Table description
After changing the settings for this item, cycle the power of the printer or perform a hard reset to make the settings effective.
This item is displayed only when the following condition is fulfilled.
[Network] in [Interface Selection] is set to [On].
Bold values in the table indicate the default settings.
The setting items or setting values with "*" may not be displayed depending on the availability of the optional accessories and other settings.
Setting Item
Setting Value
Setting
[TCP/IP Settings]
Specifies the TCP/IP setting for the print server equipped with this printer.
[IPv4 Settings]
[IPv4]: [Off], [On]
When using IPv4, set it to [On].
[IP Mode]: [Auto], [Manual]
Select the method for setting the IP address.
When setting the IP address using any one of DHCP, BOOTP, or RARP, select [Auto].
When specifying the IP address to the printer directly, select [Manual].
[Protocol]*:
[Use DHCP]: [Off], [On]
[Use BOOTP]: [Off], [On]
[Use RARP]: [Off], [On]
If you set [IP Mode] to [Auto], select which protocol you want to use. Set each of [Use DHCP], [Use BOOTP], and [Use RARP] to [On] (use) or [Off] (do not use).
[IP Address Settings]:
[IP Address]: 0.0.0.0
[Subnet Mask]: 0.0.0.0
[Gateway Address]: 0.0.0.0
Specify [IP Address], [Subnet Mask], and [Gateway Address]. For the method for entering the addresses, see "Method for entering addresses " below the table.
[DNS]:
[Primary Address]: 0.0.0.0
[Secondary Address]: 0.0.0.0
Specify [Primary Address] and [Secondary Address] for DNS.
[DHCP Option]:
[Acquire Host Name]: [Off], [On]
[DNS Dynamic Update]: [Off], [On]
Set DHCP options when [IP Mode] is set to [Manual] and [Use DHCP] is set to [On].
When obtaining the host name using DHCP, set [Acquire Host Name] to [On].
When updating the host name using DHCP, set [DNS Dynamic Update] to [On].
[IPv6 Settings]
[IPv6]: [Off], [On]
If you want to use IP v. 6, specify [On].
[WINS Resolution]
[Off], [On]
If you want to use WINS Resolution, specify [On].
[ARP/PING]
[Off], [On]
When it is set to [On], you can change the IP address settings from the client using ARP/PING commands.
[FTP]
[FTP Print]: [Off], [On]
[FTP Settings]: [Off], [On]
When it is set to [On], you can access the printer's FTP server using the FTP client and print the files.
If you want to perform the settings using FTP Client, set [FTP Settings] to [On].
[LPD Print]
[Off], [On]
If you want to use LPD Print, specify [On].
[RAW Print]
[Off], [On]
If you want to use RAW Print, specify [On].
[IPP Print]
[Off], [On]
If you want to use IPP Print, specify [On].
[WSD]
[WSD Print]: [Off], [On]
[WSD Browsing]*: [Off], [On]
[Multicast Discovery]: [Off], [On]
If you want to use WSD Print, set [WSD Print] to [On], and then specify the following settings.
If you want to obtain printer information using WSD, set [WSD Browsing] to [On]. If you set [WSD Print] to [On], [WSD Browsing] is not displayed. ([WSD Browsing] is fixed at [On].)
If you want to set the printer to respond to requests from multicast discovery, set [Multicast Discovery] to [On].
[HTTP]
[Off], [On]
When it is set to [On], you will be able to access the printer using HTTP.
When this is set to [Off], the message appears, disallowing you to use the Remote UI or perform IPP printing.
[Proxy Settings]*
[Proxy]: [Off], [On]
If you want to use the proxy function, specify [On].
[Server Address]*: -
Enter the proxy server address to be used for the proxy function.
[Port Number]*: 0 to 80 to 99999
Enter the port number of the proxy server to be used for the proxy function. You can specify between [0] and [99999].
[Same Domain]*: [Use Proxy], [Do Not Use Proxy]
If you want to use the proxy function also for the same domain, specify [Use Proxy].
[Proxy Authentication]*: [Off], [On]
If you want to use the proxy authentication function, specify [On].
[User Name]*: -
Enter the user name to be used for the proxy authentication. Up to 24 alphanumeric characters can be entered.
[Password]*: -
Enter the password to be used for the proxy authentication. Up to 24 alphanumeric characters can be entered.
[SNTP]
[Off], [On]
When obtaining time using the SNTP Client function, specify [On].
[Discovery Response]
[Off], [On]
If you want to set the printer so that it responds to searches that used the multicast discovery function, specify [On].
[IPSec]
[Off], [On]
When using the IPSec function, set it to [On].
[NetWare Settings]
[NetWare]: [Off], [On]
[Frame Type]*: [Auto Detect], [Ethernet II], [Ethernet 802.2], [Ethernet 802.3], [Ethernet SNAP]
[Print Service]*: [Bindery PServer], [RPrinter], [NDS PServer], [NPrinter]
Configures the NetWare network settings.
[AppleTalk]
[Off], [On]
Specifies whether the printer should use AppleTalk.
[SMB]*
[SMB Server]: [Off], [On]
[SMB Print]: [Off], [On]
Specifies whether the printer should use SMB.
[SNMP v. 1]
[Off], [On]
Specify whether to use the SNMP v. 1 protocol.
[Dctd. Community Set.]
[Dctd. Community 1]:
[Off], [Read Only], [Read/Write] [Dctd. Community 2]:
[Off], [Read Only], [Read/Write] |
[Dctd. Community 1]
Specifies access privileges for the Management Information Base (MIB) of the community (canon_admin) that SNMP manages. [Dctd. Community 2]
Specifies access privileges for the Management Information Base (MIB) of the community (canon_user) that SNMP manages. |
[SNMP v. 3 Settings]
[SNMP v. 3]: [Off], [On]
[User Settings 1] to [User Settings 5]*: [Auth. Password]
[Encryption Password] |
Specify the settings related to SNMP v. 3 protocol.
[Spooler]*
[Off], [On]
When using the spooling function, set it to [On].
[Network Delay Time]*
0 to 300 seconds
Specifies the time interval from when the printer is turned ON to when the protocol starts.
[Remote UI Settings]
[Remote UI]: [Off], [On]
[SSL]*: [Off], [On]*
Specifies whether the printer should use the Remote UI.
Also, whether to use SSL for communication by the Remote UI is specified.
[Ethernet Driver]*
[Auto Detect]: [Off], [On]
[Communication Mode]*: [Half Duplex], [Full Duplex]
[Ethernet Type]*: [10 Base-T], [100 Base-TX], [1000 Base-T]
Configures the Ethernet driver.
[IEEE802.1X]
[Off], [On]
When using the IEEE802.1X function, set it to [On].
[Address Filter]
[Off], [On]
When using the firewall function, set it to [On].
[MAC Address]*
(Display only)
Displays the MAC address of the printer.
[E-Mail Print Set.]
[POP3 RX Interval]: 0 to 90 (minutes)
[POP3 RX]: [Off], [On]
[SMTP RX]: [Off], [On]
Set e-mail print.
[Init. Network Set.]
By the initialization in this item, you can reset the network settings to the default settings.
Move the cursor to each field (an area separated by periods to enter three-digit numbers) in which you want to enter the address, by pressing [
] or [ ]. (The number in the field blinks, allowing you to enter a value.) |
Enter the numbers. ([
] increases the value and [ ] decreases the value.) |
After entering values in all the fields, press [OK] to confirm the settings.
