About toner cartridges
For more information on toner cartridges, see the following sections.
Message
When the message is displayed
on the screen |
Description and Solutions
<Prepare toner cartridge.>
When the toner cartridge
needs a replacement soon. |
Shake the toner cartridge to evenly distribute the
toner inside the cartridge We recommend that the toner cartridge be
replaced before printing high-volume documents. |
When white streaks appear on the output, or the output is partially faded
When white streaks appear on the output or the output is partially faded, the toner cartridge has almost reached the end of its life, even if no message appears on the screen. When the print quality becomes unacceptable, see the following to fix the problem.
When the toner nearly runs out, white streaks appear on the output, or the output is partially faded.
When this problem occurs
Follow the steps in the procedure below before replacing the toner cartridge. The machine continues printing until the toner runs out completely.
When the print quality is still unacceptable
If the problem persists after you have followed the steps in the procedure below, replace the toner cartridge.
