
(5)
When the edit is complete, select <Apply> using [
] or [ ] and press [OK]. |
(6)
] or [ ]and press [OK].![]() |
(1)
Press [
(2)
Select <Delete From Address Book> using [
(3)
Select the destination that you want to delete using [
(4)
Select <Yes> using [
] (Back) to close the menu screen.
(1)
Click [No.], [Type] or [Name].
(2)
Click [Edit].
(3)
Specify the required settings in the edit screen and click [OK].
(1)
Click [Delete] of the destination which you want to delete.
